![]() | | #281 | ![]() |
| The Truth Hurts ![]() Join Date: Mar 2009
Rep Power: 206 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 73
Groans: 286
Groaned at 339 Times in 226 Posts
| Not Ranked : 0 score
The US engine spec MS3 is not maxed out in regards to what it offers in respect to performance. The Australian MS3 out of the factory dubbed the "MS3 EXTREME" rated at 281HP & 313 lb-ft of torque.
__________________ Trickytwelveinch has elite car skillz - opt_ms3. | |||
| The Following User Says NO Thank You to trickytwelveinch For This Un-useful Post: |
![]() | | #282 | ![]() |
| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1204 ![]() Thanks: 2,634
Groans: 220
| Neutral : +1 score Combustion chamber for DISI engine - Patent 6612282 Scroll down almost to the end here: Direct Injection Systems That's what the swirl shutter/flappers are for (remember a long time ago, we had a "recall" for those swirl shutter valves getting stuck closed? Is that the same thing or similar but unrelated?) instead of the leveled piston head. It was to reduce cost and simplify piston design. I wonder how many people actually went to the dealership to get that fixed... Or if it has any relation at all. |
| The Following User Says Thank You to p057 For This Useful Post: | 802MS3 (09-29-2009) |
![]() | | #283 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
| Not Ranked : 0 score if you look in the service manual they have the diagram of how the VTCS actually "swirls" the air going into the combustion chamber which def might be a problem now that i think about it. i guess when u design a injector spray pattern as retarded as ours and then remove its bandaid your asking for problems.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner |
![]() | | #284 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score I had mine fixed. Shutter valve kept getting stuck closed or w.e ... it happened one time after and never again |
![]() | | #285 | ![]() |
Groans: 79
| Not Ranked : 0 score Some thoughts i had last night that could contribute to the theory of this thread are these: - Could the cylinder bores be out of spec slightly, not a true 90 degrees to the crank center line? this would definitely aggravate any ring & cylinder friction issues. - Cylinder wall thickness. Does anyone know how thick ours are? This could screw up the ring seals and also contribute to ring & cylinder friction. Also blow by would probably be common and oil consumption. This would be more evident with higher hp levels, and probably not applicable since our blown engines don't seem to target the high hp guys any more or less than the stockish guys. - Are our blocks open or closed deck? Thanks again lex.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #286 | ![]() |
![]() Join Date: Apr 2008 Location: Salt Lake City, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 179
Groaned at 126 Times in 71 Posts
| Not Ranked : 0 score The 2.3L Turbo DISI engine code is L3-VDT, and NA-VVT version L3-VE. Bore 87.5mm, stroke 94mm both. The blocks are the same for both, aluminum, closed deck with iron sleeves cast in. http://www.honda-tech.com/showthread.php?p=32045282
__________________ 2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI Whiteline F/R Sways | SPT SSK | TWM M1 Abrams |
| The Following User Says Thank You to badams118 For This Useful Post: | djuosnteisn (09-29-2009) |
![]() | | #287 | ![]() |
| NEC ![]() Join Date: Mar 2008
Rep Power: 473 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
Groaned at 6 Times in 6 Posts
__________________ 2006 Lotus Elise: Toy car 1999 B4000: DD / Parts hauler / SC Project 2007 Mazdaspeed 3: *sold* 2005 Corolla XRS: *sold* | |
![]() | | #288 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
edit: NM, searched and found this thread: http://www.honda-tech.com/showthread...&highlight=MZR looks like he was thinking about swapping the MZR into a different chassis and his goal was 400whp. I wonder if he was ever successful.
__________________ '08 CWP MS3 w/ T3 3071r Last edited by 802MS3; 09-29-2009 at 11:42 AM. | |
![]() | | #289 | ![]() |
Groans: 286
| Not Ranked : 0 score Reason: piston ring/cylinder friction caused over time (some in the short run basis others in the long run) due to insufficient oil lubrication along with too much heat and too little heat. Edit: the small amount of engines that blew is due to pro-long damage done being over-time. These pistons/rods failing like this doesn't just happen overnight. There's more to it but that's the basis and so I'll explain everything when I'm done writing my "article".
![]() | | #290 | ![]() |
![]() Join Date: Oct 2008 Location: Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 190
Groaned at 53 Times in 32 Posts
| Not Ranked : 0 score "Uh oh, Ford has been using these motors in Austrailian cars. XCORP was founded in 1991??? Its apparent that Ford has been working with these guys. So anyways, that’s nice. The DI system has been licensed to Ford and GM, as well as Mercury ( a boat engine manufacturer). Wow, crazy to see that Ford and GM both released their high output turbocharged DI motors within a year of eachother (sarcasm) And, look at this, too. The special piston designs from 1996-2003 were replaced with the flapper system in the intake manifolds, which cause the air to tumble into the cylinders, the swirl effect, exactly the reasoning for the goofy shaped pistons in the preliminary GDI designs. The usage of swirl valves causes a spinning air movement, like a tornado turned horizontally, rolling like a barrel, which causes atomization of the fuel and air together in the cylinder, instead of the goofy darth vader mask pistons which do the same thing at more $$$ to the manufacture, and more research and design" Direct Injection Systems Seems pretty clear to me. We need the VTCS or the eco pistons. Without either we're fucked. How many blowies had the VTCS removed? I fully believe that the problem is fuel wash down. Maybe we could benefit from re-engineered oil squirters? That would be a pretty easy fix. Not much harder than a BSD... Food for thought.
