 Old 10-19-2009, 11:42 AM   #1
Sniper2606's Avatar
Posts: 569   (View Stats)
Sniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the world
Groans: 33
Groaned at 32 Times in 15 Posts
Default What will give more power CAI or SRI
i have a SRI and i keep hearing the CAI gives more power? is this true? what about water problems since the intake its all the way down
Sniper2606 is offline   Reply With Quote
 Old 10-19-2009, 11:46 AM   #2
E4Performance's Avatar
Posts: 690   (View Stats)
E4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the world
Groaned at 69 Times in 65 Posts
CAI will give you low end torque. SRI will give you top end HP
E4Performance is offline   Reply With Quote
 Old 10-19-2009, 12:48 PM   #3
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
Both are hugely serious power mods for this engine. Either one will give you very significant power gains in both hp and torque. There will be a firestorm of debate regarding which is better. There are very technical reasons to support each view which mostly have to do with whether and to what extent the CAI actually provides colder (and denser) air to the engine compared to the SRI and whether there is any really serious risk of hydrolock from the typical CAI design if you are stupid enough to drive through really high water.
Suffice it to say that the debates, IMHO, are more academic than real world important, given the big gains this engine gets from either and the relatively modest, if any, differences in performance between designs. Either way is a big improvement over the POS stock air box. My personal preference is CAI, but I respect the views of those who prefer the SRI.
Finally, I must respectfully disagree with the observation here of our vendor regarding power down low and up high. I don't think there is much difference, and the data seems to suggest that the modest differences are only present at WOT and tend to support the opposite conclusion -- a little bit more punch down low from the SRI and a bit more high rpm, high engine load performance (trap speeds, etc.) from the CAI.
The Following 2 Users Say Thank You to MSMS3 For This Useful Post:
glocK23 (10-19-2009), ms3077 (10-19-2009)
 Old 10-19-2009, 12:59 PM   #4
It's actually oppsite MSM because at high rpm, the car is trying to suck air in quicker to feed the turbo and the engine. The SRI gives the shortest tract and therefore the quickest airflow. It may be different based on dynos with different pipe sizes, but CP-e uses 3" on both the SRI and CAI and showed top end was > on the SRI due to shorter run.
 Old 10-19-2009, 01:48 PM   #5
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
Honeslty you talking maybe about +/- a few crank hp and for the money to spend to get a cai its not going to be worth it. Plus if you plan on going fmic, its definatley not worth it cuz most kits use their own intake.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
 Old 10-19-2009, 02:05 PM   #6
Kdawg207's Avatar
Posts: 2,389   (View Stats)
smart man
my 2 cents CPE Nano - FTW
Kdawg207 is offline   Reply With Quote
 Old 10-19-2009, 02:15 PM   #7
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
actually, CAI gives you top end and on the low end, CAI has the same amount of power as SRI.
so if you want more power and top end, go with the CAI.
im going to be switching back to CAI b/c of this reason
wakeboardude and i put it to the test a few times. our cars were equally modded he had SRI i had MSCAI.
up to about 75mph, we were dead even everytime...pure drivers race but after that, my car would pull ahead everytime.
2015 Mazda 6
 Old 10-19-2009, 03:14 PM   #8
reddeerspeed3's Avatar
Posts: 689   (View Stats)
reddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the world
sportcompactcar did a fairly extensive test on this using a wrx about 9 months ago. they concluded that SRI's gave more high end HP and CAI's more low end TQ due to resonant frequencies or some technical shit like that. and like nyghtryder said, who gives a shit over 2-3 hp vs. 2-3 ft-lbs. either one is a huge improvement. if you get a CAI, buy a quality hydrosheild that fits properly. if you get a SRI, buy a cold air box to help fight heatsoak
reddeerspeed3 is offline   Reply With Quote
The Following 2 Users Say Thank You to reddeerspeed3 For This Useful Post:
E4Performance (10-19-2009), ms3077 (10-19-2009)
 Old 10-19-2009, 03:26 PM   #9
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
You can't really compare two different cars as well; some are factory freaks, some turds. For example, I have an SRI raced a buddy with same mods except his got CAI; I pulled a couple cars to 120+ plus but that didn't really prove anything as mentioned.
