-   -   Trottle body bypass gasket needed ? (http://www.mazdaspeedforums.org/forum/f10/trottle-body-bypass-gasket-needed-156591/)
tokoam 10-06-2013 08:33 PM
Throttle body bypass gasket needed ?
Well I seen alot of Diy on this install But some installs I see with New gasket replacements others I don't.Question of the day is do I need one ? JBR sells it as a kit with caps gasket and brass fitting.I can go to home depot and buy all that except the gasket can someone chime in on this ?
Dmurray06 10-06-2013 08:33 PM
Trottle?
Really?
tokoam 10-06-2013 08:45 PM
Originally Posted by Dmurray06 (Post 2285842)
Trottle?
Really?
Sorry I'm on 2 bottles of Shipyard double smash pumpkin beer and I'm pretty fucking drunk.It was a honest mistake but anyway you could answer my question Thanks.
Dmurray06 10-06-2013 09:00 PM
Good enough excuse.
No you don't need a new gasket if your doing coolant bypass, which I assume your talking about.
Also you can get the parts at you local hardware store.
Keko 10-06-2013 09:29 PM
You don't need a new gasket, as Dmurray said, but a thicker gasket like the JBR gasket will help block some additional heat transfer. You can do the coolant bypass with stuff from Home Depot if you don't want to replace gaskets.
When i did coolant bypass, TB gasket, and IM gasket there was a huge difference in temps. I suggest doing all of them.
Sid3wayS 10-06-2013 09:37 PM
You dont really need anything. You take the 2 hoses, one is super short like 7" and is connected to a nipple on a hardline, remove it then take the longer one and just connect it directly to the nipple.
2012FailWheelDrive 10-07-2013 12:04 AM
Yup I did the same as above. Get rid of the shorter line and just run the longer one to the hard line bypassing the throttle body. Easy and free to do is always good to me.
Coats 10-07-2013 05:43 AM
I just did both tigs and the bypass
BIG diff in bats.
I would suggest doing them all as well.
The coolant bypass comes from JBR with his throttle insulating gasket for $25
$50 or $60 for everything if I remember correctly
tokoam 10-07-2013 03:55 PM
did this in 5 mins thanks we shall see if it makes a difference. thanks
Sid3wayS 10-07-2013 06:08 PM
It does. Especially here in s.fla where the coldest day is like 50* Hot ass coolant is the last thing we need on the tp.
Dmurray06 10-07-2013 06:57 PM
Lol at 50*
I remember when it was 50* here.
Sid3wayS 10-07-2013 07:40 PM
Originally Posted by Dmurray06 (Post 2287343)
Lol at 50*
Dude 50* here and everyone is wearing layers and bublejackets.
Dmurray06 10-07-2013 07:54 PM
Lol....I would prolly run around naked at 50*
tokoam 10-07-2013 10:00 PM
yep that's the god to honest truth but to be honest im looking forward to the winter kinda tired of this heat.Also its fun to drive when its cold out :flowers1: ..........
Page generated in 0.18141 seconds with 11 queries
