![]() | | #121 | ![]() |
![]() Join Date: Nov 2009 Location: Pensacola FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 659
| Not Ranked : 0 score
BNR has definitely helped. Now i just gotta get the suspension caught up.
__________________ 2010 BM MS3 BNR S3 HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines Works emotions cr-kai 18x7.5 ventus v12s for the street TRM C3s 17x9 Hankook RS3s for track days ![]() STRATIFIED TUNED Other Mazdas in my stable 2010 VR MS3 Wifes Ride ETS TMIC JBR RSB JBR SSP JBR knob AT internals 1999 Miata gtx2867 1.9L VVT built like a brick shithouse 2001 Miata LS RB FSB Hawk HP+ pads Dunlop ZII | |
![]() | | #122 | ![]() |
![]() Join Date: Feb 2011 Location: Lancaster, PA
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score Thanks for the info Mandinca. I will open up my valve cover this weekend and take a look at it. The sound I have is pretty faint, but audible with the windows open and fan turned off. But it has been atleast 3 years since I had a look inside the valve cover. This would be a great excuse for me to open it up . I can also look at the cams for wear and the timing chain while at it...And question - Do i have to take apart the VT to see this fitting? Or remove this fitting? Or is it visible from the outside? Hey, thanks again. Ren.
__________________ 07 MS3 with MS CAI. Last edited by Ren; 03-25-2013 at 08:53 PM. | |
![]() | | #123 | ![]() |
![]() Join Date: Mar 2012 Location: Middletown, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 5 Posts
You might need to turn the engine over to see the button (as it might be on the underside depending on where your engine stops) but you won't need to take it apart. Check your chain for slack as well while you're in there although you can do that through the filler cap. Also, check the cam cover for wear marks on the timing chain end. Little nicks in the underside could indicate a loose or worn chain. As you know, these are interference engines, a broken chain is catastrophic. Anyway, you're most welcome. I learned a lot from these forums so just trying to pay it forward. Let me know how it turns out. | |
![]() | | #124 | ![]() |
![]() Join Date: Jun 2008 Location: Midwest
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 477
| Not Ranked : 0 score Closing in on 162,000 miles in my 2007 ms3 and running strong! Have seen a few north of 175k and even 188k on the 100,000+ mile club thread in the General section. I get between 25 and 28 mpg most of the time. I bought her off the showroom floor, without bothering with a test drive, and have never looked back. Only mods are: - MSCAI - AP with Stage 1 tune - have been running an ancient v107 map for a long time. Finally looking to play with ATR, just upgraded to v2.31 map today. Major work needed has been as follows: - 43,000 - tranny went out; the needle bearing cage basically dissolved. Covered by warranty; replaced clutch since it was open. - 105,000 - replaced all bushings - not cheap. They were torn up by our bad roads up here. - 130,000 - oil pump sending unit replaced, also replaced slave cylinder - 148,000 - AC compressor seized, melted the belt, destroyed alternator - $2000 in repairs. The timing chain was also making some noise, so replaced that and the VVT. I do seem to go through tires for some reason. Favorites so far are my current Continental ExtremeContact tires. I run 40r's. Current status: - small spot of rust by taillight :-( I have fixed most other dents and such - might be using a little oil between oil changes - possibly 1/2 quart? - original turbo, never any smoke (other than from my tires) - had to pull the horn fuse a while back - it would decide to go off at weird times. Couldn't find the cause. - I wish my cat would die so I would have no choice but go to a Cobb dp I also have a red 2012 speed3 with 16,000 miles - my wife drives it. I love my genwon!
__________________ 2007 Sunlight Silver MazdaSpeed3 Sport | BNR S3v2 | Autotech Internals | Cobb TIH | 3BAR MAP Sensor | Denso itv-22's | MSCAI | ETS 3.5" TMIC | Synchronic DV | Stratified EBCS | Guardian Angel | UR Test Pipe | Cobb AP | Koni Yellows | JBR RMM | CORN YEAH! | 265,000m | Tuned by STRATIFIED!!! To install: CPE SafeSeals 2012 Velocity Red MazdaSpeed3 w/Tech | Autotech Internals | Sure Aeros V2 | 98,000m |
| The Following 4 Users Say Thank You to BackRoads For This Useful Post: |
![]() | | #125 | ![]() |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
![]() | | #126 | ![]() |
| Not Ranked : 0 score Yes, it's legit. I will have to snap a photo of the odometer - should have done that when it hit 160,000. I am nuts about the car, and think I must have gotten a good one, again other than the tranny problem which thankfully showed up under warranty. (I also have photos from my service guy of what the tranny parts looked like - I should post them too.). I have driven it pretty hard over the years, which has mostly shown in how I go through tires. I drive about 30,000 miler per year - it's about a 95-mile round trip for me to work every day. I have gotten very good life out of the brakes, though. I guess I am always trying to go faster, not slower. :-) About to start self-tuning with ATR - ran a few logs the other night, and saw I was consistently pulling from 2500-6500 in about 6 seconds in 3rd gear, with an OTS map, with only a CAI as physical mods. Excited about what I might unleash through tuning. :-) Hopefully I will not finally blow the turbo in the process.
