vroom vroom BOOM!? i heard about boosting at 3k rpm cause the rods to wear prematurely causing the motor to blow. anyone else heard about this happening? |
hahahaha get the fuck out of here .......................... |
Paint my balls GTFO |
i reallllly wish i was kidding, this happened to a friend of mine |
just never go into boost its the only safe way to drive the car:blowjob: |
If you have to ask..... just search...searching is your friend...hell usually just ask another speed owner |
I've never heard that. Thanks for the warning. |
i hear that every speed has a built in life counter,so basically when you get into boost its like playing mortal kombat and having goro punch you in the face |
I'm glad i am now informed of this ... It's a shame no one knew this before tonight, could have saved a lot of people's cars .... :hitwithrock: |
is your friend retarded ? |
amateurs tuning and messing with atr makes a car go boom. not taking car of your car makes a car go boom |
I normally WOT @ 2500rpms in 5th and 6th gear for optimal "fwd thrust". Try it. |
http://yoyodawgdawg.com/pics/yo-dawg-the-original.jpg |
http://thechive.files.wordpress.com/...if?w=330&h=256http://thechive.files.wordpress.com/...if?w=330&h=256http://thechive.files.wordpress.com/...if?w=330&h=256http://thechive.files.wordpress.com/...if?w=330&h=256 |
im not quite sure how to take that last post, maybe it was just him, has everyone in my area against the speed6s though..lame |
dont listen to these guys, the key is flooring it always....... if u maintain enough momentum on the rotating mass of the engine there is absolutely zero danger. think of it like a rubber band,....as long as u keep stretching it back and forth it stays healthy... the second u just cruise and dont go WOT the parts stale out and soon enough boom |
:spammage: |
i just put my MS3 in "1" and frive what are these RPMs you're talking about? |
my balls itch |
how to drive your fucking car: 1) common sense saves. 2) boost when NEEDED. 3) these don't mix: low rpm, high gear, and boost. 4) open your glove box for more air flow. 5) always honk your horn 3-5 times at start-up that way you are releasing excess pressure from your blow-off valve. you don't want to stress your blow-off valve. 6) putting a used condom filled with jizz on your tailpipe WILL NOT add 5 hp. |
I have 73k miles fully bolted boosting up to 22-23psi on stock ko4. i am not kidding, i live it |
Ok, so I know I'll probably get raped for saying this, but... The poor SOB is probably just new here, is new to a boosted car, and is asking a question because he wants some info. Yes he could have searched around a little and found this out, but he is new and didn't realize it. I'm basing all this on him being new. I hope he is, or my point is shit. Using Tapatalk so I can't tell. So anyway, yeah. Boosting at low RPM's is bad. Done. Jesus. |
Ha! :-) |
| All times are GMT -7. The time now is 07:59 AM. |
