Is this transmission mount shot? 2 Attachment(s) I've heard more front end clunking than usual, and suspected the TMM since the mount on the other side had to be replaced recently. I took out the battery and tray to have a look, but expected something more obvious than what I saw. I can see what look like some possible small tears from the top side, but I can't see any torn open surfaces themselves. Can anyone who has seen a bad TMM comment on these photos? The not dirty black areas are smooth, not rough like a typical torn rubber surface. Much thanks! |
that's what mine looked liked when I pulled it out and replaced it with a JBR 70duro. |
I'm leaning towards shot, probably those tears look worse on the underside. |
yeah man I'd replace it. Mine was torn on the underside when i ripped it out. |
yeah, it's not dead yet but definitely on it's way out. you can have a new JBR in no time. and feel a difference too. |
My shifting was getting pretty rough when my tmm was on its way out. Are you getting a clunk when on / off throttle? Stock Rear mount? If its a clunk over bumps I would look at sway bar bushings or end links. |
I have stock TMM at 7xxxx miles, CP-E 60 RMM. |
| All times are GMT -7. The time now is 07:27 AM. |
