-   -   We're getting somewhere ... (http://www.mazdaspeedforums.org/forum/f10/were-getting-somewhere-38529/)
trickytwelveinch 09-28-2009 08:10 PM
What I am trying to get you guys understand is that correlation factor. A very minimal amount of MS3 blew to brush the whole engine off as weak, bad design (i.e, rods, pistons, injectors). Again, I am not knocking on LEX and what he is doing or anyone else.
Originally Posted by ktan91 (Post 323814)
I honestly don't think we blow that many engines! Have you guys never gone to the Subaru forums? I just read blown motors as being random.. maybe it's just bad luck!
If these rods and pistons and even the block itself was weak as it is believed these motors would be blowing on dynos left and right along with stock MS3 blowing from the east coast to the west coast- from the states to to Europe.... Subies blow left and right. Few locals shops blew quite a few... some brand new or just a mod or two.
The US engine spec MS3 is not maxed out in regards to what it offers in respect to performance. The Australian MS3 out of the factory dubbed the "MS3 EXTREME" rated at 281HP & 313 lb-ft of torque.
But I do agree about the new piston design in the EcoBoost.. They knew something was up but I don't think it affects it THAT much to cause major problems in our engine.
so...so...so...close...it's all about.....
So..... anyone got a solution to my car knocking like crazy cruising on the highway?
:peace: start a new thread or look for my PM.
p057 09-29-2009 07:00 AM
Originally Posted by 8.5MS3 (Post 322112)
The piston in the new ecoboost engine
http://www.drivingenthusiast.net/sec...1_HR_small.jpg
Combustion chamber for DISI engine - Patent 6612282
Scroll down almost to the end here:
http://www.mazdaspeedforums.org/foru...on-systems-80/
That's what the swirl shutter/flappers are for (remember a long time ago, we had a "recall" for those swirl shutter valves getting stuck closed? Is that the same thing or similar but unrelated?) instead of the leveled piston head.
It was to reduce cost and simplify piston design.
I wonder how many people actually went to the dealership to get that fixed... Or if it has any relation at all.
superskaterxes 09-29-2009 07:10 AM
if you look in the service manual they have the diagram of how the VTCS actually "swirls" the air going into the combustion chamber which def might be a problem now that i think about it. i guess when u design a injector spray pattern as retarded as ours and then remove its bandaid your asking for problems.
Deadman 09-29-2009 08:07 AM
I had mine fixed. Shutter valve kept getting stuck closed or w.e ... it happened one time after and never again
djuosnteisn 09-29-2009 09:04 AM
Some thoughts i had last night that could contribute to the theory of this thread are these:
- Could the cylinder bores be out of spec slightly, not a true 90 degrees to the crank center line? this would definitely aggravate any ring & cylinder friction issues.
- Cylinder wall thickness. Does anyone know how thick ours are? This could screw up the ring seals and also contribute to ring & cylinder friction. Also blow by would probably be common and oil consumption. This would be more evident with higher hp levels, and probably not applicable since our blown engines don't seem to target the high hp guys any more or less than the stockish guys.
- Are our blocks open or closed deck?
Thanks again lex.
badams118 09-29-2009 10:22 AM
The 2.3L Turbo DISI engine code is L3-VDT, and NA-VVT version L3-VE. Bore 87.5mm, stroke 94mm both. The blocks are the same for both, aluminum, closed deck with iron sleeves cast in.
http://www.honda-tech.com/showthread.php?p=32045282
subparpunk03 09-29-2009 11:10 AM
Is there statistical evidence to support that? What percentage of people blown have had the VTCS deleted? I don't buy this as a reason for throwing a rod.
802MS3 09-29-2009 11:22 AM
MZR infos for teh Mr E.G. - Honda-Tech
nice find, but why is that on a honda forum?
edit: NM, searched and found this thread: http://www.honda-tech.com/showthread...&highlight=MZR
looks like he was thinking about swapping the MZR into a different chassis and his goal was 400whp. I wonder if he was ever successful.
trickytwelveinch 09-29-2009 12:04 PM
Reason: piston ring/cylinder friction caused over time (some in the short run basis others in the long run) due to insufficient oil lubrication along with too much heat and too little heat.
Edit: the small amount of engines that blew is due to pro-long damage done being over-time. These pistons/rods failing like this doesn't just happen overnight. There's more to it but that's the basis and so I'll explain everything when I'm done writing my "article".
phantom3 09-29-2009 12:26 PM
"Uh oh, Ford has been using these motors in Austrailian cars. XCORP was founded in 1991??? Its apparent that Ford has been working with these guys. So anyways, that’s nice. The DI system has been licensed to Ford and GM, as well as Mercury ( a boat engine manufacturer). Wow, crazy to see that Ford and GM both released their high output turbocharged DI motors within a year of eachother (sarcasm)
And, look at this, too. The special piston designs from 1996-2003 were replaced with the flapper system in the intake manifolds, which cause the air to tumble into the cylinders, the swirl effect, exactly the reasoning for the goofy shaped pistons in the preliminary GDI designs. The usage of swirl valves causes a spinning air movement, like a tornado turned horizontally, rolling like a barrel, which causes atomization of the fuel and air together in the cylinder, instead of the goofy darth vader mask pistons which do the same thing at more $$$ to the manufacture, and more research and design"
Seems pretty clear to me.
We need the VTCS or the eco pistons. Without either we're fucked.
How many blowies had the VTCS removed?
