-   -   ??What size hose?? (http://www.mazdaspeedforums.org/forum/f10/what-size-hose-72682/)
drknyte 02-17-2011 05:50 PM
??What size hose??
I`m attempting to install a water temp gauge and was wondering what size is our upper radiator hose?
I did some searching and found 31mm but I wanted to make sure.
I order a 32mm water temp. sender:
Water Temperature Sender Radiator Hose Adaptor
They only have 30mm and 32mm adapters so I went with the 32mm cause I figure the hose can stretch a little and I`d rather it be tight than loose.
Any thoughts or opinions....
Thanks!
Page generated in 0.17133 seconds with 11 queries
