 Old 09-24-2009, 11:28 AM   #41
mazdaj's Avatar
Posts: 369   (View Stats)
mazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the world
this is great info, but like others have said how can you explain cx-7's hitting 100k + miles already and not having the issues that we have...
mazdaj is offline   Reply With Quote
 Old 09-24-2009, 11:37 AM   #42
CX-7's? have u ever seen a modded cx-7 jay? lol i diddent think so. im not saying the problem doesent happen stock but as soon as u start modding it just gets worse.
is this making anyone else sick to their stomach? this is literally the most disheartening news i have heard in a while. that vulture thread was easier on me then this lol
kgb (09-24-2009)
 Old 09-24-2009, 11:40 AM   #43
They are not driven as hard, don't see as much boost, don't see as much heat, don't see as much load etc.
 Old 09-24-2009, 11:40 AM   #44
kgb
kgb's Avatar
Posts: 808   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 88
Lex....I'm going to sound like one of those guys but I've be with you since day one. You put in words well thought explanations. However, I understand this is still a "work in progress" discovery. I don't pretend to understand completely so here are some questions:
1. It was hinted at before but will a thicker oil band-aid this at least a bit? Higher octane as well?
2. The PTP burning oil fix also helps by minimizing the amount of oil ingested? OCC helps too?
3. What would we have to replace to avoid this or is going forged the only solution?
Keep it up man!
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
kgb is offline   Reply With Quote
The Following User Says Thank You to kgb For This Useful Post:
Slideways (09-24-2009)
 Old 09-24-2009, 11:41 AM   #45
WOT @1k RPM!
NRSpeed's Avatar
Posts: 1,570   (View Stats)
NRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the world
Groans: 47
Groaned at 50 Times in 33 Posts
You must not have watched the video attached....
MazdaSPEED3 2009 - Mica Black
http://www.mazdaspeedforums.org/forum/f8/setting-avatar-new-users-other-noobs-43712/
http://www.mazdaspeedforums.org/forum/f8/uploading-adding-images-your-post-43704/
No BB URL code = sux
NRSpeed is offline   Reply With Quote
 Old 09-24-2009, 11:43 AM   #46
spheed3's Avatar
Posts: 487   (View Stats)
spheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond repute
If this was an engineering flaw, as is what I understand Lex is trying to say, it wouldn't matter if it was stock or modded or whatever. The reason I don't quite buy this theory is because if there was some sort of design flaw it would have most likely been addresed after the first couple dozen cx7s tossed rods. In my experiance engineering flaws will generally happen frequently and predictably, this motor popping issue is neither. I appreciate the work anyway Lex.
Black Mica 08.5 GT
I'm parting out. Buy my stuff: http://www.mazdaspeedforums.org/foru...ing-out-59908/
spheed3 is offline   Reply With Quote
The Following 2 Users Say Thank You to spheed3 For This Useful Post:
mazdaj (09-24-2009), _Toxic_ (09-24-2009)
 Old 09-24-2009, 11:44 AM   #47
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
yes I feel like i just got kicked in the nuts and gut checked at the same time....
 Old 09-24-2009, 11:53 AM   #48
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
subparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the world
Groaned at 6 Times in 6 Posts
Lex, what about seafoam in the oil 100 miles before oil changes to help clean deposits?
2006 Lotus Elise: Toy car
1999 B4000: DD / Parts hauler / SC Project
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
subparpunk03 is offline   Reply With Quote
 Old 09-24-2009, 11:54 AM   #49
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
The flaw is a characteristic of DI and people like Lenny have already stated companies work in percents and even though our 180 deep blown motor list seems like tons to them all the blown motors probably don't equal 3% between the ms3', cx7, and Ms6.
Carry on citizens....
10.7 @ 133 auto 1G DSM
The Following User Says Thank You to Darksun280 For This Useful Post:
rodrigo (09-24-2009)
 Old 09-24-2009, 11:57 AM   #50
WOT @1k RPM!
NRSpeed's Avatar
Groans: 47
Originally Posted by Lex
The lower line is likely where it had already broken.
Just making sure, this is what Im talking about.
Is this just previous damage, damage from removal, or possibly from the piston seizing up?
 Old 09-24-2009, 12:03 PM   #51
spheed3's Avatar
Oh I know and I agree 100%. It's the fact that we are under that magic number for Mazda to get involved that keeps me from believing this motor blowing issue is some sort of epidemic. For example, Lexus heard of maybe a dozen 06-08 ISs and GSs with corrodid fuel pipes and recalled all 300,000 cars from each year.
