 Old 01-07-2010, 03:48 PM   #1
speeddemon's Avatar
Posts: 128   (View Stats)
speeddemon is a jewel in the roughspeeddemon is a jewel in the roughspeeddemon is a jewel in the roughspeeddemon is a jewel in the rough
Groaned at 4 Times in 2 Posts
Default Turbosmart Dualport or HKS BOV?
Im interested in replacing the plastic piece of crap bpv on my car but not sure which is better.. which is better?
speeddemon is offline   Reply With Quote
 Old 01-07-2010, 03:58 PM   #2
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
i own both and i like the hks better! not to mention cheaper boost feels like it comes on stronger!
 Old 01-07-2010, 04:17 PM   #3
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
turbosmart - - im selling one!
 Old 01-07-2010, 04:27 PM   #4
Tripple OG
NJSPEED3's Avatar
Groans: 113
so am lol no thread yet though mine is the tb dual port one
Jdirty617 likes this.
 Old 01-07-2010, 05:14 PM   #5
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
had the ts, changed to hks. hks's sound is addicting.
xcoldricex is offline   Reply With Quote
 Old 01-07-2010, 05:26 PM   #6
Tripple OG
NJSPEED3's Avatar
Groans: 113
 Old 01-08-2010, 05:56 AM   #7
speeddemon's Avatar
is there a big difference in cost between the two... i know the HKS is for like $300 on the CP-E site that comes with their own flange.
 Old 01-08-2010, 06:39 AM   #8
Spoolme's Avatar
Posts: 1,041   (View Stats)
Spoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the world
Groans: 54
I've had zero problems with the TS bov. It's been on the car for over a year now, just converted to a FMIC and have it on there now.
Parting out!
http://www.mazdaspeedforums.org/forum/f229/spoolme-parting-out-76016/
Spoolme is offline   Reply With Quote
 Old 01-08-2010, 08:23 AM   #9
speedms6's Avatar
Posts: 825   (View Stats)
hksssss
 Old 01-08-2010, 04:41 PM   #10
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
I like the "plastic piece of crap" stock BPV. 28,000 miles. 40-100 mph in 12.5 seconds with mods below. 13.4 quarters at 107. Damn thing just won't leak. My manual boost gauge shows spikes to 20-21 psi with quick return to 17 sometimes 18 psi and hold steady right up to 5,500 shift point.
Way to many people believe the stock BPV is somehow not good. Ask Grassroots Motorsports Magazine if it leaks. They compared it to the Forge and depending on how you set up the Forge and if and only if you granny shift, the Forge permits faster recovery of boost after those granny shifts, but once the ECU stops playing nanny and you get into third gear the stock BPV actually held boost a pound to almost two pounds better than the Forge.
Not too bad for a plastic POS that just does its job without shouting out "look at me" by the way it sounds.
Just one opinion based on purely objective data.
The Following 3 Users Say Thank You to MSMS3 For This Useful Post:
ms3077 (01-09-2010), speed23 (06-13-2010), Sterling (01-23-2014)
 Old 01-09-2010, 09:28 PM   #11
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
Yeah I believe some ppl are delusional when they make claims of an after market BOV is so much better than the stock "POS". I think they're getting fooled by the cool sounds and call the stock one a "piece of shit" because it's made of plastic and doesn't look as pretty as an after market piece. I have a the turbosmart compact dual port and like it but I still don’t think the stock BPV is a POS.
Soon I’ll do some data logging to try and find out just how much of an improvement the turbosmart is over the stock bpv. So far just from my senses I believe the turbosmart recovers a bit faster between shifts and might hold a little better but we’ll see. Personally I think it’s more about the bling factor and how it sounds. I defiantely wouldn’t recommend one for the person on a tight budget as there all better bang for you buck modifications like an intake, test pipe, etc.
ms3077 is offline   Reply With Quote
The Following 2 Users Say Thank You to ms3077 For This Useful Post:
Dre (01-09-2010), speed23 (06-13-2010)
 Old 01-09-2010, 09:42 PM   #12
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
buy usedand i vote HKS
2015 Mazda 6
 Old 01-09-2010, 09:57 PM   #13
evo2ms3's Avatar
Posts: 287   (View Stats)
evo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the world
I have tons of logs showing my stocker holding 18psi+ all the way. It never really gave me a problem, I just couldnt trust it after my pos plastic one on the evo. I love the HKS sound in recirc though! Never gets old.
