 Old 02-19-2009, 05:28 PM   #1
k0m
k0m's Avatar
Posts: 134   (View Stats)
k0m has a spectacular aura aboutk0m has a spectacular aura about
Question under serious consideration
hey all,
quick question but a very important one, at least in my opinion. when exactly should you "tune" your car? i recently installed a re-worked turbo in my car and ive noticed some boost cut every now and then when i get on it and the car doesnt feel as strong as it use too. is that because the ecu cant compensate for all the added air flowing thru the cai, ported and polished turbo, downpipe, and cbe? if so does that mean i need to purchase a standback or some other form of tuning? also i plan on goin to an upgraded tmic which would again increase airflow.
thx for any suggestions
k0m is offline   Reply With Quote
 Old 02-19-2009, 05:38 PM   #2
oskinosmee's Avatar
Posts: 743   (View Stats)
oskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant future
If you dont have a fuel pump your asking for trouble
Gotta Love The Turbocharged Wagon
oskinosmee is offline   Reply With Quote
 Old 02-19-2009, 05:39 PM   #3
Buildabong's Avatar
Posts: 3,034   (View Stats)
Buildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the world
Groans: 213
Groaned at 274 Times in 187 Posts
zoom zoom boom coming for ya!
Buildabong is offline   Reply With Quote
 Old 02-19-2009, 05:40 PM   #4
phailerider's Avatar
Posts: 4,639   (View Stats)
phailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the world
Groans: 49
Groaned at 179 Times in 125 Posts
your next mods should be a standback and a fuel pump. then you should feel safe to start your car up again. until then, give it a nice car wash and enjoy it in the driveway.
phailerider is offline   Reply With Quote
The Following User Says Thank You to phailerider For This Useful Post:
gsrtype1 (02-27-2009)
 Old 02-19-2009, 05:40 PM   #5
oskinosmee's Avatar
LOL pretty much
 Old 02-19-2009, 05:41 PM   #6
Buildabong's Avatar
Groans: 213
or internals then standback...
 Old 02-19-2009, 06:54 PM   #7
k0m
k0m's Avatar
wow ok...not what i was expecting but ok...is it because of the turbo? cai? tbe? or all of them put together? could i remove say the cai until i purchase the stnadback and hpfp? also should the pump come first before the standback? i had heard that just the "internals" from PG werent recommended and that the cpe fuel pump wpuld be the better way to go. true?
 Old 02-19-2009, 07:00 PM   #8
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
I never understood the people upgrading turbos before covering the basic stuff....
Carry on citizens....
10.7 @ 133 auto 1G DSM
The Following 2 Users Say Thank You to Darksun280 For This Useful Post:
bf360 (02-20-2009), phailerider (02-19-2009)
 Old 02-19-2009, 07:00 PM   #9
Groans: 49
Issue is the bigger turbo my friend... 100%. guys with tbe and increased boost on the stock turbo, and stock pump run the risk of blowing the fuck up, ESPECIALLY if they are untuned. youre 100% gonna blow with the symptoms youre already describing. 100%... it could happen tonight. do not boost your car agin unless you want to see a hole in the block.
on the fuel pump question, i wont weigh in on the "better way to go", because i sell one of the options... but yes, a fuel pump is the next step. then if not a tune, definitely get a meth kit to go along WITH the cdfp. a standback and a dashhawk is MANDATORY with a bt in my opinion. the only other option is to drown it in meth untuned. run 9's a/fs if you want to be "safe".
removing the cai is not the next step.... 15 psi is the next step. do not raise boost until you do something along the lines of the above.
trust me on this.... the odds of blowing with a bigger turbo on the oem fuel pump is gauranteed. I know of NOBODY who has pulled that off successfully. not if they raised boost, and didnt take these other measures.
 Old 02-19-2009, 07:45 PM   #10
k0m
k0m's Avatar
ok i think there is some sort of misscommunication here. i DID NOT go to a bigger turbo. I replaced the stock turbo with another STOCK REWORKED turbo from PG. i have NOT upped the boost at all. the ecu has been controlling that the whole time. I have only seen it spike once or twice. i have only experienced boost cut 3 or 4 times.
 Old 02-19-2009, 07:50 PM   #11
JimmyMac's Avatar
Posts: 558   (View Stats)
JimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the world
Tune as you add mods or make changes to your car. My very first mod to the car (besides lighter wheels) was an XEDE. This covered me for each and every thing I added to the car afterwards. Since then I've moved on to a Standback, but my car has always had a tuning solution since day one of modding. Fuel pump was added when it first became available. That should be at the top of everyone's list when modding as well. And as Randy has said, get a dashhawk or something that you can monitor your engine vitals.
2012 MX-5 SE
JimmyMac is offline   Reply With Quote
 Old 02-19-2009, 07:52 PM   #12
Groans: 49
a well done reworked stock turbo is a BT. Like i said... untuned, raised boost, oem fuel pump = boom.
you raised boost with the bigger turbo, and your car is letting you know with the stumble. i wouldnt be surpriosed if your fuel pressure were dipping below 1000psi right now, and youre not even aware. are you datalogging?
did you talk to Ken about this?
