Went out for beer and came back with this. 4 Attachment(s) Went out to get some beer. As I was leaving the stop light right near my place I heard a loud thunk, then smelled raw fuel. Got home, popped the hood and then saw my engine puke out all its oil. I looked back down the road and saw a nice trail of oil. I thought for sure I popped my block, but as I was walking back to my apt. I saw my oil drain plug on the ground. Stroke of fucking luck, as I new exactly what happened. The monkeys i get to change my oil forgot to put a new crush washer on the plug and probably didnt tighten it enough. Fortunately the place is close by. They came and put the plug back in, filled it with 5.7 qts oil and I took it back to the shop, no knock, no lights, no KR on the DH. They changed the oil again with the filter and credited me back for my last oil change. Good outcome for a potentially shitty problem. And the moral of the story is make sure the fags that change your oil (yourself included) put a new crush washer on the plug. Attachment 20092 Attachment 20093 Attachment 20094 Attachment 20095 |
This is why you man up and do that shit yourself. And if you are going to say "Oh but I live in an apartment" then man up and go to the store and buy you some Wheel Ramps Dont be a darksun! Youll end up with an rearended Evo. |
Got all the above, and used to do it. But its pretty fuckin ghetto to be out in my little carport changing the oil. The place I live in has a rule of no working on the car. My parking spot is right by the office. Oh and you forgot to include the required 2x6 chunks to get this car up on the ramps without craping the bumpers chin. |
Oil starvation still fucked with the longevity of the motor though. Compression check bare minimum. |
oil looks really black and dirty, when was it changed ? maybe they charged you and never put in new oil |
Actually all the oil stayed in circulation until the engine was shut off. But with only 24000miles on the odo in the last 4 years I'm not too worried about the longevity of the engine. Compression check will be done on wed. for shits and giggles. Quote:
.....and this is why I wont buy a used car again... |
thats what it looks like... |
That's horrible, but it seems like your taking this lightly. I would be livid if a shop did that to my car. |
Jiffy Pube FTL. |
Call me crazy but what was the loud thunk? Why would you smell gas? Accidents happen but I think I would be a little more upset with the shop. Hope all is okay (probably is). Good luck. |
My apartment complex has a rule about not working on cars too. I don't care though and do all my maintenance on my car, my roomates car, my roomates g/fs car, my g/fs car etc. I got a garage with a bunch of tools with an air compressor and air tools coming after the holidays. Just because there is a rule doesn't mean they will enforce it. Its better to take a chance to get yelled at by some maintenance dude at an appartment complex than having your motor vomit on the pavement. |
Sent from my Droid using Tapatalk |
I smell gas every time I walk past my hood... still can't find any leaks..:261: |
I would def. be mad at your shop for such a bad job on such and easy thing to do. Get that compression test done for peace of mind. |
ss you are venting your vc to atmosphere right? theres your smell right there i believe |
Yes the thunk was the plug hitting the undertray that they have been bending every time. I used to change my oil at home, then I moved to some upscale apts. here in Cali. Ive got a reputation to uphold, and the backyard mechanic isnt one of them anymore. Interestingly, the thud was heard 2 stoplights away, almost 1000 ft from my parking spot, and i would think the drain plug would have fallen out well before the speedbumps. I work in a pretty high stress, high stakes job, and have learned that getting mad at a company for one of thier underpaid monkeys fuckup doesn't solve much. Same tech did it to another guys minivan that was also there for a "leak". Interestingly enough it was a Penzoil service station, no jiffypube. |
I would go ape shit if that happened to my car! I would hunt down ever member of the responsible persons family. Who knows what has happened to your engine. Even though it runs well now doesn't mean it not going to crap out in 10,000 miles because of this. |
they should've credited u for some new pants... b/c at first site i would've shitted mine... glad it all worked out though man |
just when i thought....can anyone fuck up an oil change? |
i have no problem with people that cant do their own shit because of lack of skills or time or whatever...but to not do it because you are afraid of what your neighbors will think? or because you think it will make you look cheap? come on.... |
Not necessarily. I have seen seen other cars go air cooled 2.5 miles away from Jiffy Lube. When I was a mechanic, our shop was literally 2.5 miles from Jiffy Lube. They would shit themselves, and coast to the front door. Most common problems were not washer or loose bolts, but overtightened/stripped bolts that fell out. So they were almost out of oil as soon as they left the place. Still if it happened to me my car would be getting a big time inspection from a mechanic making sure it was not fucked up. |
I've changed my oil at least a couple dozen times and not replaced the crush washer yet. No need to until it leaks. |
I didn't notice it until I replace the injector seals again, so it's probably just an o-ring or something... I'm going to replace them all when i get SD's seals and HPRV anyway... |
you're welcome =D http://laist.com/attachments/la_tomdog/farrellbush.jpg |
nice on nurse... :javanc: |
Paying about $2k-2500 a month rent in Cupertino? |
This is obviously a pointless battle, thank you for weighing in on my sexual orientation though. iirc I've done more dirty work and grunt work than you would care to hear about, so getting my fingernails dirty isnt my concern. Your insightful post did give me a great idea. Maybe I can start doing all my car maintenance in the back corner of the complex in front of the people that live there. Since they dont know me they obviously wont care. |
WTF cares if I choose not to change my own oil? That wasnt the intent of this thread. :33: |
I skipped through. As far as doing it yourself - If something did happen, that oil change place would've had to purchase a new engine... I like knowing a company with the money to do it would be responsible. Not only that, when you trade-in or sell, you'll have service records which exponentially increase the resale value. |
And that's why I will never let anyone else change my oil. I've had the dealership screw it up like this too because they didn't tighten the drain plug. On the whole crush washer thing, you don't have to replace it every you do the oil change unless you torque the shit out of it and crush it to oblivion. I've reused mine like 10 times already. If you do crush the washer, just a torch to heat it up and it will expend back to size ready to be crushed again. Fuck going to the dealership for new ones. Quote:
Reputation? Thats full of lulz. Quote:
Sounds like the guy set the torque wrench to ounces instead of pounds. Quote:
I had a line pop off an aftermarket oil cooler from a loose hose clamp while driving that pissed all 4.5 quarts out in about 10 seconds in a 1990 Nissan 240SX. Wound up driving about a half mile to a 7-11, valve lifters tapping away (they were hydraulic), to fix it and refill with oil. I was running Mobil 1 in it at the time. Retightened the hose, filled with new oil and that car went for another 30k miles before I sold it. As far as I know, it went for many more miles without issue. It had 160k on it when I sold it. So, the point is, you can lose all your oil and be fine, especially if you shut down quickly, which I didn't. |
| All times are GMT -7. The time now is 06:48 AM. |
