![]() | | #41 | ![]() |
![]() Join Date: Sep 2013 Location: Quebec
| Not Ranked : 0 score Be sure if you change for fidanza 11lbs as the oem is 25-26, this would make it tricky to lunch VS the tractor feeling of the oem stuff. i will check the results of your tranny It is a good thing to let specialist to open it, i'm not able to open mine...
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... |
| The Following User Says Thank You to Jeff23spl For This Useful Post: | btstarcher (04-21-2014) |
![]() | | #42 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
Groans: 112
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress | |
![]() | | #43 | ![]() |
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
^^This^^
__________________ ![]() "I only do what the voices in my wife’s head tell her to tell me to do" Last edited by CosmicArkie; 04-22-2014 at 10:10 AM. | |
![]() | | #44 | ![]() |
| Not Ranked : 0 score how much is the oem disc? 150$ or less, how much time to remove and put back the tranny? at least 5-6hres ? (Not by a very skilled mazda mechanic) the disc + 2 new bearings (TOB and pilot)
![]() | | #45 | ![]() |
Groans: 112
(Thread Starter) | Not Ranked : 0 score Well the flywheel seems fine.
![]() | | #46 | ![]() |
| Not Ranked : 0 score can you make me a favor ? I would like a picture of your input shaft to see if there is a groove on it or it is straigt and the groove on mine was made by the pilot bearing
![]() | | #47 | ![]() |
Groans: 112
(Thread Starter) | Not Ranked : 0 score Sure thing....wait, the input shaft is part of the transmission, which is at the shop. I might be able to get a pic on Friday, assuming he hasn't torn it down yet.
![]() | | #48 | ![]() |
| Not Ranked : 0 score yes it is but when you get a chance, it is fine
| The Following User Says Thank You to Jeff23spl For This Useful Post: | btstarcher (04-22-2014) |
![]() | | #49 | ![]() |
Groans: 112
(Thread Starter) | Not Ranked : 0 score Can you take a picture of yours so I'll know what to look for?
![]() | | #50 | ![]() |
| Not Ranked : 0 score decided to bring mine to the shop also and forgot to picture it anyway, they will check it.one of the beraing is completly destroyed, i started a new post for it because i can't find replacement just for the bearing, Mazda seems to sell it with the tranny case
| The Following User Says Thank You to Jeff23spl For This Useful Post: | btstarcher (04-23-2014) |
![]() | | #51 | ![]() |
| Not Ranked : 0 score Hey, Ben, For the record, I'm full of shit. Just had a chance to finally open the bible, and it sounds like your flywheel is okay. Look for scratches/discoloration; as long as there is no movement laterally from the center (up/down/left/right), the secondary mass rotates less than 15 teeth, the three locating dowels are not touching the primary mass, and the secondary mass rotates 3 teeth without resistance you're golden. All this presupposes you have less than .059" runout. Thanks, now I've got something _else_ to worry about. I cannot believe something like this has been stuck in a "performance" application.
__________________ ![]() "I only do what the voices in my wife’s head tell her to tell me to do" |
| The Following User Says Thank You to CosmicArkie For This Useful Post: | btstarcher (04-24-2014) |
![]() | | #52 | ![]() |
Groans: 112
(Thread Starter) | Not Ranked : 0 score Yeah I think I found the same reading material; everything checked out just fine. I thought about replacing it anyway but decided against it.
![]() | | #53 | ![]() |
![]() Join Date: Jul 2012 Location: South San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,074
Groaned at 9 Times in 7 Posts
Sent from my SAMSUNG-SGH-I337 using Tapatalk
__________________ 2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's to be installed : 3 Port EBCS HTP 3" intake/ MAF/ TIH Autotech internals Corksport Pmm Test pipe SBC Rear Camber Arms | |
| The Following User Says Thank You to Playaj For This Useful Post: | btstarcher (04-24-2014) |
| whining noise - transmission / lsd / PS problem? | chimneybear | 2010 MS3 - Engine, Transmission & Driveline | 6 | 05-17-2013 11:44 AM |
| Clutch/Transmission Problem | curlyface | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 03-15-2013 01:50 PM |
| Clutch/transmission problem | JMEngineer | MazdaSpeed 3 - Engine, Transmission & Driveline | 22 | 01-17-2013 12:56 PM |
| Amsoil transmission/differential fluids? | tunersteve | MazdaSpeed 6 - Engine, Transmission & Driveline | 20 | 11-27-2009 02:25 AM |
| Transmission Problem | Mickaay | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 11-17-2009 10:53 PM |