![]() | | #127 | ![]() |
![]() Join Date: Mar 2013 Location: Alton IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
Groaned at 10 Times in 7 Posts
| Not Ranked : 0 score 79250 no problems to date
__________________ [SIGPIC][/SIGPIC] 2006 MS6... Cobb AP/ SU SRI / Magnaglow exhaust / BOV / Hawk Pads / slotted drilled rotors / Driver mod / much more to come.... 2004 suzuiki hayabusa with some secerets... shhh ![]() |
![]() | | #128 | ![]() |
![]() Join Date: Jan 2013 Location: OKC THUNDER
Rep Power: 0 ![]() ![]() ![]() Thanks: 1
Groaned at 29 Times in 9 Posts
Went over a few big potholes and divided median hard, still run very good with.. Passenger mount fluid leaked.. Turbo is doing fine Engine has no leak but Pivot trans. shaft seal leaks ( cost $7 at dealership). delayed the repair bc it's stopped leaking. Brakes replaced at 145K miles as well as the rear shocks. Everything is orginal Oh..engine takes about haft quart of oil every 1000-1500 miles. Maybe its has turbo leaks? | |
![]() | | #129 | ![]() |
If they come off easily the whole job takes an hour, if that. There's a write up here - HOW-TO: shaft pivot seal replaced I make some additional comments on the second page, make sure you read them. Your passenger mount, same thing, half hour to replace if the bolts aren't done up with a dealer air ratchet. Mine were so I had to take it to a shop to have them loosen them half a turn. I bought a stock mount from rockauto.com for under $50 incl shipping. | |
![]() | | #130 | ![]() |
| Not Ranked : 0 score I had its trans fluid top again already last week..No more leaking so far. MAP sensor check engine came on again today.. I had it changed last month, don't know why but will clean it out I will keep an eye on the seal for leak..other than that timming chain loose abit after 168k ![]() |
![]() | | #131 | ![]() |
| Not Ranked : 0 score I've been driving around with a CEL for a month now, probably the O2 sensor since I'm using a quart of oil every 200 miles. Replacing the turbo as soon as my rebuilt KO4 comes. Hopefully that fixes the issue. Good to hear that you got a good one, amazingly on it's original turbo. |
![]() | | #132 | ![]() |
![]() Join Date: Sep 2012 Location: Philadelphia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 257
Groaned at 97 Times in 19 Posts
Probably tappin dat ass
__________________ 2011 Speed3 BNR S3 / HTP 3" Intake / Grimspeed EBCS / AT Internals / Cobb AP / UR Catless TBE / ETS TMIC / Forge V1 BPV / JBR 88 Duro RMM / Eibach Pro kit / SPC Camber Arms Freektune in progress | |
![]() | | #133 | ![]() |
![]() Join Date: Jul 2012 Location: Toledo, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,271
| Not Ranked : 0 score 97K on my 2007. Original Turbo with no issues, VVT replaced at 80K. No issues besides VVT warranted by Mazda |
![]() | | #134 | ![]() |
| Not Ranked : 0 score |
![]() | | #135 | ![]() |
![]() Join Date: Apr 2011 Location: La Grange, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score Addendum. 156+K miles. Just had the timing chain, guides, tensioner and VVT actuator replaced. Boku $$$$$. Would have done it myself but no garage. I did do the shaft pivot seal in the driveway and it was way easier than the thermostat. Ren - a lot of extra work but you may as well go whole hog and replace the timing chain, chain guides and tensioner. Because if the VVT is bad, pin or otherwise, the chain and all that mess should be replaced as well. To Mandinca's point, these are interference motors and the chain will stretch as you drive like you should...
