Like Tree2Likes
  • 2 Post By blackmica6
 Old 12-18-2019, 08:44 AM   #1
blackmica6's Avatar
Posts: 11   (View Stats)
blackmica6 will become famous soon enough
Default VVT "C" revision vs DCR VVT
So, I've been reading quite a lot on the VVT issue with this car, but I can't find a definite answer. Did the last revision "C" (L3K9-12-4X0C) VVT actually solve the VVT problem or does the pin cap still break off with time & does the hole where the pin engages get elongated (and therefore the VVT fails)?
Also, the DCR VVT seems to be the solution to this problem, but it is $350, which is too much for what seems to be a modified OEM VVT. Has anyone ever disassembled the DCR VVT? How is it modified? Can we modify an OEM VVT to be as good as the DCR one?
From what I understand, they've removed the button (cap), threaded in an allen head screw in its place, put a stronger spring between the pin and the screw and made the hole in the rotor where the pin engages a bit deeper. That's either hardly worth $350 or I am missing something completely.
What do you guys think?
Stock 2006 MS6 - daily driven
blackmica6 is offline   Reply With Quote
 Old 12-18-2019, 02:29 PM   #2
Jeff23spl's Avatar
Posts: 2,198   (View Stats)
the revised model seem to work for many. I don't think much second gen speed experienced failed vvt. The chain probably still get loose over time and mileage but the VVT doesn't seem to fail.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 12-19-2019, 04:06 AM   #3
blackmica6's Avatar
Really? Well, that's excellent.
I have a spare frankenstein VVT - made from B and C revision parts. I'll take it apart and see if I can copy DCR's design. I also have a brand new OEM VVT (C) which I'll use in my engine once head work is done.
About the chain though, I think they should've made it beefier, but hey...
Thanks for the answer. I'll take apart the franken VVT and study it. I'll post here if I make some progress modifying it.
Jeff23spl and Db09ms3 like this.
 Old 01-21-2020, 05:49 AM   #4
blackmica6's Avatar
So, I've made some progress with the VVT, it's almost complete. I'll hopefully complete it this weekend and I'll post pictures and a guide how to make your very own DCR-like VVT for the total price of an OEM one ($100-ish), and not the $350 that DCR charges.
EDIT: Upon further research I have found out that even the "C" revision OEM VVT (L3K9-12-4X0C) is known to break the pin cap and fly off inside the engine. Rarely, but it does happen with time. So either a DCR or a modded one is, in my opinion, necessary.
Report: Mitsubishi boss labels French minister a "retard" for "ruining the lives of motorists" Haltech Automotive News 0 10-25-2012 06:00 PM
LaHood: Getting Toyota to recall took "enormous effort," calls automaker "a little safety deaf" Haltech Automotive News 0 02-02-2010 06:10 PM
Lutz lays out his strategy for GM advertising: "Memorable," "clever," "viral" [w/VIDEO] Haltech Automotive News 0 08-04-2009 09:40 AM
Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" Haltech Automotive News 0 04-14-2009 01:40 PM
Page generated in 0.24865 seconds with 21 queries