I know at least one member who didn’t get any real significant gains with intake/ test pipe but my car got huge gains; he’s got an 09, me an 08. I’m holding ~ 18psi on stock tune, he not even a tad over stock boost. Apparently there’s weird shit going on between different model years.
The 2010 MS3 response great to bolt ons according to corksport, they got like 40hp/tq with just intake/ inlet/ test pipe, holding ~18.5psi like I'm doing. So I'm wondering if the 09's got some kind of issue?
But yeah CAI, SRI doesn't really matter both huge gains.
MSMS3, you should stick around here more often, screw 24/7.
ms3077 is offline   Reply With Quote
The Following User Says Thank You to ms3077 For This Useful Post:
MSMS3 (10-19-2009)
 Old 10-19-2009, 03:34 PM   #10
BoostIsBetter's Avatar
Posts: 582   (View Stats)
BoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the world
Groans: 32
Groaned at 31 Times in 18 Posts
not this debate again.
please do a search!!!
BoostIsBetter is offline   Reply With Quote
 Old 10-19-2009, 03:39 PM   #11
IshiKage's Avatar
Groans: 278
not sure, there could be something up witht he tunes of 09s or ecus better yet.
but we are both 09s
CAI's have shown higher hp gain and CAI's take in cooler air than SRIs. so SRI's giving a better top end over CAi makes no sense to me
2015 Mazda 6
 Old 10-19-2009, 03:42 PM   #12
wankular's Avatar
Posts: 4,343   (View Stats)
Who cares about the technical crap? I prefer an SRI because the filter lookes sweet in the engine bay.
2009 MS3 sport MGM
 Old 10-19-2009, 03:56 PM   #13
ms3077's Avatar
Groans: 974
but we are both 09s
Probably but enough to make a significant gain vs. the other. Doubtful, what most everyone is saying is that neither one makes enough power over the other to really justify one superior. Perhaps the CAI takes in cooler air but how much cooler to you think that air is? Once the car is moving air does in fact get directed through the engine bay and this is reflected via. Dash Hawk monitoring.
Myself including many other members here have witnessed intake temps to be within +/- just 2-4 degrees off real ambient temps using a SRI. So how much to you think those couple degree cooler temps are worth? Probably not much, then you got to take the other aspects into consideration like price, installation, maintenance, etc. Also, say if you do indeed get say 5hp more with a CAI; does it off set the better throttle response and other pluses you get with a SRI? And if those 5hp or so aren’t realized until 120mph what’s the point?
 Old 10-19-2009, 04:00 PM   #14
silverspd3's Avatar
Posts: 298   (View Stats)
silverspd3 is a splendid one to beholdsilverspd3 is a splendid one to beholdsilverspd3 is a splendid one to beholdsilverspd3 is a splendid one to beholdsilverspd3 is a splendid one to beholdsilverspd3 is a splendid one to beholdsilverspd3 is a splendid one to behold
Groans: 43
i have the cp-e cai love it never had a problem with it.. bought the pre-filter works great and with there design the filter angles up away from the ground and the bumper is sealed off pretty well only holes their are is in the wheel well and i never felt my filter wet.. i have seen water spots inside the engine bay to so a sri is gonna get a lil wet to but not enough to harm. It would take a lot to suck in water with this car unless u drive trough 2-3 ft of water and if u do see a puddle just coast through it (no gas) or drive around it and most puddle's are on the right side of the road and the intake is on the left.. i Bought a cai mainly because i don't like the idea of sucking in all that hot air from the engine bay but both sri n cai are both good for this car.. i felt more high end gain from the cai then low end gain. and its not hard to change the filter either just the matter of turning the wheel's all the way to the right and unscrew the 3 or 4 screws in the wheel well then u have access.