//Cobb AccessPORT//Cobb E-Tune@20psi//SU TMIC//Mazdaspeed CAI//HKS SSQV//RPMC Turbo Inlet//CP-E HPFP//Corksport Race Pipe//Resonator Delete//Corksport MM Inserts//TWM STS//TWM Bushings//Denso ITV22//Prosport Premium Boost//RX-8 Wheels//Kumho Ecsta XS's 235-40//Valentine One//35% Tint//TRADED IN
WW EVO X GSR//SSS//Navi//Advan Racing RS 19x10//BC Racing Coilovers//Cobb AccessPORT//Perrin 3-port/AMS FMIC//UR UICP//Works Air Filter//UR Test Pipe//Trust PE II Exhaust//Defi Boost Gauge//APR Vortex Generator//Ralliart Tails//20% Tint//Valentine One//
evo2ms3 is offline   Reply With Quote
 Old 01-10-2010, 03:38 AM   #14
matsuda's Avatar
Posts: 35   (View Stats)
matsuda has a spectacular aura aboutmatsuda has a spectacular aura aboutmatsuda has a spectacular aura about
Who told you that it was a piece of crap?
I (and many others) don't have any problems with the BPV.
In fact, I have read more than one post where someone solved a problem by replacing their aftermarket BPV with the OEM one.
If you don't like plastic valves, you'll need to replace a lot more than just the BPV.
matsuda is offline   Reply With Quote
The Following User Says Thank You to matsuda For This Useful Post:
ms3077 (01-10-2010)
 Old 01-10-2010, 03:44 AM   #15
IshiKage's Avatar
Groans: 278
i dont know why people are getting their panties in a bunch over people calling the "plastic pos bpv" a pos...it is a piece of shit.
i changed mine out right away b/c i didnt want to worry about it leaking and i wanted better sound as well as better performance/function
2015 Mazda 6
 Old 01-10-2010, 08:50 AM   #16
ms3077's Avatar
Groans: 974
Zack,
That's because it's not a "POS." Being made of plastic doesn't make it a "POS". If it functions the way it should it's a good piece. Perhaps some have experienced their stock valve leaking but for the most part it seems they’re holding up and performing just fine.
Trust me, I like the sound and how a good after market bov/bpv looks under the hood but the general consensus is that it doesn’t give a substantial increase in performance vs. the stock bpv.
If the stock BPV is a “POS” by your definition then there’s a whole lot of “POS” in this car. If the stock valve didn’t hold boost and perform the way it should then sure by all means call it a POS but this isn’t the case.
If you could provide some hard evidence to support your claim that the stock BPV is in fact a “POS” I’m all ears. Otherwise, you're just spreading bum scoop.
 Old 01-10-2010, 10:20 AM   #17
IshiKage's Avatar
Groans: 278
dont get me wrong. i didnt get an aftermarket bov for "added performance." i got one b/c i wanted to make sure my bpv was holding pressure and doing its job...thats what i meant when i said
better performance/function.
eventually the stocker will leak, so instead of waiting for it to do so, i went ahead a upgraded it.
thats why i refered to it as a "pos." i know it works, its just a matter of time before it stops working properly
2015 Mazda 6
 Old 01-10-2010, 11:53 AM   #18
darth vader's Avatar
Posts: 665   (View Stats)
We've all been on this merry-go-round before. It's not fair to say the stock valve leaks w/o data to back it up. Nor is it fair to claim the stocker "holds more boost" when, there are likely alot of uneliminated variables that can affect that, even on the same car, same day.
The problem I have with plastic pieces is that, over time, they become inconsistent in performance, as the plastic degrades and they are not tuneable. Ask any 1996 4.6 litre Ford owner how much they love plastic. Aftermarket metal valves, like Forge, HKS, TS or WHY, will probably last as long as the car, at the expense of needing a touch of periodic maintenance.
I have seen NO difference in held ultimate boost level with either a stocker or Forge. The car's no question more pleasant to drive with the Forge. The primary induction noise I hear is intake and the noise of the BPV is actually about the same, Forge v. stock. No pings, coins, swords or phased plasma rifle in the 40 watt range sounds. The intake made the BPV sound loud first, not vice versa.
Either way, if performance is at issue, as it was for me, change it out, it's only money. If it isn't, drive on and be happy.
 Old 01-10-2010, 02:26 PM   #19
speeddemon's Avatar
Is the HKS a better BOV than the turbosmart dualport? the HKS is obviously a full recirc, the turbo smart can run full recirc or 50/50. Im not sure if the stocker is a full recirc or its a 50/50
 Old 01-10-2010, 03:57 PM   #20
IshiKage's Avatar
Groans: 278
wrong. the HKS is a 50/50 too
2015 Mazda 6
 Old 01-10-2010, 04:10 PM   #21
OMGWTFHAX's Avatar
Posts: 445   (View Stats)
OMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the world
Groaned at 26 Times in 25 Posts
I dont know if the stock BOV is shit or not but I do like the sound of my HKS over the stock.
