 Old 05-12-2013, 07:27 PM   #1
Elvisrosales88's Avatar
Posts: 113   (View Stats)
Elvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the world
Groaned at 9 Times in 2 Posts
Default What sensor is this?
My friends broke this sensor while removing his hpfp. Does anyone know what sensor this is? Perhaps a part #?
My guess is that's is its a Temperature sensitive as its on what looks like a coolant hose.
Someone please shed light on this?
Sent from my SPH-L720 using Tapatalk 2
Cobb AP+ Stratified OTS--JBR Powerpath Stage III intake-- Turbosmart BPV--AutoTech Fuel Pump Internals--CPE TMIC-- OBX test pipe+ UR catback--ITV-22 plugs-- H&R springs--CPE RMM- JBR PMM and TMM--
Elvisrosales88 is offline   Reply With Quote
 Old 05-12-2013, 09:15 PM   #2
valveking35's Avatar
Posts: 64   (View Stats)
valveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond reputevalveking35 has a reputation beyond repute
Groaned at 8 Times in 3 Posts
Flux capacitor.
Sent from my DROID RAZR using Tapatalk 2
valveking35 is offline   Reply With Quote
 Old 05-12-2013, 09:38 PM   #3
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
coolant temp sensor
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
Sensor 1 low input(Knock sensor)? SpeedKAF MazdaSpeed 3/6 - Turbo Induction 0 07-02-2011 10:30 AM
Page generated in 0.24239 seconds with 22 queries