And I disagree with E4 statement about the sri giving faster airflow.. only thing true about that is as soon as u give it gas it will be quicker b/c of the shorter pipe but once ur already moving it doesnt matter
Thats my 2 cents
forge bpv, cp-e cai
silverspd3 is offline   Reply With Quote
The Following User Says Thank You to silverspd3 For This Useful Post:
IshiKage (10-19-2009)
 Old 10-19-2009, 04:01 PM   #15
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
It seems logical that a cia would give more hp cause its not breathing the hotter air of the engine bay.
The Following User Says Thank You to gsrtype1 For This Useful Post:
 Old 10-19-2009, 04:04 PM   #16
ms3077's Avatar
Groans: 974
Thats my 2 cents
The air ain't all that "hot" once moving (+/- 2-4degrees ambient) and throttle response will matter everytime you let off the throttle unless of course you're power shifting. But when you’re just cruising around in gear and decide to downshift “throttle response” comes into play
 Old 10-19-2009, 04:10 PM   #17
IshiKage's Avatar
Groans: 278
dude, the air is hotter with SRI. have you had both? i have. the thing that improve with SRI vs CAI was throttle response. the amount of time it took the air to stop in the CAI was longer thus making it feel a bit sloppier.
but power wise.
CAI>SRI in terms ofpower. cooler air=more power
2015 Mazda 6
The Following User Says Thank You to IshiKage For This Useful Post:
acidbbg (11-19-2010)
 Old 10-19-2009, 04:12 PM   #18
silverspd3's Avatar
Groans: 43
True but whats the diff like .5 secs.. or less and true once u get moving there is air flowing through the engine bay but r engines get hot as fuck.. but to each his own.. this battle could go on all day.. i like both.. both r great upgrades for this car.. cant lose on either one.
forge bpv, cp-e cai
 Old 10-19-2009, 04:12 PM   #19
glocK23's Avatar
Posts: 1,753   (View Stats)
glocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the world
Groans: 701
I initially had Cobb SRI, switched over to CP-E CAI, then to CP-E Nano, then back to CP-E CAI.
The cobb sri felt snappier than cp-e nano. the cp-e cai felt very nice low-end and top end. I kept the CP-E CAI over the Cobb and Nano.
If I had to choose which intake from CAI to SRI, it would be
CAI = CP-E Xcel CAI
SRI = Cobb SRI
Just based on personal placebo experience
glocK23 is offline   Reply With Quote
The Following User Says Thank You to glocK23 For This Useful Post:
karl-hungus (10-28-2009)
 Old 10-19-2009, 04:12 PM   #20
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
i think the differences in hp and tq are negligible
The Following User Says Thank You to rodrigo For This Useful Post:
ms3077 (10-19-2009)
 Old 10-19-2009, 04:13 PM   #21
mazdaj's Avatar
Posts: 369   (View Stats)
mazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the world
i ran with the bottom splash shield off and a cpe cai in 1-2 ft puddles of torrential rain and i came out ok...despite what people think it takes alot to hydrolock. the things i did to test motor mounts for cpe....lol
mazdaj is offline   Reply With Quote
 Old 10-19-2009, 04:22 PM   #22
dizzin9's Avatar
Posts: 1,807   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
Groaned at 39 Times in 27 Posts
think about it this way: would u rather have a short or long penis?
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg
Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB
J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19
dizzin9 is offline   Reply With Quote
The Following 5 Users Say Thank You to dizzin9 For This Useful Post:
E4Performance (10-19-2009), glocK23 (10-19-2009), IshiKage (10-19-2009), silverspd3 (10-19-2009), zoom1&zoom2 (10-28-2009)
 Old 10-19-2009, 04:30 PM   #23
wankular's Avatar
Depends on who you're asking.
2009 MS3 sport MGM
 Old 10-19-2009, 04:31 PM   #24
IshiKage's Avatar
Groans: 278
I had a penis reduction and I'm not liking the change, nor is the bitch. Even though I don't really need a cai since I have fmic, my intake temps have def gone up b/c of the extra metal in the engine bay
2015 Mazda 6
 Old 10-19-2009, 04:33 PM   #25
ms3077's Avatar
Groans: 974
This sums it up.