Black Mica 08.5 GT
 Old 09-24-2009, 12:05 PM   #52
Thestaplegunkid's Avatar
Posts: 150   (View Stats)
Thestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the world
I believe that is the mark made after the piston got smacked cock eyed in the bore by the flailing rod.
Thestaplegunkid is offline   Reply With Quote
 Old 09-24-2009, 12:05 PM   #53
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
damn!!!!!
"Go find your own enterprise, and get the fuck off my bridge!"
2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard"
1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action"
skeeter149 is offline   Reply With Quote
 Old 09-24-2009, 12:05 PM   #54
_Toxic_'s Avatar
Posts: 643   (View Stats)
_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world
Groans: 35
Groaned at 16 Times in 11 Posts
Does anybody know how many ms3, ms6 has been built around the world?
2010 Mazda 3 MPS White Pearl Mica
K&N Typhoon SRI // Ray Catback Exhaust // Eibach Pro Kit // Tenzo R Type M 18x8 Titanium // 20% Tint all wind
_Toxic_ is offline   Reply With Quote
 Old 09-24-2009, 12:11 PM   #55
WOT @1k RPM!
NRSpeed's Avatar
Groans: 47
Yea, I was kind of wondering about that, if thats the case then wouldnt the wear marks be further along the wall? Down closer to where the piston seized up near the bottom of the cylinder?
 Old 09-24-2009, 12:17 PM   #56
BlackMS3's Avatar
Posts: 1,078   (View Stats)
BlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the world
I have a feeling the price of PI heads are going to go up!!! LOL!!
Someone call DCR and tell them to just drop the DI gig altogether and make us a PI/BT package good for 500+hp without worrying about any of these issues again!!!
Best to date - 13.802@104.16 (I/MP/MM/W)
BlackMS3 is offline   Reply With Quote
 Old 09-24-2009, 12:17 PM   #57
Fux Wit It
Darksun280's Avatar
Groans: 175
it was something like 9k ms3 in 07 and 10 in 08 I have no idea about 09
Lets assume there was 10k made for each car each year that would be
40k ms3's
30k ms6's
30kcx7's?
100k of our motors in America alone
1% would be a thousand cars needed to blow. No company is going to look into 1k cars blowing their motors specially when they void half of them for the slightest thing out of stock spec and once your voided they don't apply you to their blown motor statistics your like a ghost to them. God only knows how many they have sold world wide all combined for eash car. Basically what I'm saying is we are screwed. When you saw the Subaru motors getting recalled trust me it musta been like a 10% or higher fail rate world wide that got them to move their asses.
 Old 09-24-2009, 12:41 PM   #58
_Toxic_'s Avatar
Groans: 35
40k ms3's
30k ms6's
30kcx7's?
Should be possible to find out how many are made exactly, but good guessing i think. Its the same engine in these cars but i dont think we can compare them with each other that much, i mean they must have different settings like in the ECU/ gear ratio/turbo boost or what not.
Specially the Cx7.. does it really have the same internals in the engine and so as the speed3,6?
When motors blow i dont think they wait until like 10% blows, it should be a huge problem if motors blow up stock! its not like it is some minor problem like windshield squeking or so.
But if they wait till 10% stock motors blow, well they do.. warranty or not, they shouldnt charge people to fix it if thats happenes. just speculations......
 Old 09-24-2009, 12:58 PM   #59
Fux Wit It
Darksun280's Avatar
Groans: 175
But if they wait till 10% stock motors blow, well they do.. warranty or not, they shouldn't charge people to fix it if thats happens. just speculations......
What I said is real general but if what Lex pointed out is true its a DI characteristic and not just a ms3/ms6 thing. All the motors would show signs of it. If some one could get P# to answer how mine looked that would tell you. I had 38k HARD fucking miles on that thing.
 Old 09-24-2009, 01:04 PM   #60
Slideways's Avatar
Posts: 18   (View Stats)
Slideways has much to be proud ofSlideways has much to be proud ofSlideways has much to be proud ofSlideways has much to be proud ofSlideways has much to be proud ofSlideways has much to be proud ofSlideways has much to be proud ofSlideways has much to be proud of
Keep it up man!
Yeah second that. I'm willing to do a lot of little band aids if I can make my motor last longer. I'd really like to do an intake on my car because the power drop off at 6 anoy's me. But I don't want to hasten the damage to my rings. What are some idea's on it. Lets not get 30 posts of 'dude your screwed like the rest of us" Lets put some heads together and see what little tricks can be done to help out.