__________________ My mission is to go fast. ![]() Currently Designing: The golden girdle of the gods The CF "fuck your face" IM |
![]() | | #291 | ![]() |
![]() Join Date: Aug 2009 Location: Raleigh NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
Groaned at 40 Times in 22 Posts
| Not Ranked : 0 score wait, people have been removing the VTCS from their cars? |
![]() | | #292 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score yea, search for VTCS delete
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
![]() | | #293 | ![]() |
| Not Ranked : 0 score have those same people been blowing engines? |
![]() | | #294 | ![]() |
| Not Ranked : 0 score i think we need a new poll!
![]() | | #295 | ![]() |
![]() Join Date: May 2009
Rep Power: 372 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 558
| Not Ranked : 0 score How about a small amount of oil mixed in the fuel, kind of like a 2 stroke but not as much oil ? Sounds lame but would this help keep the cylinder walls oiled ?
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount |
![]() | | #296 | ![]() |
| Not Ranked : 0 score It's pretty clear to me that from a design perspective, the VTCS OR the Funky Piston ring is needed(as phantom3 already stated) So it seems to me that it's a pretty dumb move to REMOVE this part(although maybe nobody knew any better) Also, it IS possible that dumping more fuel causes the VTCS to malfunction. That is also worth looking into. |
![]() | | #297 | ![]() |
Groans: 220
![]() I doubt VCTS is the culprit; i wouldn't jump to that conclusion. Last edited by p057; 09-29-2009 at 01:58 PM. Reason: oops | |
![]() | | #298 | ![]() |
| Not Ranked : 0 score not jumping to conclusions...merely offering insight in order to make a conclusion, you need to do testing |
![]() | | #299 | ![]() |
![]() Join Date: Apr 2008 Location: Utah
Rep Power: 573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
| Not Ranked : 0 score VCTS flaps are only used during cold starts & idle BTW, after it warms up they are open 100% |
| The Following User Says Thank You to JumpingJackson For This Useful Post: | spnkr21 (10-01-2009) |
![]() | | #300 | ![]() |
Groans: 190
| Not Ranked : 0 score What about the swirl in general? Not in relation to the VTCS but rather to the flow mods (Ie: FMIC, CIA, SRI, TIP, ect) All these things have an affect on flow which in turn affects the flow (Read swirl) into the cylinder chamber. If our flow mods are altering the swirl pattern enough, the fuel won't suspend properly in the air. If it's not suspending it may be shooting straight onto the cylinder wall affecting the lubrication causing the piston to bind. It's possible that 2 cycle may be the way to go. Rotary's run 2 cycle to help with the high wear. MIGHT be our solution as well. [QUOTE=boardjnky4;324466it IS possible that dumping more fuel causes the VTCS to malfunction. That is also worth looking into.[/QUOTE] I don't see how dumping more fuel can cause the VTCS to malfunction as the injector comes after the VTCS.
![]() | | #301 | ![]() |
![]() Join Date: Oct 2008 Location: New Brunswick, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
| Not Ranked : 0 score And just to confirm, my VTCS was fully functional. So I don't think that's the smoking gun. (VTCS currently being removed .... just gotta weld up some holes) |
![]() | | #302 | ![]() |
Groans: 190
Note: Don't everyone freak out. I'm merely postulating.
__________________ My mission is to go fast. ![]() Currently Designing: The golden girdle of the gods The CF "fuck your face" IM | |
![]() | | #303 | ![]() |
Groans: 79
| Not Ranked : 0 score I doubt its swirl related. Other things like 400 - 1700 psi fuel pressure, VVT, RPM in general, exh back pressure, etc etc etc would all affect the fuel atomization & suspension much more imo.
