Anyone ever run Liquidmoly 5w-40 |
I priced some T6 today and was very surprised at how reasonable it was, However after reading all that I am clear as MUD! lol Kinda dont matter how many threads you read - There is No One oil that all agree on... SO I guess I will wing it - Play it by ear - and stick with some recommended synthetics and see what one i like after I try a few |
Another I'd like to try is redline but its pretty spendy. I see motul has this ester based stuff but don't see it available for a reasonable price anywhere either. https://s3-eu-west-1.amazonaws.com/m...png?1409560151 |
With the exception of the 4600 mile change, this was all with SuperTech conventional. I switched over to M1 15-50 synthetic for one change when it was on sale. It did hold its viscosity a little better, otherwise a synthetic isn't anything impressive in terms of wear metals. I have another 10k miles on the engine at this point, it's probably about time for another UOA. Remember that this car is autocrossed twice/month with 200+ runs per year. We turn 7500 rpm at nearly every autocross. It's also been on a road course with the same oil, nbd. The real advantage to a synthetic is its ability to have 2x or longer life than conventional. If you plan to run short changes (~4k miles or less), it doesn't make any sense to run a synthetic. Once you start to push into the 6k+ miles range on an oil interval, you're starting to see some cost benefit. http://i64.photobucket.com/albums/h1...psit1hxksz.png |
Thanks for the post, @phate |
1 Attachment(s) I use Redline 5w-30 right now. I used 0w-40 for two changes thinking it would protect and flow better but switched back to 5w-30 now... not sure if my thinking was sound or not... Works great, never ever burned/consumed oil and I am at 41k... but like everyone else has said you dont need it... I just use it for peace of mind (at a high price I might add) |
Honestly a very interesting read with how often people raise their pitch forks at the idea of anything but Rotella. And just goes to show, its a fucking car engine it just needs oil. Yes better oil is "better" but within the < 3-4k oil change time frame the engine is just starting to break it down but not enough to matter. Wont change what I run but a good food for thought. |
But it's DI, it has cats, it runs pretty darn hot while the cooling approach and crank case and valve cover ventilation are not the best in the industry, and the higher and higher concentration of ethanol in the fuel blends (pump gas or E mixes done by the owner) makes choosing the right oil a lot harder. I know it should be simple but it's not. |
I am at 182k on original turbo. I think it might be going but not sure. For the past 20k I have been on an partial e-85 mix but might be coming off of that since ill be moving and wont be able to store gas cans I think. Since 148k I have been using rotella t6 and changing it between 3-4k depending on how I have been driving. |
HOWEVER - after reading the responses here, understanding that out stock turbo's seem to do better on 5w40, and after pricing the T6 (which is very reasonable imo). I have decided that T6 will be the Oil I use on my MS3 from now on. Previous owner used Castrol 5w30 synthetic from day one till he sold it to me. The turbo dose smoke a little but he said its gota be sitting at idol for a LONG time b4 it dose it. He also waited about twice as long as I think you should between oil changes- sooo .... This thread has bin a great read with great responses, Thank you all very much |
Usually smokes after like 15-20min I think at idle. The only real way to make sure you intervals are correct are to do Blackstone labs which i am t lazy to do. I have always done oil at 3-4k even on the car I use to own. The t6 is thicker(40 instead of 30) when warm which usually helps prevent smoky turbo. |
Although, After cleaning the TB and the EGR port's in the Intake Friday, My check engine light went away yesterday lol. Go Figure, and I already have all the new parts ordered and paid for... |
I'm probably missing something here but I never understood how the banjo bolt is a 'fix' when in theory it's just starving the turbo of the oil it needs. |
Raise ur idle bruh |
I may get an AP one day, however - i can promise you that i would not buy it for the sole purpose of going from 800 to 900 RPMs at idol...... lol |
What do u have now? Just an intake + stock tune? |
However, once i get passed all that, an AP and HPFP internals are probably what i will be looking into =) |
The stock tune blew infinitely more cars compared to mild stage1-like tunes. It has a lot to do with the stock tune aggressiveness to save fuel and run as efficient as possible, and it's stubborn enough to want to keep the AFRs lean, VVT and advance timing high even during mild spool-up. This is one of the possible reasons for low speed pre-ignition which blew cars cruising on highway, off boost, just during a gear change or something. Get yourself an AP or the Versatuner. You can get an used AP v2 which are cheaper these days. Hell, even a hypertech would be a lot better than the stock tune. |
From what I've seen, Mobil1 is $22/5qt jug at walmart or Amazon, and Amsoil 5w30sig is $11/qt at Napa or online. |
The local salvo auto parts has both for $8.50 a quart. Mobil 1 may have come down in price but its not worth any price premium over dinosaur oil. |
| All times are GMT -7. The time now is 08:07 AM. |
