 Old 10-31-2008, 01:55 PM   #1
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
Default TRZ tranny mount I HAVE ONE !!
my impressions so far.....
WOW...AMAZING !! i thought when i got the lower mount i had a solid driveline, well trust me it got WAYYYY better. the engine/tranny stability now is rock solid. even my every day normal slow driving has improved. i have never been able to consistanly shift this car smoothly. now with the side mount it is smooth as glass ! you can actually feel the clutch working now. and there is no lash in the driveline. vibration was surpisinlg minimal. between this and the TRZ poly lower mount i expected it to be HARSH, but it really isnt at all. easily daily driveable. although the vibration is minimal there are many more sounds/ noises to be heard now. you can hear how mutch these wonderfull mazda clutches chatter when at idle, you can hear the clutch disk grab and release as well as feel it in the pedal. the most noticable noise though is the gear whine. the faster you go the louder it gets. never to the point it is unbearable but its sure there. the reason is simply because that big fat sloppy rubber mount that was absorbing all this is no longer there. i love it. it is a whole new car to drive at this point.
i got a pic of it partially installed for you guys. it is typical TRZ....a very basic UNBREAKABLE design. it also uses a THICK ASS washer as a failsafe. if by some miricle the bushing fails there is a solid steel plate waser that is under the bolthead that will prevent the engine from dropping to the ground.
look............
TRU-BOOST is offline   Reply With Quote
The Following User Says Thank You to TRU-BOOST For This Useful Post:
karl-hungus (03-28-2009)
 Old 10-31-2008, 01:58 PM   #2
FCmaniac's Avatar
Posts: 330   (View Stats)
FCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond repute
sweet
FCmaniac is offline   Reply With Quote
 Old 10-31-2008, 02:13 PM   #3
wisniaPl's Avatar
Posts: 933   (View Stats)
wisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond repute
you hear ger whine...so now it sound like a race car :p I want one but im waiting to get one with upgraded bracket that goes between tranny and this mount....
wisniaPl is offline   Reply With Quote
 Old 10-31-2008, 02:23 PM   #4
TRU-BOOST's Avatar
i THINK TRZ will offer the tripod bracket but i am not sure. in all honesty i dont think it is needed. i know several owners have broken that part, but that is due to the stock mount. the stock mount is so sloppy and gets so much movement that it puts a lot of impact strain on that piece. once you eliminate all that slop i think that the tripod piece is plenty strong. its like removing a rusty bolt. if you apply 100ft lbs. to a ratchet by hand you will never get it loose. but if you take that same 100ft lbs. and apply it with an impact gun it will break it loose. but hey i guess it wont hurt to be safe if they do sell it !
 Old 10-31-2008, 02:26 PM   #5
Grim's Avatar
Posts: 2,395   (View Stats)
Grim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the world
would you say it is less harsh than having a trz delrin on?If so im all game for this mount.
Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW!
Grim is offline   Reply With Quote
 Old 10-31-2008, 02:54 PM   #6
TRU-BOOST's Avatar
it is hard for me to say what this mount alone would feel like or if it was used with another brand lower mount. i can say with the poly lower mount and this it feels about the same as the delrin mount when used by itself. which some think is harsh but i do not. like i said there is more noise gained, the added vibs are minimal. actually my low rpm vibrations seem to be better than before.
you can get yours soon too !! the call went in to TRZ to tell them that the fitment is perfect. it will probably be a few weeks before the first batch is ready. the plates get laser cut off of a CAD drawing made by TRZ, then they get sent off for powder coating. the last step is when TRZ gets them back. they press in the sleeves and bushings and ship them to PG !!!
 Old 10-31-2008, 07:34 PM   #7
ms3jake's Avatar
Posts: 695   (View Stats)
ms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the world
How long to install?
ms3jake is offline   Reply With Quote
 Old 10-31-2008, 08:29 PM   #8
Phantom's Avatar
Posts: 313   (View Stats)
Phantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud of
I am for sure looking at one of these.
CPE CAI|TRZ Motor Mount (Poly)|Hoen Xenonmatch Fogs/Highs |Hotchkis Rear Sway Bar|Prosport Boost Gauge|Buddy Club Condenser|18x8 OZ Ultraleggera Matte Black|Gorilla Black Lugs|G2 Red Calipers|Autoexe Stainless Steel Brake Lines|Chromium Signals|Hella Supertone|sk07 Accel Pedal|CPE DP|Cobb Shift Weight|Evo Turbo Timer|Dual AeroForce|TurboSmart BOV|Denso ITV22 Plugs|CPE HPFP|H&R Springs|Koni Yellows (Struts/Shocks)|Autoexe Street Pads|Rotora Slotted Rotors|SPC Camber Kit|CPE PNP|CPE Standback|CPE Pro Fuel Controller|Labonte Stage 1 Water/Meth Injection Kit|Tribute Oil Filter Converstion
Phantom is offline   Reply With Quote
 Old 10-31-2008, 08:57 PM   #9
kopf's Avatar
Posts: 327   (View Stats)
kopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the world
Fuck, I need to start robbing banks to pay for my parts habit...
kopf is offline   Reply With Quote
 Old 10-31-2008, 10:07 PM   #10
Strytnyne's Avatar
Posts: 214   (View Stats)
Strytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud of
lol my tranyy and clutch already makes alot of noise without one =p wonder how it would be if i got it
Strytnyne is offline   Reply With Quote
 Old 11-01-2008, 01:22 PM   #11
TRU-BOOST's Avatar
for your first time doing it...expect it to take an hour or so. i have it down to about a 15 min process now !