__________________ 2007 Red MS3: 4" ported PTE 5858, HTP intake, HTP undermount, Treadstone TR8, HKS BOV (VTA), Custom exhaust mani, V-band dp, CNT exhaust, ACT clutch, ACT 6-puck PP, Damond PMM, RMM & TMM, Koni yellows, Eibach prokit springs, Damond OCCs (vented & not). |
![]() | | #136 | ![]() |
| Not Ranked : 0 score Updating my Original engine 2006 MSP 6 170,000 Miles... Engine has no leaks except the pivot shaft shifter seal fill oil nearly a quart every 1000 miles or so..I think oil leaks at turbo seal. |
![]() | | #137 | ![]() |
![]() | | #138 | ![]() |
I'm working on my turbo now and trust me, it's a bitch. I got everything off last weekend except the oil drain pipe which bolts to the underside of the turbo. I couldn't get to the bolts so had to put everything back...yeah, I was seriously pissed. 9 hours in total for nothing. I've been told that it is possible to do it if you remove the downpipe completely but I'm also told that you have to support the engine on a floor jack, unbolt the mounts and rock the engine forwards to create space to remove the downpipe. F me Mazda. My dealership quoted $1200 in labor. I've asked them to tell me how their techs do it. Haven't heard back yet. Yeah I know. The light is off again right now. I'm guessing it was for missfires due to the oil coming through the turbo or past the rings. Last edited by Mandinca; 04-19-2013 at 02:05 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #139 | ![]() |
Test wheel with hand placed at 12 and 6 o'clock positions, wheel is tight. Dont have any issue with tires neither. Michellin Primacy flat-free tires ($134 at Direct Discount Tires) are supper! | |
![]() | | #140 | ![]() |
![]() Join Date: Apr 2012 Location: Tacoma, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 104
| Not Ranked : 0 score 07 speed 3 just hit 100k yesterday. Nothing really big has came up yet and I hope not |
![]() | | #141 | ![]() |
| Not Ranked : 0 score Keep an eye on your oil consumption. My wife's CX-7 used all the oil between changes at around 120K. Blew the motor. |
![]() | | #142 | ![]() |
| Not Ranked : 0 score Ya just took mine to the shop 2 days ago. Getting clutch replaced and finally getting a downpipe lol. Also the boot on the joint ripped. So I'm getting it fixed next time I get a dyno. So far that's it. Nothing major |
![]() | | #143 | ![]() |
![]() Join Date: Jan 2011 Location: Vancouver BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 130
FML. Have a coolant leak and a transfer case leak.. and that. Definitely no bilsteins, sway bars or ball joints now
__________________ 2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km Leakdown results was 50% or more across all four. slow rebuild in progress Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses. Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB. SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate. Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs. To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters | |
![]() | | #144 | ![]() |
Coolant leak ? Should be easy enough to fix if you can find it unless it's one of the turbo coolant pipes which will take some work to get to. Transfer case - common issue on these cars. Is it definitely the transfer case or could it be the pivot seal on top of the transmission (where the gear cables attach) ? That is also a very common place to leak and the tranny fluid runs down under the car and all over the underside of the transfer case....look down in your engine bay to the transmission to see if you have fluid pooling on the cover where the cables are. If it is then it's an $8 part and a two hour repair. There's a pivot shaft seal "how to" on here. Good luck. | |
![]() | | #145 | ![]() |
Thanks for the informative reply - quite appreciated.
__________________ 2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km Leakdown results was 50% or more across all four. slow rebuild in progress Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses. Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB. SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate. Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs. To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters | |||
![]() | | #146 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
I fucking love MSF!
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
![]() | | #147 | ![]() |
"It's what we do on here" Or, to give you a better idea of what kind of community we have, one of the other members practically forced me to let him do a motor switch on my MS6 when I have the money available. Some really great guys in here. | |
![]() | | #148 | ![]() |
Have you had a look for yourself ? The transfer case looks like the attached picture. Yeah, timing is not a job for the non-mechanically inclined. As for the transfer case/pivot shaft seal....dry that pivot shaft plate off as well as you can and dry off the underside as much as possible as well then drive a few miles and see if the plate gets wet before the transfer case does. If it does it's most likely the pivot shaft seal. The hardest part about changing it is undoing the engine mount on the transmission. If it's so tight you can't undo it take it to a tire shop or somewhere and ask them to loosen it a turn. I had to do that once, cost me $10 to buy the guy lunch. The rest of the job is easy, just follow the how to and you'll have it done in under 2 hours. No special tools needed, just a good metric socket set and pliers....and a tube of instant gasket for the transmission plate you have to remove or it will leak from there instead of the seal :-) (as I found out for myself) | |
![]() | | #149 | ![]() |
![]() Join Date: Aug 2013 Location: Alpharetta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
| Not Ranked : 0 score Just bought a 08 MS3 with 110k on it. Runs just fine with just a Cobb intake and HKS BOV. Previous owner said he didnt have any issues with the car and mazda inspected it before I bought it and didn't find anything major wrong with it. After a few weeks now I just hit 111k and still getting use to driving a manual again as well as getting use to the car, which isnt hard its pretty easy. Im hoping to keep it as long as I can I love it. |
![]() | | #150 | ![]() |
As for the transmission mount, I'm having the dealership do the vvt tsb, transfer case re&re and added the jbr side mounts to that install while they're at it.
