-   -   Transmission Leak (http://www.mazdaspeedforums.org/forum/f10/transmission-leak-179553/)
JCMS07 11-02-2014 03:53 PM
Transmission Leak
Leaking trans fluid and it appears to be coming from these sensors. Put a socket around the middle one to try and tighten it but it didn't budge. Anyone have an idea on how to tighten the top sensor? Can't get a socket or crescent wrench around it.
Etipp98 11-02-2014 04:00 PM
You're gonna have to take the middle centering plug out to get to it.
JCMS07 11-02-2014 06:32 PM
Don't know anything about transmissions. Ok to just take out the center plug?
Etipp98 11-03-2014 04:26 PM
It wont hurt anything, you might lose some fluid, i cant remember where this is on the case. it just has a spring loaded ball bearing on the opposite end.
JCMS07 11-06-2014 10:48 PM
Took the centering plug out but still couldn't get to the top sensor with a crescent wrench. Just tightened the lower sensor and the centering plug and will keep an eye on it.
ICEBOXOCB 11-17-2014 08:19 AM
Any idea what the top (far left in the photo) sensor is? I haven't been able to find a reference for it in the part explosions online.
Mine starting leaking last week from the sensor itself.
JCMS07 11-18-2014 09:21 PM
Not really sure but looks like it could be a backup lamp switch with part # A61017640B
ENGINE SWITCHES & RELAYS (W/TURBO). Fits: 2007 Mazda Mazda 3 | Jim Ellis Mazda
@Etipp98 Any idea if it's ok to take out the switch and put it back in? Looks like for me it is leaking from the top sensor also.
ICEBOXOCB 11-19-2014 09:57 AM
Yep, that's it. I'm going to swap mine out this weekend. Only cost about $55 with the new gasket. The unicorn jiz MTF is the expensive part. I paid $25 per quart.
Etipp98 11-19-2014 04:54 PM
Yes you can take it out, wont harm anything.
Page generated in 0.17506 seconds with 11 queries
