![]() | | #1 | ![]() |
![]() Join Date: Jun 2012 Location: Clearfield, pennsylvania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
![]() Join Date: Dec 2011 Location: Red Deer,AB Canada
Rep Power: 1607 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,920
Groans: 121
Groaned at 49 Times in 15 Posts
1,3,5...all on top, my guess is a linkage issue. Check your shifter cable.
__________________ 2010 Mazdaspeed 3 Black Mica w/ Tech Package Insalled: Corksport SRI/TIP // Cobb AccessPort// Autotech Internals // Corksport LED Kit // Corksport Stubby Antenna // Forge v2 BPV // JBR SSP// JBR 80a RMM // JBR Weighted Shift Knob // ETS TMIC // Corksport Catless Downpipe // Corksport RacePipe // Denso itv22 // Stratified Guardian Angel // block8head Defrost Pod // Prosport Boost Gauge // Zoom Boom Box Awaiting Install: HTP 3" TIP // HTP Battery Tray // Sure 3" MAF // Stratified Boost Dial |
| The Following 2 Users Say Thank You to Dmurray06 For This Useful Post: | Downmented (10-06-2012), Easter Bunny (10-07-2012) |
| Scammer Hunter ![]() ![]() Join Date: Mar 2008 Location: Jacksonville, FL
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,832
Groans: 448
Modded? Oh, check cable, too.
__________________ ![]() ![]() ![]() 1) Looking to Buy a used Mazdaspeed? Read this! 2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here. 3) Wanna buy and sell here? DONATE for VIP 4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting! 5) Help MSF grow with FAQ threads!? |
![]() | | #4 | ![]() |
only mod is an cobb intake. shifter cable could be it never thought of that duh. Thanks fellas
| The Following User Says Thank You to whitespeed29 For This Useful Post: | Dmurray06 (10-06-2012) |
![]() | | #5 | ![]() |
Groans: 448
If the cable broke, it's easier to torch the car than swap it out. Whole fucking dash has to come out.
![]() | | #6 | ![]() |
anything else
![]() | | #7 | ![]() |
Groans: 121
| Not Ranked : 0 score Will the gears stay engaged at a stop, or while car is off?
![]() | | #8 | ![]() |
i didnt try that. I will tomorrow. Would i just need to get a shoprt shift plate to replace/fix the problem
![]() | | #9 | ![]() |
Groans: 121
Well I would be sure you know the problem before you try and fix it. First I would check, underneath your air box/filter...on top of the transmission is the shifter cable. Check that all out, have someone in your car changing gears while ou look for obvious problems. The cable runs from your shifter to you transmission. No of which is under you car.
![]() | | #10 | ![]() |
what kind of problems am i looking for. noises?
![]() | | #11 | ![]() |
Groans: 121
Well it's not engaging in your top gears so something is wrong with your cable moving in that direct. Check to see if its free of anything hitting it. Inspect the cable and yoke to be sure they are working fine, and are good shape. If all that check out, take apart your shifter in the cabin and check everything out there.
![]() | | #12 | ![]() |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 1611 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
take off your intake, have a friend in the car shift the gears in order. you will be able to see the shift cable moving the linkages. you will then need to stare at them, scratch your nuts and figure out if there is any reason, right there in front of you, why the linkage won't move in the odd numbered gears direction.. you just need to figure it out. when you take off the intake, you'll see it all laid bare. once your helper starts shifting, it should all start to make sense. if it doesn't, there is a good chance you have 0 mechanical aptitude, so you should then find a mechanically inclined friend or pay someone. good luck.
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows ![]() ![]() |
| The Following User Says Thank You to tddvrrn For This Useful Post: | Dmurray06 (10-06-2012) |
![]() | | #13 | ![]() |
its all good. The air intake filter wasnt tight enough and fell off and got stuck on the linkage part. All fixed thanks fellas
![]() | | #14 | ![]() |
Groans: 121
Glad you got it fixed.
__________________ 2010 Mazdaspeed 3 Black Mica w/ Tech Package Insalled: Corksport SRI/TIP // Cobb AccessPort// Autotech Internals // Corksport LED Kit // Corksport Stubby Antenna // Forge v2 BPV // JBR SSP// JBR 80a RMM // JBR Weighted Shift Knob // ETS TMIC // Corksport Catless Downpipe // Corksport RacePipe // Denso itv22 // Stratified Guardian Angel // block8head Defrost Pod // Prosport Boost Gauge // Zoom Boom Box Awaiting Install: HTP 3" TIP // HTP Battery Tray // Sure 3" MAF // Stratified Boost Dial | |
![]() | | #15 | ![]() |
![]() Join Date: Mar 2011 Location: North Jersey
Rep Power: 205 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 150
Groaned at 54 Times in 17 Posts
| Not Ranked : 0 score sorry to resurrect a dead thread but FUCKING WOW
__________________ 2011 Black Mica MS3 FREEKTUNE IN PROGRESS, ATP GTX3071R IWG Full Race exhaust manifold CP-e whale peen + 3.25 in. intake COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport SRI + TIP + CBE Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Installation TBD: , H&R springs + Koni yellow shocks + struts |
| Clutch Problem | ReD BoY | MazdaSpeed 3 - Engine, Transmission & Driveline | 23 | 11-03-2012 07:28 AM |
| Odd trans/shifter problem | kwsmithphoto | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 10-08-2011 07:47 PM |
| 09 Speed 3 Blown Trans/clutch 20k miles dealer refuses to fix. | Blitzkrieg | MazdaSpeed 3 - Engine, Transmission & Driveline | 157 | 01-11-2011 06:59 AM |
| Clutch dissengagement problem | Fagwagon | MazdaSpeed 3 - Engine, Transmission & Driveline | 30 | 03-01-2010 10:26 AM |
| Clutch problem please help | gsrtype1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 44 | 12-14-2009 03:58 PM |