![]() | | #304 | ![]() |
Groans: 190
| Not Ranked : 0 score Maybe my next project will be a set of light weight billet cnc'd pistons. Maybe Aluminum rods to go with... EDIT: Maybe I'll just CNC an entire engine... maybe that would work better... lol
| The Following 2 Users Say Thank You to phantom3 For This Useful Post: | 802MS3 (09-29-2009), reddeerspeed3 (09-29-2009) |
![]() | | #305 | ![]() |
Rep Power: 2585 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,910
Groans: 35
Groaned at 16 Times in 11 Posts
![]() | | #306 | ![]() |
![]() Join Date: Jul 2009 Location: Vancouver, BC
| Not Ranked : 0 score Negative, that would just reduce fuel octane and likely INDUCE knock. You have to get the oil in from the non-combustion side, that's why there's rings. |
![]() | | #307 | ![]() |
Groans: 190
| Not Ranked : 0 score Why can't we get aftermarket injectors!?!?! lol
![]() | | #308 | ![]() |
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I was thinking the same thing today as well. Do the upgraded fuel pumps increase the output pressure of the injectors??? Because the injectors spray pattern could be affected by the higher pressures. |
![]() | | #309 | ![]() |
| Not Ranked : 0 score Tough to believe DI is the culprit. It's been around since the 1930s. If it was good enough for Daimler-Benz to put in a Bf-109, it oughta be good enough for our little engine. Of course, stupidity and engineering accidents are timeless, I guess. |
![]() | | #310 | ![]() |
![]() Join Date: May 2009 Location: Georgia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Not Ranked : 0 score How about you take everyting out the engine and replace it with an evo drivetrain and call it a day......LOL (BTW I am kidding)
__________________ 2006 Mazdaspeed6 Sport - Black Cherry Mica Sure Aeros Short Ram Intake | Stage 1 SF +93 AP Map | 3.25 TMIC | Cobb Tuning Turbo Inlet Pipe | Turbosmart Hybrid BOV | Magnaflow catback Exhaust | ATP High Flow Catted Downpipe | Steedspeed Exhaust Manifold Ceramic Coated | ACT Clutch and Flywheel | Black JDM LED Tailights | CPE Rear Engine Motor Mount | SU Solid Shifter Spacers | Denso 2 Step Colder Spark Plugs | SU Boost Tubes |
![]() | | #311 | ![]() |
![]() Join Date: Jan 2009 Location: PHX/SV AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 772
Groans: 94
Groaned at 43 Times in 33 Posts
| Not Ranked : 0 score you just became "that guy"
__________________ ![]() 321 HP/348TQ-- 13.940 @ 106 /3kft ASL |
| The Following 2 Users Say Thank You to Scatt Nasty For This Useful Post: | madvillain (10-01-2009), phantom3 (10-01-2009) |
![]() | | #312 | ![]() |
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score what a read. i cant remember what page but as far as I know the total number of MS6 made were 5000 in 2006 and another 5000 in 2007. how many ms6 have blown thus far? I have no idea about total ms3 or cx7 made. I know I killed a 06 speed 6 from hydrolocking so now max of 4999 Last edited by ms686; 10-01-2009 at 06:49 AM. |
![]() | | #313 | ![]() |
| Not Ranked : 0 score wheres that guy with the scope camera who was documenting meth cleaning the cylinder heads. maby we can stick that shit in there and crank the motor to see exactly how the spray pattern is spraying or something. or maby even to just look at carbon deposits/damage.
![]() | | #314 | ![]() |
Groans: 221
| Not Ranked : 0 score I think socks did that.
__________________ '08 CWP MS3 w/ T3 3071r |
![]() | | #315 | ![]() |
![]() Join Date: Aug 2009 Location: San Diego
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 48
| Not Ranked : 0 score so what ever happened to trickytwelveinch's super article? |
![]() | | #316 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
| Not Ranked : 0 score I was wondering the same thing.......
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 ![]() http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. |
![]() | | #317 | ![]() |
Groans: 286
| Not Ranked : 0 score I'll post it when it's done, maybe a week, maybe a month or maybe three. Sorry, but I got more important things to do, then to sit and gather data and write an article about actual facts that majority of people are going to call BS anyway- that's just my opinion. Plus, the percentage of people who blew their motors is like what, less than 1%? Nothing too serious, just end-user error.
![]() | | #318 | ![]() |
| The Following 7 Users Say Thank You to Lex For This Useful Post: | djuosnteisn (10-18-2009), evidence (10-18-2009), JmkC (10-18-2009), kgb (10-19-2009), phantom3 (10-18-2009), reddeerspeed3 (10-18-2009), Thestaplegunkid (10-18-2009) |
![]() | | #319 | ![]() |
Groans: 190
| Not Ranked : 0 score SNAP!
![]() | | #320 | ![]() |
I must say, if your "article" is anything like your typical thread posts, it should be an "entertaining" read if nothing else. | |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/we-re-getting-somewhere-38529/ | ||||
| The almost defininitive reason for why our motors - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | This thread | Refback | 03-05-2010 11:36 PM | |
| Mazda6 / Atenza > The almost defininitive reason for why our motors | This thread | Refback | 09-28-2009 07:08 AM | |
| The almost defininitive reason for why our motors - Mazda6 / Atenza | This thread | Refback | 09-28-2009 06:54 AM | |
