 Old 08-07-2018, 12:14 AM   #1
Mashaustin's Avatar
Posts: 12   (View Stats)
Mashaustin is an unknown quantity at this point
Default Wheel Hub/Wheel Bearing Replacement
So i need to replace my wheel bearing & i might as well replace the wheel hub, c clip, and axle nut and this is my first time so im just making sure i got all my ducks in a row.
How To: Front Wheel Bearing Replacement
OP linked to a wheel hub that is no longer sold, and i go to looking on rock auto, this is a kit from SKF, anyone confirm if it will fit? it has everything i need/want, but i dont want to get everything apart and have to be stranded and wait on parts.
https://www.rockauto.com/en/moreinfo...sn=381&jsn=381
Im hoping to get the knuckle assembly out, and have a shop press the bearing out and in, and doing the rest myself with hand tools and loaners
EDIT: Side not any tips or tricks for unstaking the axle nut? i didnt know about this and i am unsure how i am going to approach it
Mashaustin is offline   Reply With Quote
 Old 08-07-2018, 07:30 AM   #2
Shwaykid's Avatar
Posts: 646   (View Stats)
Shwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the world
I have a press. I'm on the North side of town off 620 if you want some help. I haven't done one on a speed, but I've done both sides of my 200sx. Pretty sure it'll be similar. I couldn't find a shop in Austin or Cedar Park that would press out the bearing for less than $100.
2008 Mazdaspeed3 GT
JBR TRU 3.5 Aluminum WP // Corksport TBE // JBR OCC Stage 2 // AP v3 (Tweaked [by me] E40 Tune) // Autotech Internals // Stratified EBCS // TWM Full Replacement w/ Type R Knob // CP-e Stage 2 RMM // JBR/Damond Full EGR Delete // Synchronic DV // NGK 6510s // FMIC [TR8 w/ JBR Pipes] // CorkSport Adjustable Struts/Lowering Springs // Progress RSB
Jet Black Wax (06/24/2017)
Better compression than Silaramic (02/20/2016)
Shwaykid is offline   Reply With Quote
How To: Front Wheel Bearing Replacement Constantin MazdaSpeed 3 - How-To's 55 04-28-2019 01:19 PM
Bad Wheel Bearing or Hub? qkrthnu2 MazdaSpeed 3/6 - Suspension & Brakes 3 05-28-2015 12:43 PM
Wheel bearing jracer MazdaSpeed 6 - Engine, Transmission & Driveline 94 11-09-2013 06:19 PM
Front wheel bearing replacement radioflyer MazdaSpeed 3/6 - Suspension & Brakes 1 06-02-2012 09:29 PM
Bad Wheel Bearing?? emag remrofni MazdaSpeed 3 - Engine, Transmission & Driveline 4 01-15-2012 09:43 PM
Page generated in 0.24779 seconds with 21 queries