![]() | | #151 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score '08 ms3, 57k miles, owned it for about 10k now...no problems so far, not even a CEL and i'm fully bolted minus a front mount!
__________________ TurboXS: Downpipe, Racepipe, Catback, FMIC C-PE: RMM, TIP, Nano Intake AutoTech Internals, Custom Tuned |
![]() | | #152 | ![]() |
![]() Join Date: Jul 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Just bought a 07 MS3 with 192k. Going to drive it until the engine blows and then do a rebuild. So far, the car is running great. |
![]() | | #153 | ![]() |
Sent from my HTC One using Tapatalk 2
![]() | | #154 | ![]() |
| Not Ranked : 0 score Is that 192k yards ? What did the previous owner do, work in a different hemisphere ?
__________________ Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM |
![]() | | #155 | ![]() |
| Not Ranked : 0 score I paid 5k. I have no idea what the previous owner did. Thing still runs like a champ, though. I just bought it as a cheap, fun car to take overseas with me. |
![]() | | #156 | ![]() |
Now is this miles or kilometers lol. Sent from my HTC One using Tapatalk 2
![]() | | #157 | ![]() |
![]() Join Date: Jun 2013 Location: Orange County NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 383
Groaned at 9 Times in 6 Posts
| Not Ranked : 0 score 07 ms3 101,000 miles new clutch @80k o2 sensor @99k ko4 inspected/new seals @90k only repairs that i know of. running stupid fast till zoom boom
__________________ ![]() 99 JEEP WRANGLER SPORT 4 liter- 5 speed- RCD BILTEIN 4" lift -32X12.5" tires-Xtreme 15"x12" wheels-JET Stage 2 ECU- K&N Intake-TB Spacer -Banks Power Monster Header back exhaust-Hurst short throw shifter-Fender Flares w/ clear corners -brush guard -Fog kit-8500lbs winch -tail light guards-Sound bar 2007 Sunlight GT Crash Smash Boom ZOOM ZOOM = HTP Full Metal 3" // CS SRI FMIC // Cobb AP // Autotechs // CS TP & CBE // Stock Block // Stock Turbo // Ralco RZ Shifter // JBR 88 RMM + 80 PMM + Spherical Knob + SSP + WEIGHT + Bushings // Saiko Michi OCC // Cobb Springs // KYB FRONT & BACK // Tri-point rear links // Redline hood shocks // Gen2 VC // RICE = Rally Armor // 20% Tint All Around // Weather Tech // JDM Goodie Visors // CF Eyelids // Red/Black CF Dash Kit // Bumper Covers // Extra Sub Mod //Stuby Antenna//Red&Blue Interior L.E.D. // 50w 10 L.E.D. Cree Reverse lights ![]() |
![]() | | #158 | ![]() |
![]() Join Date: Apr 2013 Location: Seattle, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,526
I wanna see an Odometer photo! As for me 107000 miles on a 2009. | |
![]() | | #159 | ![]() |
![]() Join Date: Sep 2011 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
Groans: 24
Groaned at 166 Times in 32 Posts
| Not Ranked : 0 score Yeah for $5000 I would buy the car just for parts...even if it's a 1st gen. Would have a spare block, turbo, ecu, transmission, fuel pump, everything.
__________________ - 2010 Mazdaspeed 3 Black Mica - - Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 - - SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace - - CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint - |
![]() | | #160 | ![]() |
| Not Ranked : 0 score I just passed 140k today. '06 MS6 that drinks more oil than I care to mention. Ok, a qt every 200 miles.
| Approaching 1000 miles on built engine | JumpingJackson | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 03-21-2010 12:01 PM |
| MS 3 original body kit | 0001 | MazdaSpeed 3/6 - Wheels & Tires | 1 | 09-20-2009 06:40 AM |
| Wanted-- MS 3 original body kit | 0001 | MazdaSpeed 3/6 - Appearance | 0 | 09-20-2009 04:17 AM |
| Mazda 3 Speed 5 Door Needs / Blown Engine 14K miles | kingpin748 | Mazdaspeed3/6 General Discussion | 12 | 03-13-2009 10:01 AM |
