What RPM to launch at? Mods are in Sig...never really launched on a dig but its about time I learn in this car. What RPMs are you guys launching from? |
street i would launch around 2800, drop the clutch with dsc all the way off. i only got four runs at the track when i went but my best 60' was a 2.145 from dumping the clutch at like 3400. |
It is going to depend on your track surface, temperature and your tires. On the street, with my mods in sig, I roast the tires hopelessly at anything over 2,300 rpm, even trying to feather the damn thing, and get bad wheel hop in second too. On the track here, depending on temps, I can launch at 2,400 to 2,500 rpm without too much spin. But, I'm probably the wrong guy to ask for advice, because my 60 ft. times still suck. 2.2's if I'm lucky. Too many 2.3's still. I just don't have the right technique yet. Runs like a banshee once she hooks, up, though. Need stickier tires, but mostly need the driver mod. lol. |
6k |
I find myself never having to really launch, just take off normally to get yourself rolling and then get on it and go! You'll probably still roast your tires and get a ton of wheel hop if you don't have a RMM or grippy tires, but it's better than roasting 'em off the line. |
not many mods here...but normally i launch at 3k but i dont dump it...i just let it out like i normally do...just a little bit quicker...i get the clutch to the point where it is right about to engage...then release and floor it....having it almost to engagement really limits the drop on the drive train...plus smooth clutch work while shifting (not drop it) always feels so much faster |
on the street... i just take off normally and then get on it... |
26-28psi front / 38-40psi rear Don't go thru water 2400-2600rpms slip clutch out modulate throttle to limit wheel spin power shift into 2nd at ~5500rpms 2.0 - 2.1 60ft (consistently) |
ms3077 what tires are you on? |
Currently I have Michelin Pilot Sport 2's - 225/40/18 (haven't tried these yet) |
cant wait to take my car to the track only had it for a couple months....thankz for the input...but OP r u getting any fuel cutoff? cuz ur sig doesnt mention a hpfp n alot of the bigger guys on here say it is necessary once u put in a DP |
Have you guys tried drag radials or is that too much for the front end to handle? |
Set the wotbox up @4400rpm and build boost drop the clutch and hope the m/t et streets 245/45/17 hook and the box/clutch/drive shatfs dont stay behind on the line |
AWD FTMFW |
mines set at 4500 right now, not gonna be dumping the clutch tho, always slip it. |
I've found launching at 2500-3000 rpms (depending on conditions) works the best. Got a 2.1 60ft on all-seasons. |
What about using wotbox at 5000 ft over sea level with a shitty track? I was thinking on setting it up to 2800 rpm (Right now is @ 3200 rpm and wheels spin as a bitch!) |
| All times are GMT -7. The time now is 07:46 AM. |
