-   -   What the heck, man? (http://www.mazdaspeedforums.org/forum/f10/what-heck-man-25674/)
sleeper3 04-15-2009 02:44 PM
What the heck, man?
So I put on my Cobb FMIC and turbo inlet about 3 weeks ago, and all was well. Took the car to the track, and started feeling this weird thing in 5th gear. Like at about 105 MPH (I don't know the RPMs but whatever 5th @105 is) it would stutter once. Now I can't get pas about 15lbs of boost without it doing the same thing. I've been trying to notice weird fuel pressure readings on my dash hawk or a fluttering boost needle, but I don't see anything weird. Any thoughts? I am sure it is just boost cut or fuel cut, but is there something I can log on my dash hawk to know for sure? it's freaking me out, man!
aaronc7 04-15-2009 02:47 PM
RPM,boost,AFR,fuel pressure,AbsThrottle
Start with that I guess, its too bad you can't do more than 5 parameters at once...especially since you gotta hit 105 mph to log it, lol
and FYI that's about 5k rpm
gsrtype1 04-15-2009 02:51 PM
Not that Cobb has a bad fmic but why didn't you just keep your ETS top mount and get meth injection?
sleeper3 04-15-2009 02:52 PM
I will log that stuff on my way to church tonight and post graphs. lol
nah I don't have to hit 105 to do it anymore. As long as boost is above 15psi in 3rd or 4th, it starts happening. it's very frustrating.
I think it's weird that it didn't start happening right away with the new parts. Also, I noticed that my TPS never goes above 70%, and it seems like it's closing when this is happening. not sure though, the logs will tell more, I am sure.
because I wanted the cobb fmic.
Grim 04-15-2009 02:53 PM
fmic is always superior to a tmic,aftermarket or not.
sleeper3 04-15-2009 02:55 PM
All I've got to say is top mount - 13.5, front mount 13.3
bykeryder4life 04-15-2009 02:57 PM
as long as the fmic is properly designed and flows well then screw a tmic.
gsrtype1 04-15-2009 02:57 PM
Meth + ETS is 12.5.
sleeper3 04-15-2009 02:59 PM
Originally Posted by gsrtype1 (Post 204106)
Meth + ETS is 12.5.
says who?
No one has done that. No one.
Grim 04-15-2009 02:59 PM
Meth + ETS is 12.5.
meth+fmic=better times.
Cobb definitely did their homework. This thing is the bee's knees.
gsrtype1 04-15-2009 03:02 PM
Until I see proof of that I am skepitcal... I have almost 0 pressure loss with my ets and my boost temps go below abmient. How much better can that get?
sleeper3 04-15-2009 03:16 PM
um, explain why boost temps would ever be below ambient temps?
gsrtype1 04-15-2009 03:25 PM
Meth injection.
sleeper3 04-15-2009 03:51 PM
Originally Posted by gsrtype1 (Post 204123)
Meth injection.
lol so it doesn't have anything to do with the intercooler at this point. The alcohol evaporating has a far more pronounced effect on the air temp than an intercooler could.
gsrtype1 04-15-2009 04:01 PM
lol Exactly! why did you get the fmic?
gsrtype1 04-15-2009 04:06 PM
If you just wanted it I respect that but my point is you had the beutiful 3.5 ets why not just get meth for $250 instaed of $1000 for fmic + the posablity of pressure loss...
Renzokuken 04-15-2009 04:17 PM
Probably because its HIS car and he can do what he wants with it?
serium 04-15-2009 04:34 PM
ETS + meth FTW........cobb fmic for the ladies. Im stuck i want the fmic for the looks but i want the ETS + meth for the $$ and same result without pressure drop...what to do what to do.
Unoriginalusername 04-15-2009 05:11 PM
Meth + ETS is 12.5.
meth doesn't gain anything on the dyno... a local guy dyno'd less running meth than a similarly modded car without. reliability is a different story, but you are not going to gain a second at the track or any hp at the dyno with meth.