07 Sunlight silver
00 Jeep XJ
Slideways is offline   Reply With Quote
The Following User Says Thank You to Slideways For This Useful Post:
J Dragon (10-18-2009)
 Old 09-24-2009, 01:15 PM   #61
_Toxic_'s Avatar
Groans: 35
Maybe true.. but have we seen sign of it in the "other" engines? If that was the case, all these cars will blow up eventually u mean? Stock or not? Was the picture shown in this thread from a stock or tuned/modded car? (the first pictures in this thread)
 Old 09-24-2009, 01:21 PM   #62
Fux Wit It
Darksun280's Avatar
Groans: 175
It was modded but IMO I always felt that all the motors had a flaw that made its a candidate to blow.
 Old 09-24-2009, 01:24 PM   #63
ALL-IN.
AndyMS3's Avatar
Posts: 671   (View Stats)
AndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the world
Groans: 30
Anyone know what the piston rings are made of?
AndyMS3 is offline   Reply With Quote
 Old 09-24-2009, 01:24 PM   #64
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
thank you.
thank you
40k ms3's
30k ms6's
30kcx7's?
__________________________________________________ __________________________________________________ ____________
I find all this searching for answers very commendable. Keep digging and maybe soon we can build a bulletproof engine here with this ms3.
that aside, make no mistake.....for manufacturers such as Mazda or any other car manufacturer it's simple math. We tend to forget that we are a community of modded ms3's , and in the manufacturers eyes NOT ONE SINGLE blow up of a mildly - fully bolted ms3/ms6 even counts , simply because you MODIFIED IT. but pretending for a moment that they did feel the need to include all these blow ups it would still be a negligible %age of the whole production line for this engine.
you guys are comparing a 4k member forum vs the # of people that have blown up....the ratios are obviously much different.
Last edited by rodrigo; 09-24-2009 at 01:34 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to rodrigo For This Useful Post:
predapio (09-24-2009)
 Old 09-24-2009, 01:27 PM   #65
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
I guess now the fail boat has completely sunk...
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
madvillain (09-24-2009), Scatt Nasty (09-24-2009)
 Old 09-24-2009, 01:30 PM   #66
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
so even though Blackstone's UOA said I could go to 8,000mi on my next oil change with PP 5w-40 (the sample I sent them had about 5k on it), I probably shouldn't do that?
'08 CWP MS3 w/ T3 3071r
 Old 09-24-2009, 01:34 PM   #67
WOT @1k RPM!
NRSpeed's Avatar
Groans: 47
Its more like slowly tipping, just pray your car isnt on the side going in the water.
Im still wondering what where mods and info of the car from which the pictures have been gathered. What kind of mileage, mods, typical driving patterns, etc.
 Old 09-24-2009, 01:40 PM   #68
_Toxic_'s Avatar
Groans: 35
Not trying too be a dick or anything.. but putting on a lot of bolt ons and not tune or tune with a bad tune is a fail on these cars.. saying this because i havent seen any complete stock cars blown.
Not until some tuning company comes up with a tune and cracks the ECU on how its working on these cars, then whe can start modding etc...
 Old 09-24-2009, 01:45 PM   #69
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Wow, Lex definitely seems to be on to something here.
I know this has been asked a few times, but I'm going to reiterate it till there is an answer.
What can we do to help prevent against this, for aided reliability?
1. Thicker high grade oil, like 10w-30, or 10w-40?
2. Oil additives, "Engine Restorer" comes to mind, to help reduce cylinder wall scoring.
3. OCCs or VTA valve cover breather, to prevent oil burning?
4. EGR delete or restriction?
5. Make the car run leaner, SRI for un-tuned folks, or tune the AFI to be leaner?
6. Cryo-treated engine components, to reduce expansion from constant temp changes?
7. Seafoaming often, to reduce carbon build up?
8. Leave in the BS assenbly, to reduce motor vibrations?
9. This would take some machining, but what if we swapped the location of the plugs and the injectors?
I don't know about you guys, but I plan on taking this motor past 150k.
Current Fail:
MATT DAMOND is offline   Reply With Quote
The Following 2 Users Say Thank You to MATT DAMOND For This Useful Post:
djthom (09-25-2009), Slideways (09-24-2009)
 Old 09-24-2009, 01:56 PM   #70
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
well thats great that you plan on it.... however i don't think the Mr.Disi himself plans too...