Where can the HKS vta if setup up for recirc? I think you might need to check your facts because I cant see how it would be able to vta unless it was setup for it.
Flickr
Originally Posted by Andrew85 View Post
Wow kid... how about LOL @ you for being a piece of garbage without a purpose in life. For one thing, im not really bragging, just sharing an experience. Another thing is that you like men and your opinions dont count cause you take it up the poop shute.
OMGWTFHAX is offline   Reply With Quote
 Old 01-10-2010, 05:31 PM   #22
IshiKage's Avatar
Groans: 278
it vtas from the same outlet the recirc fitting is sitting. just dont attached the recirc hose.
and i need to correct myself. i didnt mean to say its 50/50. i meant to say is runs almost like a 50/50. i have a couple friends with MS3's running their SQVV's VTA and dont have any probs stalling. i tried running my Type S in VTA and the car wants to stall immediately, pops violently and runs liek shit. theirs dont
2015 Mazda 6
 Old 01-10-2010, 07:59 PM   #23
OMGWTFHAX's Avatar
Thats what Im saying, if its set up for recirculation (IE recirc hose attached) then it physically cant vta.
How's it run almost like a 50/50? Its either full recirculation, or full vent to atmosphere.
Flickr
The Following User Says Thank You to OMGWTFHAX For This Useful Post:
ms3077 (01-10-2010)
 Old 01-10-2010, 09:13 PM   #24
ms3077's Avatar
Groans: 974
Got this info from Street Units site in ref to the TurboSmart BOV
Benefits of the TurboSmart BOV Kit over ALL other BOV kits:
•Recirculates under light boost/normal daily driving conditions
•VTA and recirculates under high boost conditions or compression surge
•BOV spring rate is tunable to the vacuum of your car
•No stalling or backfiring when adjusted properly
•3 in 1 BOV: VTA in tandem with Recirculation (recommended), 100% Vent to Atmosphere, or 100% Recirculation
•Holds more boost over stock valve
•Increases drivability and responsiveness
•Get the BOV sound of a VTA setup with all the benefits of a recirculation setup
•Recirculation helps maintain proper A/F Ratios
•Gain Top End Horsepower
-I've had mine installed for just about 1 week and I'm really liking it!
The Following User Says Thank You to ms3077 For This Useful Post:
kairojya (07-14-2012)
 Old 01-10-2010, 11:24 PM   #25
IshiKage's Avatar
Groans: 278
it can physically VTA. its not rocket science. IE DONT attach the recirc hose and its running VTA. its not that hard
and read what i said about how its runs like a 50/50. running 50/50 keeps the car from popping, bucking and stalling. a couple of the MS3 guys here in orlando with HKSs are running VTA and have none of these probs. when i try running my Type S vta. the car pops violently, bucks like a stallion, stalls like crazy, and exhaust smells terrible
here is a pic. see the black recirc hose? ok, disconnect it and the bov is now running VTA.
2015 Mazda 6
 Old 01-11-2010, 12:04 AM   #26
OMGWTFHAX's Avatar
Youre seriously fucking retarded. Ive been saying this whole time if it's set up for recirc, IE the recirc hose is connected, then it cant VTA. If you dont have the hose on there, then yes it will VTA. Go back and read my posts slowly, and work on your reading comprehension. You keep acting like Im wrong but you repeat EXACTLY what Ive been saying.
Flickr
 Old 01-11-2010, 12:41 AM   #27
IshiKage's Avatar
Groans: 278
again, the confusion came into play when i said the hks is 50/50. then i said i needed to correct my self, that i didnt mean to say the HKS was 50/50, rather that it performs almost like a 50/50 being that i have a couple friends running in VTA(on their MS3s) but their cars do not stall, pop, buck or smell. the way mine does when i try running VTA. the Type S doesnt functions as well as the HKS when running VTA
so i apologize. i assumed you were confused on recirc'ing and vta'ing. and didnt think the HKS could run VTA at all
2015 Mazda 6
 Old 01-11-2010, 12:44 AM   #28
OMGWTFHAX's Avatar
Im honestly surprised you didnt explain to me the difference between setting up for VTA and setting up for recric again.
