 Old 07-03-2013, 05:02 PM   #1
dannyboy1234's Avatar
Posts: 244   (View Stats)
dannyboy1234 has a reputation beyond reputedannyboy1234 has a reputation beyond reputedannyboy1234 has a reputation beyond reputedannyboy1234 has a reputation beyond reputedannyboy1234 has a reputation beyond reputedannyboy1234 has a reputation beyond reputedannyboy1234 has a reputation beyond reputedannyboy1234 has a reputation beyond reputedannyboy1234 has a reputation beyond reputedannyboy1234 has a reputation beyond reputedannyboy1234 has a reputation beyond repute
Default Valve cleaning at 91k miles...
Pulled the intake mani of today and blasted those valves using this method:
HOW TO: Clean your valves - easy & cheap
Deviations from above procedure:
1) The 1" ID tube got in the way so I didn't use it the way it was used in the above procedure; Just held it close to the gun. Got walnut all over the place but whatever - worked really well.
2) had to soak twice and blast a LOT due to the fact that this has never been done and the carbon build-up was crazy.
3) Used a dentist pick to get the tough spots around the stem and seat (I highly recommend this)
Took me all day because I've never removed the intake mani before and the valves were in really bad shape. Luckily I had a friend help with removing everything and putting it back together. I also installed a JBR SSP and a forge v2 bpv. I cleaned the EGR tube and valve as well because I don't have it blocked off unfortunately.
Initial Impressions:
The car feels so much smoother and feels like it pulls harder at high RPMs. SSP is awesome and I really like the forge BPV. Learned a lot and definitely glad I did all of this. I went on a 180 mile trip after and nothing blew up, no CEL, and no parts falling off on the highway!
EDIT: Sorry if some pics show up sideways.
08' BM MS3 GT- Cobb SRI + TIP, Magnaflow CBE, CP-E RMM, Forge BPV v2, JBR SSP + bushings
dannyboy1234 is offline   Reply With Quote
 Old 07-03-2013, 05:06 PM   #2
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Pics of after would've really helped... good job doing it yourself though.
 Old 07-03-2013, 05:06 PM   #3
ms6mil's Avatar
Posts: 4,972   (View Stats)
ms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the world
Groans: 307
Groaned at 6 Times in 6 Posts
Nice, I did the same thing with the stupid clear tube. It just got in the way.
"Here am I. Send me!"
____________________________________________
Columbus, GA 2006 MazdaSpeed 6
EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel
GT3076 - 393/380 3/9 e85
GT3076 - 426/400 E85/DO10 Meth
PTE5862 - TBD
ms6mil is offline   Reply With Quote
 Old 07-03-2013, 09:03 PM   #4
There is a pic of after... That's why the image is titled "clean valve"
Sent from my iPhone using Tapatalk 2
The Following User Says Thank You to dannyboy1234 For This Useful Post:
Agent_Orange (07-03-2013)
 Old 07-04-2013, 12:20 AM   #5
hnda etr's Avatar
Groans: 90
Sorry, not seeing titles in your pics, but I'm using tapatalk so maybe they dont show..
Sent from my giant i317 Pocket Monster
 Old 07-12-2013, 12:21 AM   #6
rolanblack's Avatar
Posts: 2,110   (View Stats)
rolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the world
For 91k on it, does not look bad at all. Seen 35k pu with a cone of carbon.
rolanblack is offline   Reply With Quote
Valve Cleaning at 91k miles dannyboy1234 MazdaSpeed 6 - Engine, Transmission & Driveline 3 07-01-2013 04:51 PM
valve cleaning soon, what else should i do dan7225 Mazdaspeed3/6 General Discussion 25 07-31-2012 04:42 PM
Valve Cleaning beachshoer Gen2 MS3 General Discussion 16 07-08-2012 07:43 PM
20k + miles inspection after valve cleaning dooderek Mazdaspeed3/6 General Discussion 20 02-09-2012 12:42 PM
Page generated in 0.27902 seconds with 24 queries