1) jack up the driverside of the car and support it with a jackstand.
2) use the jack to support the tranny
3) remove the battery, battery box, and ECU
4) remove the vibration damper and other bracketry
5) remove the OEM mount
then put thr TRZ mount in and follow those steps backwards !!
 Old 11-01-2008, 05:50 PM   #12
bani's Avatar
Posts: 335   (View Stats)
bani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond repute
Groans: 35
Groaned at 35 Times in 17 Posts
i'll wait for a softer mount, thanks but no thanks.
a solid piece of metal... i already have enough vibes in my car i don't need more...
bani is offline   Reply With Quote
 Old 11-01-2008, 06:07 PM   #13
TRU-BOOST's Avatar
whatever you say. you see what happens to the "softer lower mounts right....?? torn up and broken...AWR...CP-E ....SU they all have numerous documented failures. and trust me when a side mount lets go you get more than just a clunk when you drive. once that bad boy lets go your engine is in the street !
 Old 11-01-2008, 06:10 PM   #14
crazyitalian041's Avatar
Posts: 611   (View Stats)
crazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the worldcrazyitalian041 is the leader of the world
Nothing catastrophic on cp-e's...
crazyitalian041 is offline   Reply With Quote
 Old 11-01-2008, 09:37 PM   #15
wisniaPl's Avatar
i like my vibes....im feeling like driving race car:p.....but serious;y i rather have more vibes than motor on the street
 Old 11-04-2008, 01:50 AM   #16
bani's Avatar
Groans: 35
my car rattles enough, dont need more. i like to keep my fillings in my teeth, thanks.
theres ways to make mounts that arent solid hunks of metal that have non catastrophic failure modes.
 Old 11-04-2008, 02:05 AM   #17
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Well there are reasons people who race or build cars use solid motor mounts... To each their own.. ill take a solid mount with vibes than having my engine fall, causing the block and transmission case to crack.
 Old 11-04-2008, 06:05 PM   #18
boosted3's Avatar
Posts: 855   (View Stats)
boosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the world
Groans: 49
when r they shipping out.
boosted3 is offline   Reply With Quote
 Old 11-04-2008, 07:48 PM   #19
BreakTheStatic's Avatar
Posts: 280   (View Stats)
BreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant future
Oh man, I'm so on this when it comes out. I love my dogbone!
BreakTheStatic is offline   Reply With Quote
 Old 12-19-2008, 02:25 PM   #20
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Addikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the world
Groans: 157
Groaned at 29 Times in 16 Posts
I just installed mine about twenty minutes ago... man what a difference in shifting... But i have to say at first i was a little taken aback at the vibes comin through all three of my pedals but after a few minutes of beating on it up and down the road it seems to have settled in there pretty good. One quick question for you guys though, When i was installing it i could not for the life of me get the back two bolts (towards the rear of the car) to get lined up dead center in the big holes that TRZ used.... The front two were centered up fine but i tried budging it with my arm adjusting my jack position twenty seven different ways, tryin to roll the jack back some, but nothing would get those two bolts centered... I tried jackin the front of the trans, the middle, the trans and the motor, but still no luck. Do you guys think this will cause any problems its only about an eighth of an inch were talkin about so i'm not really worried but i just figured i would ask... the final position of the thing looked just like how TRU-BOOST's mount looks in that pic up there with the two rear bolts positioned in the corners towards the rear and towards the center of the car. I dont think TRZ would have used such big holes if it was really important that the mount be centered but I figured I would ask some opinions... Anyways, shifting is fucking awesome now and i think i can get to like the race car like feel.
09 MGM MS3
BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s
Addikted To Boost is offline   Reply With Quote
 Old 12-19-2008, 02:40 PM   #21
Young Roids
Lurkers
Young Roids's Avatar
Posts: n/a
You are only solving half the problem. YOu are taking out the movement of the engine but the bottom part of the mount is failing. This mount continues to use the aluminum base that is getting striped threads.
 Old 12-19-2008, 02:47 PM   #22
Groans: 157
I was pretty careful threading the bolt back into the tripod mount when installing it... I cranked down on that baby pretty good and i probably put somewhere close to 100ft lbs of torque on it and nothing got stripped. The reason people's lower part of this mount was breaking is because of the stock POS rubber mount above it not the strength of the tripod mount itself. But Ken at PG is sending me the Tripod Mount for free when TRZ finally releases it because i was one of the first ones to purchase it so I will put that one when i get it.
