  • 1 Post By Reds3
 Old 01-07-2019, 05:35 PM   #1
sjdannen's Avatar
Posts: 42   (View Stats)
sjdannen is just really nicesjdannen is just really nicesjdannen is just really nicesjdannen is just really nice
Default Transmission fluid from breather??
While dropping of my wife at home, I noticed a spot in the driveway where I park my car. It was fresh enough to feel it and it was slick like oil but to the left hand side. I thought that I might have an oil pan or rear main seal leaking. When I got home from work I pulled the car in the garage and popped the hood and very quickly saw the most likely source of my puddle. The pockets around the manual transmission breather were full of fluid!
I didn't log when I changed the transmission fluid, but it was probably at about 50k miles and I've got 94k miles on it now and was planning on changing it at 100k. Looking at one thread in the forums, some people are changing every 30k.
Would fluid break down cause fluid expansion to the point that it will come out the breather vent, or do I perhaps have a different problem?
sjdannen is offline   Reply With Quote
 Old 01-07-2019, 06:08 PM   #2
Amnesiac's Avatar
Posts: 315   (View Stats)
Amnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the world
Groaned at 6 Times in 4 Posts
Do a search for pivot shaft seal. Pretty common problem
Amnesiac is offline   Reply With Quote
The Following User Says Thank You to Amnesiac For This Useful Post:
sjdannen (01-07-2019)
 Old 01-07-2019, 06:15 PM   #3
sjdannen's Avatar
Thank you Amnesiac.
I put a short shift plate in place about 10k miles ago. Could that contribute to the seal going bad? Or was it just its time to die?
 Old 01-07-2019, 07:01 PM   #4
08mzr's Avatar
Posts: 641   (View Stats)
08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world
The seals just fail. I'd recommend a new pivot bearing as well while you're in there. I just did it on mine, not a hard job at all.
2008 Metro Gray Mica Speed 3-SOLD
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
SPC rear camber arms
Hawk HPS pads front and rear
FREEKTUNE OTS+
1998 Civic - SOLD
2011 Speed3 200k+ miles Stock -Daily
08mzr is offline   Reply With Quote
 Old 01-08-2019, 06:08 AM   #5
Reds3's Avatar
Posts: 21   (View Stats)
Reds3 has a spectacular aura aboutReds3 has a spectacular aura about
How-to: MS3 Pivot Shaft Seal, Bearing, Breather Replacement
incase you cant find it.
Db09ms3 likes this.
Reds3 is offline   Reply With Quote
 Old 01-08-2019, 10:27 AM   #6
Db09ms3's Avatar
Posts: 375   (View Stats)
Groans: 81
Yeah do the seal, bearing and breather. Easy peasy, I did mine in less than an hour.
Stockish
The Following User Says Thank You to Db09ms3 For This Useful Post:
sjdannen (01-13-2019)
 Old 01-08-2019, 11:17 AM   #7
Fstrnyou's Avatar
Posts: 2,377   (View Stats)
When I did mine, I only replaced the seal.
But hindsight, I should have replaced the bearing too while it's all apart.
It hasn't started to leak yet, but it only seems logical that a worn bearing will prematurely wear out a new seal.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 01-08-2019, 04:21 PM   #8
sjdannen's Avatar
Thank you everyone, I really appreciate the info. Local dealer had the seal but not the bearing, so that is on order and will be in on Friday. I did go over the How-To and the whole process looks easier than doing the HPFP swap, so I'm not too worried. And hearing that others have done it in less than an hour has me less worried. Gonna just change the fluid and might as well do an oil change while I'm at it. I have wanted to put the oil catch can back on, so I might just make an afternoon of car maintenance.
Best Gen 2 Transmission Fluid? Tru3 2010 MS3 - Engine, Transmission & Driveline 8 09-11-2018 05:23 PM
OEM transmission fluid spinixguy MazdaSpeed 3 - Engine, Transmission & Driveline 6 10-13-2014 10:04 AM
Enough Transmission fluid? mxrider518 2010 MS3 - Engine, Transmission & Driveline 5 07-01-2013 08:49 AM
Transmission Fluid Crazyspeed3 Mazdaspeed3/6 General Discussion 6 12-23-2011 06:32 PM
Chevy Suburban Transmission Fluid, Using CO2 to Fill a Tire, How To Unclog Windshield Wiper Fluid Spouts, Dead Battery A Haltech Automotive News 0 05-15-2009 03:10 PM
Page generated in 0.30016 seconds with 25 queries
