-   -   Valve cover oil leak (http://www.mazdaspeedforums.org/forum/f10/valve-cover-oil-leak-168438/)
Jinba Ittai 04-12-2014 02:50 PM
I've search this forum and can't find this simple question, does the valve cover come off this car with just removing the bolts, I tried and failed due to the fact that it got caught up by the fuel pump. I have to replace the gasket because it's leaking, I hope I don't have to remove the fuel pump just to change a simple gasket.
Amnesiac 04-12-2014 03:12 PM
Yes, just take off the bolts. You don't have to remove the fuel pump.
Jinba Ittai 04-12-2014 06:48 PM
Thanks I appreciate the response!
alphasaur 04-12-2014 07:12 PM
wat
afaik, hpfp needs to come off.
Amnesiac 04-12-2014 07:15 PM
Nope, not for the valve cover. Just changed the gasket on mine 2 weeks ago and didn't touch the hpfp.
alphasaur 04-12-2014 07:18 PM
http://076dd0a50e0c1255009e-bd4b8aab...nal/original.0
Jinba Ittai 04-12-2014 07:42 PM
ok, what's the hpfp anyway, I hate acronyms sometimes, especially when I don't know what wtf they mean..
Amnesiac 04-12-2014 07:56 PM
high pressure fuel pump
Jinba Ittai 04-12-2014 08:03 PM
ok, same as the fuel pump just an extra word, same unit I was talking about. thanks!
alphasaur 04-12-2014 08:07 PM
"fuel pump" typically refers to the pump in your gas tank. Hpfp refers to the cam driven high pressure fuel pump.
Jinba Ittai 04-12-2014 08:16 PM
Thanks, do you have to shimmy the cover off, pry it out, it didn't want to come off.
Amnesiac 04-12-2014 09:35 PM
I did have to pry it up
Page generated in 0.17785 seconds with 11 queries
