![]() | | #1 | ![]() |
![]() Join Date: May 2011 Location: Portage, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,113
Groans: 83
(Thread Starter) | Not Ranked : 0 score So my question is how hard is it to remove the lower passenger side mount (connected to the motor not the car) I'm assuming it's sum gay shit involving me taking off the valve cover, timing cover, etc.) Thanks in advance.......
__________________ -#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo -1970 Chevelle - Needs full resto |
| 6 mods and some Kool-Aid ![]() Join Date: Mar 2008 Location: Jax, FL
Rep Power: 28978 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,271
Groans: 856
| Not Ranked : 0 score I think you are halfway there. @jbarone might have a good idea, he sells replacement mounts. |
| The Following 2 Users Say Thank You to Raider For This Useful Post: | rghispanic88 (11-07-2011), TexasSpeed3 (11-08-2011) |
![]() Join Date: Apr 2010 Location: Miami FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,836
Groans: 263
Groaned at 73 Times in 43 Posts
__________________ 2010 Black Mica 2004 EVO 8 Green Monster The "7up" | |
![]() | | #4 | ![]() |
![]() Join Date: Aug 2009 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score Naw, it's pretty easy to get it out. You'll need a jack and a pair of jack stands, tho. And, you'll need a new pair of mounting bolts at least, but I don't know the size. The hardest bit might be getting the nuts off the broken bolts to reuse. If you're very nice to Jamie Barone (e.g. buy one of his PMMs to make it worth his while), he might help you out. I'm shocked that the bolts would shear off before the mount failed. Or, did the mount fail, too? Stock mount, I assume?
__________________ 08 MS3 GT (SSM). JBR WP intake, CS boost tubes, Forge v2 BPV, JBR TB/IM TIG, JBR TB coolant bypass, JBR EGR block-off, 3-bar MAP, PTP pill, bnoon bolt, SM OCC (MD kit) w/ Kat's heater, UR DP (ceramic cat), UR resonated TP/CBE, JBR SSP, SU shift bushings, JBR trilogy mounts (CRMO 88 RMM, 70 PMM/TMM), Koni yellows, JBR RSB, 2nd Fiamm, Stoptech SS lines, Hawk HPS, spin-on CX-9 oil filter, Fumoto valve, PP 5W-30, XT-M5-QS, tints, clear bra, Continental DWS, ITV22, DashHawk, AP, AT internals
![]() | | #5 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7119 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
Groans: 28
| Not Ranked : 0 score Man I've never seen the stds break. I beleive replacement bolts are 12mm x 1.25 x 30mm; I would verify that firs.The studs from the dealer are like $17.00 each so go with bolts and get a high grade of bolt as well and one of my passenger mounts would be strongly recommended. I'd like to see pics if you have time. Thanks, Jamie |
| The Following 3 Users Say Thank You to JBR For This Useful Post: |
![]() | | #6 | ![]() |
![]() Join Date: Mar 2011 Location: Bastrop, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,208
Groans: 273
| Not Ranked : 0 score pics would be nice
__________________ 2011 Black Mica - Daily JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp |
![]() | | #7 | ![]() |
![]() Join Date: Feb 2011 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
| Not Ranked : 0 score Damn......not good -Jake
__________________ New: 2012 Mazda MX5 Miata True Red |
![]() | | #8 | ![]() |
Groans: 83
(Thread Starter) | Not Ranked : 0 score Sure I will post pics. This most have been a problem for awhile and the torque inventually caused them to snap. I really don't know how the hell this happened. So much for case hardened bolts. The mount on your side is pretty sweet unfortunately the studs are stuck on the engine side mount which looks like the mount is 1 piece with the timing cover.
__________________ -#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo -1970 Chevelle - Needs full resto Last edited by MSFer87; 11-08-2011 at 07:12 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #9 | ![]() |
![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 427
| Not Ranked : 0 score Before doing anything, wouldn't this be covered in the 5 yr powertrain warranty? |
| The Following User Says Thank You to JLee1469 For This Useful Post: | TexasSpeed3 (11-08-2011) |
![]() | | #10 | ![]() |
Groans: 83
(Thread Starter) | Not Ranked : 0 score Eh........good question I assumed I was WAY out of warranty the car is a 2007 with 65,XXX on it
![]() | | #11 | ![]() |
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,450
| Not Ranked : 0 score There's not enough left of the studs to double-nut them out?
__________________ 2009 MS3 sport MGM |
![]() | | #12 | ![]() |
Groans: 83
(Thread Starter) | Not Ranked : 0 score NO sir just a nice clean separation in the bottom mount. When I get the timing cover off (fucking crank pulley is a dirty slut) I'm going to take it to a machine shop it's the only way.
![]() | | #13 | ![]() |
Groans: 83
(Thread Starter) | Not Ranked : 0 score Man that was fun having to remove the crank pulley and all the other shit in the way to remove the timing cover, what is that thing torque to 200lbs. The engineers at Mazda can suck my taint for designing the fucking motor mount and timing cover together as one piece.
![]() | | #14 | ![]() |
| Will fuck up ur day ![]() Join Date: Feb 2010 Location: Parrish, FL
Rep Power: 4200 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,803
Groans: 433
| Not Ranked : 0 score yes, it's torqued on to almost 200 ft-lbs. lol.
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. |
![]() | | #15 | ![]() |
Groans: 83
(Thread Starter) | Not Ranked : 0 score That's what it seemed like that bitch wasn't budging.
![]() | | #16 | ![]() |
Groans: 433
| Not Ranked : 0 score look in the FSM at the torque specs. After torquing the damn thing down, i had to use a 4' breaker bar to turn the bolt more as called for.
| The Following User Says Thank You to Chimmike For This Useful Post: | MSFer87 (11-11-2011) |
![]() | | #17 | ![]() |
Groans: 83
(Thread Starter) | Not Ranked : 0 score I'm going to have to go to the library and get the torque specs
![]() | | #18 | ![]() |
![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,795
Groans: 89