I fully believe that the problem is fuel wash down. Maybe we could benefit from re-engineered oil squirters? That would be a pretty easy fix. Not much harder than a BSD... Food for thought.
boardjnky4 09-29-2009 12:35 PM
wait, people have been removing the VTCS from their cars?
m4tic 09-29-2009 12:41 PM
yea, search for VTCS delete
boardjnky4 09-29-2009 12:43 PM
have those same people been blowing engines?
m4tic 09-29-2009 12:44 PM
i think we need a new poll!
flyrevs2 09-29-2009 12:45 PM
How about a small amount of oil mixed in the fuel, kind of like a 2 stroke but not as much oil ? Sounds lame but would this help keep the cylinder walls oiled ?
boardjnky4 09-29-2009 12:47 PM
It's pretty clear to me that from a design perspective, the VTCS OR the Funky Piston ring is needed(as phantom3 already stated)
So it seems to me that it's a pretty dumb move to REMOVE this part(although maybe nobody knew any better)
Also, it IS possible that dumping more fuel causes the VTCS to malfunction. That is also worth looking into.
p057 09-29-2009 01:55 PM
:oops:
I doubt VCTS is the culprit; i wouldn't jump to that conclusion.
boardjnky4 09-29-2009 02:03 PM
not jumping to conclusions...merely offering insight
in order to make a conclusion, you need to do testing
JumpingJackson 09-29-2009 02:08 PM
VCTS flaps are only used during cold starts & idle BTW, after it warms up they are open 100%
phantom3 09-29-2009 02:24 PM
What about the swirl in general?
Not in relation to the VTCS but rather to the flow mods (Ie: FMIC, CIA, SRI, TIP, ect) All these things have an affect on flow which in turn affects the flow (Read swirl) into the cylinder chamber.
If our flow mods are altering the swirl pattern enough, the fuel won't suspend properly in the air. If it's not suspending it may be shooting straight onto the cylinder wall affecting the lubrication causing the piston to bind.
It's possible that 2 cycle may be the way to go. Rotary's run 2 cycle to help with the high wear. MIGHT be our solution as well.
[QUOTE=boardjnky4;324466it IS possible that dumping more fuel causes the VTCS to malfunction. That is also worth looking into.[/QUOTE]
I don't see how dumping more fuel can cause the VTCS to malfunction as the injector comes after the VTCS.
Thestaplegunkid 09-29-2009 02:24 PM
And just to confirm, my VTCS was fully functional. So I don't think that's the smoking gun. (VTCS currently being removed .... just gotta weld up some holes)
phantom3 09-29-2009 02:30 PM
What about flow mods? (intake, ic, ect) Did you have any of those?
Note: Don't everyone freak out. I'm merely postulating.
djuosnteisn 09-29-2009 02:33 PM
I doubt its swirl related. Other things like 400 - 1700 psi fuel pressure, VVT, RPM in general, exh back pressure, etc etc etc would all affect the fuel atomization & suspension much more imo.
phantom3 09-29-2009 02:40 PM
Maybe my next project will be a set of light weight billet cnc'd pistons. Maybe Aluminum rods to go with...
EDIT: Maybe I'll just CNC an entire engine... maybe that would work better... lol
_Toxic_ 09-30-2009 12:29 AM
I think you are on too something here! :fing02:
darth vader 09-30-2009 07:29 AM
Negative, that would just reduce fuel octane and likely INDUCE knock. You have to get the oil in from the non-combustion side, that's why there's rings.
phantom3 09-30-2009 07:32 AM
Why can't we get aftermarket injectors!?!?! lol
halifaxm3s 09-30-2009 05:16 PM
"Seems pretty clear to me.
I was thinking the same thing today as well. Do the upgraded fuel pumps increase the output pressure of the injectors??? Because the injectors spray pattern could be affected by the higher pressures.
darth vader 09-30-2009 06:37 PM
Tough to believe DI is the culprit. It's been around since the 1930s. If it was good enough for Daimler-Benz to put in a Bf-109, it oughta be good enough for our little engine.
Of course, stupidity and engineering accidents are timeless, I guess.
manofhonor24 09-30-2009 07:20 PM
How about you take everyting out the engine and replace it with an evo drivetrain and call it a day......LOL (BTW I am kidding)
Scatt Nasty 10-01-2009 12:05 AM
you just became "that guy"
ms686 10-01-2009 12:52 AM
what a read. i cant remember what page but as far as I know the total number of MS6 made were 5000 in 2006 and another 5000 in 2007. how many ms6 have blown thus far? I have no idea about total ms3 or cx7 made. I know I killed a 06 speed 6 from hydrolocking so now max of 4999 ;)
superskaterxes 10-01-2009 07:48 AM
wheres that guy with the scope camera who was documenting meth cleaning the cylinder heads. maby we can stick that shit in there and crank the motor to see exactly how the spray pattern is spraying or something. or maby even to just look at carbon deposits/damage.
802MS3 10-01-2009 08:17 AM
I think socks did that.
dphm 10-17-2009 11:15 PM
so what ever happened to trickytwelveinch's super article?
FreeFlyFreak 10-17-2009 11:19 PM
I was wondering the same thing.......
trickytwelveinch 10-18-2009 12:40 AM
I'll post it when it's done, maybe a week, maybe a month or maybe three. Sorry, but I got more important things to do, then to sit and gather data and write an article about actual facts that majority of people are going to call BS anyway- that's just my opinion.
Plus, the percentage of people who blew their motors is like what, less than 1%? Nothing too serious, just end-user error.
Lex 10-18-2009 01:19 AM
You nailed it on the head, there isn't anything you can add that hasn't already been discussed. Unfortunately you did have the time to make a big fuss about it.
phantom3 10-18-2009 02:36 AM
SNAP!
Thestaplegunkid 10-18-2009 06:27 AM
Well that is a god damned shame.
I must say, if your "article" is anything like your typical thread posts, it should be an "entertaining" read if nothing else.
Page generated in 0.21408 seconds with 11 queries