Deadman is offline   Reply With Quote
The Following User Says Thank You to Deadman For This Useful Post:
Darksun280 (09-24-2009)
 Old 09-24-2009, 02:01 PM   #71
boardjnky4's Avatar
Posts: 402   (View Stats)
boardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the world
Groaned at 40 Times in 22 Posts
seafoaming won't help build-up in the rings
boardjnky4 is offline   Reply With Quote
 Old 09-24-2009, 02:02 PM   #72
you need to run RICHER. rich=cool. thats why people with BT's and people who beat on their cars last. if you taking a long cruise make sure u dont just to 3k rpms the whole way there. get into boost every so often and vary the RPM's.
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
Fobio (09-24-2009), MATT DAMOND (09-24-2009), predapio (09-24-2009), thanox2 (09-25-2009), _Toxic_ (09-24-2009)
 Old 09-24-2009, 02:05 PM   #73
boardjnky4's Avatar
I drive my bitch like I stole it.
The ring issue is REALLY scary though, especially since I don't know the history of oil changes with my car. :gulp:
 Old 09-24-2009, 02:11 PM   #74
WOT @1k RPM!
NRSpeed's Avatar
Groans: 47
Call me a pic whore, but I want to see more pics of the carnage and findings.
 Old 09-24-2009, 02:13 PM   #75
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
this guy in sweden blew his speed in 6th gear. on secondmotor
http://www.mazdas247.com/forum/showt...hp?t=123754538
2015 Mazda 6
 Old 09-24-2009, 02:15 PM   #76
awd>fwd
jwdp54's Avatar
Posts: 627   (View Stats)
jwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the world
Groans: 27
imo not really worried on why these motors blow. if i was i'd go forged. plus don't go by what one pic shows. if everyone that has blown posted a similar pic i'd believe him then.
but for now i'm more concerned on why i can't make more POWER.... figure that out first.
MS3 310whp/320tq- SOLD finally(5/5/10)
evo 8-tuned to E85
jwdp54 is offline   Reply With Quote
 Old 09-24-2009, 02:18 PM   #77
lol is anyone even viewing any other threads right now? haha
AmillieMS6 (09-30-2009), MATT DAMOND (09-24-2009)
 Old 09-24-2009, 02:19 PM   #78
_Toxic_'s Avatar
Groans: 35
I have read about some people with JUST an SRI intake thats getting CEL codes: P0300 and P0303, thats random missfires and missfire in cylinder #3. Isnt that cylinder wich oftens blows?
Last edited by _Toxic_; 09-24-2009 at 02:32 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-24-2009, 02:35 PM   #79
danesti's Avatar
Posts: 4,186   (View Stats)
danesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the world
Groans: 137
should i buy stock in the largest manufacturer of these?
in a way this gives hope..
2008 STi
Intake
Turboback
AP
danesti is offline   Reply With Quote
The Following 11 Users Say Thank You to danesti For This Useful Post:
802MS3 (09-24-2009), AmillieMS6 (09-30-2009), Darksun280 (10-01-2009), djuosnteisn (09-24-2009), jwdp54 (09-24-2009), madvillain (09-24-2009), MATT DAMOND (09-24-2009), predapio (09-24-2009), Scatt Nasty (09-24-2009), superskaterxes (09-24-2009), tozfeekum (09-24-2009)
 Old 09-24-2009, 02:41 PM   #80
Lots of questions here and I certainly don't have all the answers. This is the motor the piston and rod are from: http://www.mazdaspeedforums.org/foru...-no-56k-19727/
Apparently low miles. Probably dyno oil used like Mazda suggests
No we can't change the location of the injector with the spark plug, the flame front will go towards the cylinder wall.
Not sure if seafoaming will do anything to the oil passages on the rings - best bet in my opinion would be changing oil often (I change it at 3k miles) with a full synthetic.
Also we know that knock is induced if the car is heatsoaked/prolonged driving and prone to knock if we get on it. Try and lean into it a little slower before going full race mode.
Cooling it off with some meth is not a bad idea.
However, and unfortunately the uneven heating/cooling of pistons and poor oil control along with cylinder wall washoff will still exist. It's as Darksun has pointed out part of the particular DI design in our car.
djthom (09-25-2009), MATT DAMOND (09-24-2009)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/we-re-getting-somewhere-38529/
The almost defininitive reason for why our motors - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 03-05-2010 11:36 PM
Mazda6 / Atenza > The almost defininitive reason for why our motors This thread Refback 09-28-2009 07:08 AM
The almost defininitive reason for why our motors - Mazda6 / Atenza This thread Refback 09-28-2009 06:54 AM
Page generated in 0.61431 seconds with 43 queries