Flickr
 Old 01-11-2010, 12:48 AM   #29
IshiKage's Avatar
Groans: 278
i eventually would have b/c i assumed you were confused on recirc, vta and thinking the hks couldnt vta at all.
so that was my bad
2015 Mazda 6
 Old 01-11-2010, 01:37 AM   #30
BoostedBlack6's Avatar
Posts: 261   (View Stats)
BoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond reputeBoostedBlack6 has a reputation beyond repute
I have the Cobb XLE and it is nice. I have had both and prefer the Turbosmart above everything I have had. Wish I hadn't sold mine but I like my Cobb as well. Plus it iz the rareness.
2006 Black Mica MS6: Cobb AP, Stage 2 v105 93, MSD Dashhawk, Speedie6 TIP, CPe Nano SRI, HKS SSQV, Custom FMIC, Custom 3" Single Exhaust w/ Dynomax Race Muffler, H&R Sport Springs, SPC Adjustable Balljoints, TWM Stage 2 Short Shifter w/ SU bushings, 18" Drag DR-34s
BoostedBlack6 is offline   Reply With Quote
 Old 01-11-2010, 02:16 AM   #31
IshiKage's Avatar
Groans: 278
by the way OMG,
how loud is your HKS in recirc. i havent heard one run in recirc yet
2015 Mazda 6
 Old 01-11-2010, 02:47 AM   #32
OMGWTFHAX's Avatar
Its pretty loud. You can really hear it on the outside even in recirc. I can hear every little thing on the inside though because I have the cobb fmic, cobb inlet, and aem intake. Shit amplifies every noise. Its great.
Flickr
 Old 01-11-2010, 05:04 AM   #33
speeddemon's Avatar
But if you would run the HKS or any other BOV in VTA, arent you losing power? Running VTA makes a great sound but id rather make more power than to have a nice sound.
 Old 01-11-2010, 05:07 AM   #34
OMGWTFHAX's Avatar
You dont make anymore power with a new BOV, no matter how you look at it.
Flickr
 Old 01-11-2010, 05:18 AM   #35
speeddemon's Avatar
ok, i have just been hearing all this crap how the plastic stock one leaks and will hold more power with a better quality bov only in full recirc.
 Old 01-11-2010, 05:21 AM   #36
OMGWTFHAX's Avatar
Look, get a new BOV if you know that yours is leaking. If you arent sure if yours is leaking, then just say youre getting one because you want a cool sound when you shift.
You'll find just as many posts saying the stock BOV is good as you will saying its bad. In the end, its your money and you know what you want or need.
Flickr
 Old 01-11-2010, 05:29 AM   #37
speeddemon's Avatar
Im not sure if its bad or not. this is my first turbo car so all this is new to me. Im still learning so dont get upset because some things dont make sense
 Old 01-11-2010, 07:42 AM   #38
Police
ganque's Avatar
ganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the world
i have a question.
How is the best way to tune the Turbosmart BPV? I've read that the key is the noises and backfire, but:
a) What kind of noises are those? (vids?)
b) Do i have to do the tests while running the car or stopped completely?
SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQ
SOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW!
MS3 vs Focus ST vs Camaro LS1 ---> Click here
TEH MEXICAN'T PERM!
Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes
ganque is offline   Reply With Quote
 Old 01-11-2010, 08:29 AM   #39
OMGWTFHAX's Avatar
Who's upset?
Flickr
 Old 01-11-2010, 08:43 AM   #40
IshiKage's Avatar
Groans: 278
the way you tell is to get a boost gauge in you car so see if your bpv is holding stock-target boost levels.
if you see that it is isnt. make sure all couplers are tight then check again. if they are, its probably the stocker leaking.
there wasnt a change in sound when you added FMIC? once i installed my front mount, my Greddy Type S doesnt have that "type s" sound anymore.
but, the sound is close when shifting under full boost with the FMIC and like whooshing air under reg boost. on the other hand, when i had my stock TMIC, the type s made that "type s" sound under reg boost but whooshing air sound under fulll boost. WTF?
but i want to get a HKS, since Type S's have diaphragms whicch leak, eventually
2015 Mazda 6
Last edited by IshiKage; 01-11-2010 at 08:53 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to IshiKage For This Useful Post:
XerocX (02-24-2014)
Turbosmart BPV redblur 2010 MS3 - Engine, Transmission & Driveline 31 09-07-2011 12:55 PM
turbosmart bov blackmsp3 487 MazdaSpeed 3 - How-To's 12 01-17-2010 01:37 PM
new turbosmart bpv to come boostedminime MazdaSpeed 3/6 - Turbo Induction 16 04-11-2009 11:05 PM
Page generated in 0.55648 seconds with 34 queries
