this is great info, but like others have said how can you explain cx-7's hitting 100k + miles already and not having the issues that we have... |
CX-7's? have u ever seen a modded cx-7 jay? lol i diddent think so. im not saying the problem doesent happen stock but as soon as u start modding it just gets worse. is this making anyone else sick to their stomach? this is literally the most disheartening news i have heard in a while. that vulture thread was easier on me then this lol |
Lex....I'm going to sound like one of those guys but I've be with you since day one. You put in words well thought explanations. However, I understand this is still a "work in progress" discovery. I don't pretend to understand completely so here are some questions: 1. It was hinted at before but will a thicker oil band-aid this at least a bit? Higher octane as well? 2. The PTP burning oil fix also helps by minimizing the amount of oil ingested? OCC helps too? 3. What would we have to replace to avoid this or is going forged the only solution? Keep it up man! :biglaugh: |
If this was an engineering flaw, as is what I understand Lex is trying to say, it wouldn't matter if it was stock or modded or whatever. The reason I don't quite buy this theory is because if there was some sort of design flaw it would have most likely been addresed after the first couple dozen cx7s tossed rods. In my experiance engineering flaws will generally happen frequently and predictably, this motor popping issue is neither. I appreciate the work anyway Lex. |
Lex, what about seafoam in the oil 100 miles before oil changes to help clean deposits? |
1 Attachment(s) Quote:
http://www.mazdaspeedforums.org/foru...1&d=1253814697 Is this just previous damage, damage from removal, or possibly from the piston seizing up? |
damn!!!!! |
I have a feeling the price of PI heads are going to go up!!! LOL!! Someone call DCR and tell them to just drop the DI gig altogether and make us a PI/BT package good for 500+hp without worrying about any of these issues again!!! |
Lets assume there was 10k made for each car each year that would be 40k ms3's 30k ms6's 30kcx7's? 100k of our motors in America alone 1% would be a thousand cars needed to blow. No company is going to look into 1k cars blowing their motors specially when they void half of them for the slightest thing out of stock spec and once your voided they don't apply you to their blown motor statistics your like a ghost to them. God only knows how many they have sold world wide all combined for eash car. Basically what I'm saying is we are screwed. When you saw the Subaru motors getting recalled trust me it musta been like a 10% or higher fail rate world wide that got them to move their asses. |
Specially the Cx7.. does it really have the same internals in the engine and so as the speed3,6? When motors blow i dont think they wait until like 10% blows, it should be a huge problem if motors blow up stock! its not like it is some minor problem like windshield squeking or so. But if they wait till 10% stock motors blow, well they do.. warranty or not, they shouldnt charge people to fix it if thats happenes. just speculations......:sasmokin: |
Anyone know what the piston rings are made of? |
thank you. Quote:
I find all this searching for answers very commendable. Keep digging and maybe soon we can build a bulletproof engine here with this ms3. that aside, make no mistake.....for manufacturers such as Mazda or any other car manufacturer it's simple math. We tend to forget that we are a community of modded ms3's , and in the manufacturers eyes NOT ONE SINGLE blow up of a mildly - fully bolted ms3/ms6 even counts , simply because you MODIFIED IT. but pretending for a moment that they did feel the need to include all these blow ups it would still be a negligible %age of the whole production line for this engine. you guys are comparing a 4k member forum vs the # of people that have blown up....the ratios are obviously much different. |
I guess now the fail boat has completely sunk... |
so even though Blackstone's UOA said I could go to 8,000mi on my next oil change with PP 5w-40 (the sample I sent them had about 5k on it), I probably shouldn't do that? |
Im still wondering what where mods and info of the car from which the pictures have been gathered. What kind of mileage, mods, typical driving patterns, etc. |
Not until some tuning company comes up with a tune and cracks the ECU on how its working on these cars, then whe can start modding etc...:thinking: |
Wow, Lex definitely seems to be on to something here. I know this has been asked a few times, but I'm going to reiterate it till there is an answer. What can we do to help prevent against this, for aided reliability? 1. Thicker high grade oil, like 10w-30, or 10w-40? 2. Oil additives, "Engine Restorer" comes to mind, to help reduce cylinder wall scoring. 3. OCCs or VTA valve cover breather, to prevent oil burning? 4. EGR delete or restriction? 5. Make the car run leaner, SRI for un-tuned folks, or tune the AFI to be leaner? 6. Cryo-treated engine components, to reduce expansion from constant temp changes? 7. Seafoaming often, to reduce carbon build up? 8. Leave in the BS assenbly, to reduce motor vibrations? 9. This would take some machining, but what if we swapped the location of the plugs and the injectors? I don't know about you guys, but I plan on taking this motor past 150k. |
seafoaming won't help build-up in the rings |
you need to run RICHER. rich=cool. thats why people with BT's and people who beat on their cars last. if you taking a long cruise make sure u dont just to 3k rpms the whole way there. get into boost every so often and vary the RPM's. |
I drive my bitch like I stole it. The ring issue is REALLY scary though, especially since I don't know the history of oil changes with my car. :gulp: |
Call me a pic whore, but I want to see more pics of the carnage and findings. |
this guy in sweden blew his speed in 6th gear. on secondmotor http://www.mazdas247.com/forum/showt...hp?t=123754538 |
imo not really worried on why these motors blow. if i was i'd go forged. plus don't go by what one pic shows. if everyone that has blown posted a similar pic i'd believe him then. but for now i'm more concerned on why i can't make more POWER.... figure that out first. |
lol is anyone even viewing any other threads right now? haha |
I have read about some people with JUST an SRI intake thats getting CEL codes: P0300 and P0303, thats random missfires and missfire in cylinder #3. Isnt that cylinder wich oftens blows? |
should i buy stock in the largest manufacturer of these? http://cnreviews.com/wp-content/uplo..._sale_sign.jpg in a way this gives hope.. |
Lots of questions here and I certainly don't have all the answers. This is the motor the piston and rod are from: http://www.mazdaspeedforums.org/foru...-no-56k-19727/ Apparently low miles. Probably dyno oil used like Mazda suggests No we can't change the location of the injector with the spark plug, the flame front will go towards the cylinder wall. Not sure if seafoaming will do anything to the oil passages on the rings - best bet in my opinion would be changing oil often (I change it at 3k miles) with a full synthetic. Also we know that knock is induced if the car is heatsoaked/prolonged driving and prone to knock if we get on it. Try and lean into it a little slower before going full race mode. Cooling it off with some meth is not a bad idea. However, and unfortunately the uneven heating/cooling of pistons and poor oil control along with cylinder wall washoff will still exist. It's as Darksun has pointed out part of the particular DI design in our car. |
| All times are GMT -7. The time now is 06:47 AM. |