 Old 02-19-2009, 07:57 PM   #13
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
With a reworked turbo you wontb EVER need a tune. I've been running around like that for months now. I am am fully bolted on a stock block with a big k04 and 20psi all day long. Get the fuel pump internal from PG and go to town. If you want more boost run a MBC. It works fine.... Hell it got me in he 12's with basic bolt ons last year. I would suggest the ecu flashes from cpe to get throttle control and stop all that BS throttle cut.
TRU-BOOST is offline   Reply With Quote
 Old 02-19-2009, 08:05 PM   #14
fbpem1's Avatar
Posts: 1,159   (View Stats)
fbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the world
Groaned at 47 Times in 40 Posts
i dropped to 500psi today and kept my foot in it to see what it would do it just kinda stopped moving...my motor won't blow...WHY!? lol
fbpem1 is offline   Reply With Quote
 Old 02-19-2009, 08:08 PM   #15
k0m
k0m's Avatar
the only data logging i have done was i went to go get a dyno done the other day. i did it just to make sure my a/f ratios were ok and i wasnt running to lean. it started out at 14:1 and dropped all the way to 8:1 at the 6krpm range. not sure if that means anything. no i have not talked to ken about it.
 Old 02-19-2009, 08:46 PM   #16
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
subparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the world
Groaned at 6 Times in 6 Posts
15 psi on stock turbo does not equal 15 psi on reworked turbo. Why? The compressor map has changed (albeit not by a whole lot)
Its not just about the pressure in the system, its about the amount of air that is being moved through the system, whoever said "reworked turbo is like going with a bigger turbo" is pretty much right.
You NEED a fuel pump. For sure.
You might be OK without a tune... but let me just say that the difference between a car with the reworked turbo tuned vs untuned is night and day.
I've been pretty pessimistic with my reworked turbo until recently. I've FINALLY gotten the thing running right and its a monster now. Do yourself a favor and pickup a fuel pump, a meth kit and some way to tune with it all.
2006 Lotus Elise: Toy car
1999 B4000: DD / Parts hauler / SC Project
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
subparpunk03 is offline   Reply With Quote
 Old 02-19-2009, 10:00 PM   #17
k0m
k0m's Avatar
ok well i def appreciate all the help i guess ill put in an order with su for a standback and cpe pump tommorw...another 1500 bucs...nice :/
 Old 02-19-2009, 11:17 PM   #18
NEC
you are doing the :/ now but after you install you will be doing:
zomg doodz! this is the schniznoz! For realz homieguys! lol11!
car won't cut and you'll be having issues getting traction in third gear. Its worth the money.
 Old 02-20-2009, 10:15 AM   #19
Groans: 49
uh.... it wont be 1500 bucks ordering it through me man. not close.
 Old 02-23-2009, 06:39 PM   #20
k0m
k0m's Avatar
ok well i got the dashhawk and attempted to do some datalogging. i put all the pids i wanted to monitor and off i went. the 2 things i was mainly looking for was afr and fuel pressure. when i pulled up the log on the comp though it didnt show any of what i thought it was recording. is there a way to change that? i did notice that when @ wot fuel pressure was right 1800. would that indicate i have enough fuel?
 Old 02-23-2009, 10:38 PM   #21
meatball84's Avatar
Posts: 17   (View Stats)
meatball84 is an unknown quantity at this point
good luck dude
CP-E Catted Downpipe, MAZDASPEED Cold Air Intake, RPCM Turbo Inlet, HKS SSQ Blow Off Valve
meatball84 is offline   Reply With Quote
 Old 02-24-2009, 09:18 AM   #22
martyxattack's Avatar
Posts: 924   (View Stats)
martyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the world
Groaned at 37 Times in 27 Posts
you realize you need to know how to tune once you get the standback right. i just dont understand going out and getting something like a reworked turbo and not knowing you should be tuning for your mods
martyxattack is offline   Reply With Quote
 Old 02-27-2009, 01:50 PM   #23
k0m
k0m's Avatar
yes ty i realize i need to know how to tune. i figure with the help of datalogging from the DH and the standback jordan can try and create some custom maps. im also taking it to a local shop here that knows how to tune with the SB.
 Old 02-27-2009, 02:03 PM   #24
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Get the Standback and a dashawk ASAP and tune your ride for your mods. And yeah you will ned a fuel pump as well.
 Old 03-02-2009, 04:23 AM   #25
wassup61's Avatar
Posts: 1,232   (View Stats)
Groans: 29
Hey OP,
You definitely need a fuel pump with those mods. I also STRONGLY suggest a data monitoring device, the most user friendly being the Dash Hawk. You may or may not want to consider a tuning solution, but the best for your mods would be a CP-E Standback V2.
PM or email me msfprotegegarage@gmaill.com
For the best deals on the above parts,
-Jeff at PG
All wagon, No traction
Holden Commodore hybrid and turbo'd four under consideration Haltech Automotive News 0 05-19-2008 08:40 AM
Holden Commodore hybrid and turbo'd four under consideration Haltech Automotive News 0 05-19-2008 06:11 AM
Page generated in 0.44805 seconds with 32 queries