 Old 10-19-2009, 06:39 PM   #26
ATAZ's Avatar
Posts: 314   (View Stats)
ATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond repute
Simple solution for SRI getting cold air. Take the ram air piping out of the battery and allow the TMIC ducts to supply colder air. It literally sits right in front of the SRI....so therefore ur always getting cold air and the SRI is way easier to clean.
just my $.02
ATAZ is offline   Reply With Quote
 Old 10-19-2009, 07:04 PM   #27
ms3077's Avatar
Groans: 974
just my $.02
Or you could just fab something up to have 2 air ways (still have air going to bat) this way you'll get true ambient vice 2-4 warmer but big deal right? lol. I’m glad you pointed this out, now I have something to burn some time on as I’m pretty bored right now.
 Old 10-19-2009, 07:05 PM   #28
i've been trying to think of a decent way to do this without hacking that plastic all to shit. i'm more likely just gonna port one of these into my CAB
 Old 10-19-2009, 07:19 PM   #29
acmhd7's Avatar
Posts: 460   (View Stats)
acmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the worldacmhd7 is the leader of the world
Glad this topic came up again because I never thought about searching and probably would have went with a CAI before this thread. Some good points have been brought up on both ends.
CIA - Cooler air....well thats about it.
SRI - Wayy cheaper, easier to clean, no issues if go with a FMIC...if I ever decide to.
The two points that are selling me on the SRI are price and ease of cleaning. I dont think the HP #'s on the two are that different enough to warrant $100+
acmhd7 is offline   Reply With Quote
 Old 10-26-2009, 12:08 PM   #30
Sniper2606's Avatar
Groans: 33
thanks for all the replies i will stay with my hks sri lol, last thing since some people brought this up, whats the deal with the FMIC and the SRI? because i have both on my car
 Old 10-26-2009, 12:11 PM   #31
IshiKage's Avatar
Groans: 278
i think some are under the assumption that you cant run CAI with FMIC when you can
2015 Mazda 6
 Old 10-28-2009, 01:07 PM   #32
Sniper2606's Avatar
Groans: 33
quick question how do i clean the intake filter just blowing air to it?
 Old 10-28-2009, 01:18 PM   #33
ms3077's Avatar
Groans: 974
Use an air duster (like the ones used for cleaning electronics) to blow off dirt/ debris. After this use a mild detergent under cool water to clean / rinse the filter clean. Let dry naturally or sit next to a fan; don't blow dry under heat! Re-apply thin layer of oil if it's an oiled filter like Cobb's; don't over oil!
 Old 10-28-2009, 09:22 PM   #34
snowms3's Avatar
Posts: 287   (View Stats)
snowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond repute
yah definitely dont over oil. my buddy did that on his car and it ruined his maf sensor 500 bucks later he learned his lesson. thats 500 he could spent on parts for his car. but the way its been explained to me about sri vs. cai is that short ram will provide initial torque because its a smaller tube thus any turbo lag you may experience may be gone and cold air intake will take you mid range to higher rpms but i too believe the gains are so subtle it doesnt matter too much. its just a personal pref
snowms3 is offline   Reply With Quote
The Following User Says Thank You to snowms3 For This Useful Post:
ms3077 (10-29-2009)
 Old 10-28-2009, 10:12 PM   #35
rapha82's Avatar
Posts: 8   (View Stats)
rapha82 will become famous soon enough
nice to know
rapha82 is offline   Reply With Quote
 Old 10-28-2009, 11:21 PM   #36
zoom1&zoom2's Avatar
Posts: 404   (View Stats)
zoom1&zoom2 is the leader of the worldzoom1&zoom2 is the leader of the worldzoom1&zoom2 is the leader of the worldzoom1&zoom2 is the leader of the worldzoom1&zoom2 is the leader of the worldzoom1&zoom2 is the leader of the worldzoom1&zoom2 is the leader of the worldzoom1&zoom2 is the leader of the worldzoom1&zoom2 is the leader of the worldzoom1&zoom2 is the leader of the worldzoom1&zoom2 is the leader of the world
I have a MS6 and I have tried the cobb sri and my ms cai back to back, no dyno or track but I'll share my findings. The sri showed a IAT change of 20-25 degree's warmer, and it did effect hp, car felt more sluggish. Down low and up top. The part I did like about the sri is it quieter outside and inside. It also will stay 100% dry. But I went back to the MSCAI. IAT temps dropped back down and the power came back up. Another thing is the cobb has the built in air flow straightner, and my MScai does not have one. I saw no differences in anything how the car drove in that respect. But not all of us seem to need a straightner. As for wet weather, I have driven in alot of standing rain, had the dryflow filter soaked, but I stayed out of the throttle as much as possible, and when I got home I checked the inside of the tube by the MAF sensor and there was no water. Now I have a K&N filter with a prefilter. The prefilter and the oil in the K&N are great water deterrents.
