![]() | | #1 | ![]() |
![]() Join Date: Apr 2012 Location: Plainfield, IL
Rep Power: 193 ![]() Thanks: 52
(Thread Starter) | Not Ranked : 0 score I've went front mount so I bought Vht wrinkle black to do the VC with. The super black was extremely strong, almost too strong (on my probe I had to beat the oil pan off it was so glued on, and pry it every which way to the point of damaging my oil pan just to get it off, luckily I had an extra).
__________________ 2009 Mazdaspeed3 GT Cobb SRI E4P Short Throw shifter |
Rep Power: 6865 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,516
Groans: 39
Any oil resistant rtv is ok, it isnt under pressure or submerged in oil. Just be sure to apply it as per the instructions because different rtv sealants have different instructions and most people apply them all the same way.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant |
| The Following User Says Thank You to 06Speed6 For This Useful Post: | helmetface (09-04-2012) |
Ok, sounds good. I might not get the super black again because it was literally almsot impossible to get my old oil pan off, and i don't want that to happen to my valve covers. Ill grab some regular permatex black oil resistant rtv!
| oil control valve gasket?! | crystalwhitespeed | Mazdaspeed3/6 General Discussion | 3 | 08-30-2012 07:41 PM |
| High pressure rail releif valve and IM gasket | oh_yeams6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 10-11-2011 08:32 AM |
| Diff cover gasket? | rob ms6gt | Mazdaspeed3/6 General Discussion | 2 | 01-16-2011 06:42 AM |