Car 1 (not mine)
CPE TBE, CPE intake, Cobb FMIC, Cobb AP, Meth injection, forge bpv
Car 2 (not mine)
TurboXS TBE, Injen CAI, Turbo XS FMIC and bpv
This was on the early Cobb maps, i am sure 103 would do better based on my results with the different maps.... anyways long story short the meth didn't help car 1 pull any better numbers
kingpin748 04-15-2009 05:13 PM
I don't know where people get this idea that TMIC are better than FMIC. There not. Period.
I'm not saying TMIC suck, they work just fine but all things being equal a FMIC is better.
aaronc7 04-15-2009 05:15 PM
someone should just run a pipe from the turbo to the throttle body, no intercooler, just meth, hahaha.
wow way offtopic, post up the logs when u can!
kingpin748 04-15-2009 05:15 PM
If you tune for meth is will make a difference. Nobody here does that and it's not the greatest idea for a DD.
Everyone here runs the meth because it's magically going to stop the engine exploding.
aaronc7 04-15-2009 05:18 PM
spraying a small amount of meth with no tune u should not lose power. any loss in power will probably be offset by the gain in cooler BATs. spraying tons of meth without tuning for it has definitely shown losses for people...
I use the d03 nozzle and I think it added some powa, maybe just gave me a little more low/mid torque, i dunno. But it definitely didnt slow stuff down. And car seems to run more consistent which I like.
Unoriginalusername 04-15-2009 05:19 PM
For the OP, any tuning? sure you don't have a lose boost hose?
On some cars yes, on DI i haven't seen the huge gains that meth has allowed on other cars.
Better hope you don't run out if you build your tune around it
the ETS isn't free... i think you are forgetting that in your math
Crossbow 04-15-2009 06:59 PM
Dump a pile of ice on the TMIC, then it'll match the FMIC for one run...lol.
killa cam 04-15-2009 07:07 PM
perfect application:
http://www.evsmpi.net/tbird/TBirdEngine030704.jpg
LOL
Frequentflyer 04-15-2009 07:26 PM
That's old school right there.
Anyway, not sure how we got onto the TMIC vs FMIC debate, but back on topic. Did you check your plugs and do the coil spring stretch mod?
martyxattack 04-15-2009 07:48 PM
give it time. ive had mine since dec.31st and i will say fitment sucks. and before anyone asks yes a i have a rear mm.
aaronc7 04-15-2009 08:09 PM
look at that turbo inlet pipe!! lol
Unoriginalusername 04-15-2009 08:33 PM
then you installed it wrong... its a pita, but when done properly it fits just fine
sleeper3 04-16-2009 05:31 AM
because it's MY car and I do what I want with it!
sleeper3 04-16-2009 05:34 AM
so true!
I don't think I had any pressure drop... maybe it was so insignificant that I didn't notice...
sleeper3 04-16-2009 06:12 AM
yeah, mine fits great. no issues whatsoever.
Also, I am having a heck of a time getting my dashhawk to talk to my computer. I am installing and uninstalling every version of the software to figure out what will work. bear with me please.
And no, I haven't done any coil stretching or anything. is there a chance that it could fix the problem?
sleeper3 04-16-2009 06:42 AM
This stupid thing is not working ANGRYFACE
gsrtype1 04-16-2009 07:29 AM
Car 1 (not mine)
Car 2 (not mine)
Bro you are incorect for sure! I dynoed 267whp without meth at 17.5psi and 291.7whp with meth at 19psi on the same dyno, same tune about 80 dgrees out both times. You think I gained 25hp form 1.5psi? More Hp = better track times, how do you think Darksun made all his power on the stock turbo? = meth
phantom6294 04-16-2009 07:34 AM
I hate to ask the obvious... but are you using the latest version from the DH website? Second, what OS are you running. DH just doesn't want to place nice with x64 versions. Also, people have had issues with Vista and the UAC. On top of all that, however, it seems nothing about the software is consistent. People report success with certain steps, another person mirrors those steps and it just doesn't work. I have Vista x64 and finally resorted to VMWare with an old Win2k CD I have to use my DH.
sleeper3 04-16-2009 07:37 AM
I'm running XP, and I've finally got it talking to the DH, but it keeps saying that there is not a log on the device... I "updated" the dashhawk, and I'm going to run another log during lunch. Hopefully it will work.
Page generated in 0.20996 seconds with 11 queries