09 MGM MS3
 Old 12-19-2008, 02:55 PM   #23
Young Roids
Lurkers
Posts: n/a
so trz is going to make a bottom part?
 Old 12-19-2008, 03:01 PM   #24
Groans: 157
Yes indeed, according to Ken At Protege Garage, I just emailed him and asked him about a status report.
09 MGM MS3
 Old 12-19-2008, 03:16 PM   #25
Young Roids
Lurkers
Posts: n/a
That proves my point then the mount is incomplete.
 Old 12-19-2008, 03:42 PM   #26
Groans: 157
"All posts made by Young Roids are for entertainment purposes only. Young Roids is a fictitious character and all statements made do not reflect the views of the account holder."
Indeed
09 MGM MS3
 Old 12-19-2008, 04:22 PM   #27
TRU-BOOST's Avatar
The holes are fine bud. Thats why the are that big. They are a PITA to line up! As long as the studs are in there you are all good.
 Old 12-19-2008, 04:51 PM   #28
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Sweet!
You shouldn't have to jack up the car, just jack on the tranny and support it right?
 Old 12-19-2008, 05:55 PM   #29
badams118's Avatar
Posts: 821   (View Stats)
badams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the world
Groaned at 126 Times in 71 Posts
I think you are wrong. I removed the entire mount, & bolted in the TRZ. The tranny bolts to the big metal plate (the TRZ mount) which bolts to the frame. That shit is going nowhere.
2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI
Whiteline F/R Sways | SPT SSK | TWM M1 Abrams
badams118 is offline   Reply With Quote
The Following User Says Thank You to badams118 For This Useful Post:
Addikted To Boost (12-19-2008)
 Old 12-19-2008, 07:43 PM   #30
TRU-BOOST's Avatar
Originally Posted by bioevolve View Post
Sweet!
Corretamundo!
 Old 12-19-2008, 08:44 PM   #31
Groans: 157
I put mine on ramps cuz i wanted to take off the lower plastic plate thingy and used a board to distribute the weight of the trans across it...
09 MGM MS3
 Old 12-19-2008, 09:00 PM   #32
Young Roids
Lurkers
Posts: n/a
That is all the top of the mount I am speaking of the bottom aluminum hole that the bolt threads into.
 Old 12-20-2008, 12:14 AM   #33
steven88's Avatar
Posts: 773   (View Stats)
steven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the world
Groaned at 9 Times in 5 Posts
will the trz tripod bracket be real beefy?
steven88 is offline   Reply With Quote
 Old 12-20-2008, 03:39 PM   #34
TRU-BOOST's Avatar
I didnt even remove the platstic tray. I just used my jack to supprt the trans right were the lower mount connects. It worked fine.
 Old 12-20-2008, 07:12 PM   #35
badams118's Avatar
From what I could tell, that's part of the tranny case?
On a side note, I threw a couple rubber washers on either side of the mount plate. It's not night & day, but it does help with the NVH somewhat. At least you are no longer bolting metal direct to metal. You can find them cheap at Lowes.
 Old 12-20-2008, 09:13 PM   #36
Groans: 157
thats a good idea, and after about a hundred or so miles of driving now i really love this mount it feels like a totally different car. The only annoying thing is when you get into the upper rpms it really screams like a damn race car and the vibes pick up a good amount. I will give the rubber washers a try that might help a bit, and as for the tripod mount, a couple people have had them break at the track and stuff but thats because the stock drivers side mount is so damn soft and let the trans move around so much.
09 MGM MS3
 Old 12-21-2008, 02:42 AM   #37
Young Roids
Lurkers
Posts: n/a
Wrong, it's an aluminum bracket held in place by three bolts.
 Old 12-21-2008, 09:27 AM   #38
badams118's Avatar
The one the battery box bolts to? There is zero movement there; I dont see how that piece could break with the new mount.
 Old 12-21-2008, 04:37 PM   #39
Young Roids
Lurkers
Posts: n/a
the one on the left
 Old 12-21-2008, 04:52 PM   #40
Groans: 157
Yea we know which one you are talkin about, and what we are trying to tell you is that that piece is not gonna break with a solid mount on top because there is no movement like in the stock mount.
09 MGM MS3
MS3 Transmission Mount Solution!!! NEW MOUNT! ptperformance Mazdaspeed3/6 General Discussion 135 01-19-2009 02:41 PM
Tranny Mount Disected and Fixed Laloosh MazdaSpeed 3 - Engine, Transmission & Driveline 43 10-25-2008 07:19 AM
Possible bad tranny mount what do you think? Joshj84 MazdaSpeed 3 - Engine, Transmission & Driveline 25 10-20-2008 04:49 PM
Tranny mount warning! gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 12 10-19-2008 10:39 PM
Page generated in 0.55545 seconds with 36 queries
