-   -   While changing my spark plugs. (http://www.mazdaspeedforums.org/forum/f10/while-changing-my-spark-plugs-157438/)
561BlackMS3 10-20-2013 07:43 PM
So I was changing my spark plugs today and when I look into my intercooler I see this:
http://img.tapatalk.com/d/13/10/21/8amy4era.jpghttp://img.tapatalk.com/d/13/10/21/hapebeby.jpg
I don't think that's normal for it to be that dirty. The car doesn't smoke at all.
jk_ms3 10-20-2013 07:44 PM
Time for an OCC.
561BlackMS3 10-20-2013 07:47 PM
OCC??
Tokay444 10-20-2013 07:49 PM
Occ
561BlackMS3 10-20-2013 07:50 PM
What's an OCC?
Code Monkey 10-20-2013 07:52 PM
:D
Block8head 10-20-2013 07:54 PM
Originally Posted by 561BlackMS3 (Post 2305309)
What's an OCC?
Let me google that for you
561BlackMS3 10-20-2013 08:01 PM
Originally Posted by Block8head (Post 2305314)
Wow that was a blonde moment on my part, especially since I had a Mishomoto one on my KIA.
561BlackMS3 10-20-2013 08:15 PM
Thank you guys.
speed23 10-20-2013 08:18 PM
I had exactly the same thing. I assumed it was oil that was cooked into carbon dust.
BigRedSpecial 10-21-2013 05:32 AM
Occ isn't going to do anything for oil in the intercooler hotside...
561BlackMS3 10-21-2013 05:41 AM
What else could it be? I'm not smoking so I'm assuming it isn't my seals.
BigRedSpecial 10-21-2013 05:48 AM
Seals could be leaking on the compressor side but not enough to smoke... or you could have excessive blow by. I'd pull your TIP and check for oil from the VC hose
Tokay444 10-21-2013 01:00 PM
are you catted?
561BlackMS3 10-21-2013 03:38 PM
Originally Posted by Tokay444 (Post 2306183)
are you catted?
The car is completely stock.
Tokay444 10-21-2013 07:17 PM
Ok. Running two oem cats will mask A LOT of smoke.
561BlackMS3 10-21-2013 07:36 PM
Oh ok, we'll I'll pull the tip this weekend and see.
Tokay444 10-21-2013 07:42 PM
Do a compression and leak down test.
561BlackMS3 10-21-2013 10:53 PM
I'll let you guys know what happens this weekend.
06Speed6 10-22-2013 12:37 AM
+1
561BlackMS3 10-27-2013 09:49 PM
Quick update:
Took off my air box, and I can see the stain of oil coming from the vacuum hose. I did a compression test and all cylinders would go up to 210 at every interval then taper down to 180 and hold it (+/- 2).
Tokay444 10-28-2013 01:52 AM
As in the other thread, something is wrong with your gauge if it's "tapering down" as you say. Assuming you didn't run a leak down test.
breakfstincluded 10-28-2013 01:57 AM
Originally Posted by 561BlackMS3 (Post 2305306)
OCC??
http://upload.wikimedia.org/wikipedi...ppers_logo.jpg
561BlackMS3 10-28-2013 07:40 PM
Originally Posted by breakfstincluded (Post 2315465)
LOL.. well did it again and its 179-181-180-182. I didn't do a leakdown test. So now time to go shopping for an OCC.
Tokay444 10-29-2013 08:01 AM
unsubbed.
BigRedSpecial 10-29-2013 02:45 PM
And again...
Page generated in 0.19033 seconds with 11 queries