2007 mazdaspeed6 & 2007 mazda 6 wagon gt 3.0
zoom1&zoom2 is offline   Reply With Quote
 Old 10-29-2009, 12:35 AM   #37
ms3077's Avatar
Groans: 974
20-25 warmer IAT's?? That doesn't make sense at all! I think you're confusing BAT's (boosted air temps) with IAT (air intake temps).
With an SRI; IAT's (air intake temps) will be on avg just + 2 -4 degree's from true ambient (the air a cold air intake should be taking in) once moving forward; those few degrees aren't enough to yield substantial gains.
Plenty of people have confirmed this to be true. If you're seeing much higher than +4 degrees IAT's with an SRI that's only because you're still; once moving the IAT's go down al most immediately; just a few short secs.
Driver311 actually did back to back DYNO runs with CAI / SRI and found that niether yielded substantial gains over the other; this is right in tune with everything my self and the majority of the board have concluded.
I mean honestly there’s really no good reason to run a CAI vice an SRI here. You can say what you want but the facts are the facts; unless of course you're hell bent on the idea of possibly getting an extra 2-3hp for the first 3-5secs of a run.
 Old 10-29-2009, 01:11 AM   #38
glocK23's Avatar
Groans: 701
Does it even matter about temperature? I mean that shit is negligible , it's all going into a hot ass turbo regardless.
FML.
ms3077 (10-29-2009)
 Old 10-29-2009, 05:59 AM   #39
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Go with the SRI. Cheaper, more safe, easier to install/uninstall/service the filter and hp difference is not enough to really feel the difference. If your ass can feel a <5whp difference in a car with this amount of power to begin with, you've got a real sensitive ass!
 Old 10-29-2009, 06:07 AM   #40
Thermonuclear Skeet
FantasmoNegro's Avatar
Posts: 2,810   (View Stats)
FantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the world
Groans: 188
Groaned at 333 Times in 222 Posts
MSCAI and your warranty will stay intact.
El Fantasmo Del Negro
Helicopter Cat LIVES
FantasmoNegro is offline   Reply With Quote
The Following 2 Users Say Thank You to FantasmoNegro For This Useful Post:
acidbbg (11-19-2010), jrp (05-26-2010)
Will adding meth/water spray give me any power gain? Sloane MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 11-30-2008 03:13 PM
Antec True Power Trio TP3-550 ATX12V 550W Power Supply with Three 12V Rails $49.99 at newegg Haltech Hot Deals Section 0 04-16-2008 09:40 AM
COOLER MASTER Real Power Pro 750W Power Supply $59.99AR at ZipZoomfly Haltech Hot Deals Section 0 04-14-2008 05:00 PM
CoolerMaster Extreme Power 650W ATX Power Supply $49.99AR Haltech Hot Deals Section 0 04-08-2008 09:50 PM
Antec Neo Power 500 ATX12V 500W Power Supply 100Vac to 240Vac $69.99 Free Shipping Haltech Hot Deals Section 0 04-01-2008 09:41 PM
Page generated in 0.59802 seconds with 42 queries
