Like Tree60Likes
 Old 11-25-2015, 10:52 AM   #201
Tex06's Avatar
Posts: 13   (View Stats)
Tex06 is an unknown quantity at this point
1982xx today. Original Motor, no smoke yet, original transmission but 3rd gear synchro was replaced in it (Don't think PO did the clutch though). Definitely need to look into bushings/body mounts, this thing rattles and clunks in the back end like crazy on these NOLA roads.
BackRoads likes this.
Tex06 is offline   Reply With Quote
 Old 11-25-2015, 03:09 PM   #202
voodoo2crue's Avatar
Posts: 371   (View Stats)
voodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the world
Nola is hard on the suspension.
2012 MS3 VRM/w Tech
Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom
1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather
Plugs-NGK LTR7IX-11(6510)
Oil-RP 10/30
Tires-235 40 18 Federal 595 rsrr
Brakes-EBC Yellow pads with ATE 200 fluid
Check out my wheelwell page here. If your a member hit me up.
https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/
voodoo2crue is offline   Reply With Quote
 Old 11-28-2015, 12:41 AM   #203
Tex06's Avatar
Yeah, I'm worried my SSR IIIs will be done in by some of the small lakes (potholes) here. If I don't know the road real well, bet your ass I'm doing the speed limit. Already had a curb trash my bumper as I was trying to leave Rouses....
Hit 199,870 coming back from TX today. Getting close to the big 200k.
 Old 11-28-2015, 06:37 AM   #204
Balthazar's Avatar
Posts: 168   (View Stats)
Balthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the worldBalthazar is the leader of the world
Won't be beating anyone here, 90k but turbo replaced around 60k, warrantied at least.
Balthazar is offline   Reply With Quote
 Old 11-29-2015, 04:09 PM   #205
WillP's Avatar
Posts: 224   (View Stats)
WillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond repute
For all of you high mileage speeds what oil are you guys using? I purchased my speed6 with 54K not sure what they used before but I started with Rotella. I switched to Amsoil for two changes then back to rotella. I just rolled over 100K and I know keeping the oil levels where they need to be helps with longevity of engines. Also, regular 3-4K oil changes helps from what I am reading. Please share.
2007 Titanium Gray ll Metallic Mazdaspeed6
#10227
Mods // SURE SRI // COBB TIH // CP-E TMIC w/Robert Roark Cork Gasket // COBB AP V3 // AUTOTECH HPFP // MD SSP // JBR RMM // H&R Springs // 3" Str8 Pipe-Beast Mod //
Freektune OTS+ // ITV22 // Kevdog Tow Plate
WillP is offline   Reply With Quote
 Old 11-29-2015, 04:40 PM   #206
KennyFish's Avatar
Posts: 552   (View Stats)
KennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the worldKennyFish is the leader of the world
I'm at 99k on my '10 cat less dp the last 10k turbo is close to its last leg. I run t6 but even that isn't keeping the white smoke at bay anymore. Time for a corksport
KennyFish is offline   Reply With Quote
 Old 11-30-2015, 04:31 PM   #207
Tex06's Avatar
Mobil 1 high mileage. Anything over 100k gets it. Anything under gets the regular full synthetic stuff.
Only vehicle that doesn't is the GFs VW. It's gotta have special oil because, Germany.
Stupid Krauss.
 Old 12-09-2015, 04:20 PM   #208
TinyVoices's Avatar
Posts: 17   (View Stats)
TinyVoices has a spectacular aura aboutTinyVoices has a spectacular aura aboutTinyVoices has a spectacular aura about
I'm at 105k on the stock turbo and motor. No smoke at all and burns less than a quart every 5k miles.
2006 Mazdaspeed6 Sport
TinyVoices is offline   Reply With Quote
 Old 12-09-2015, 06:50 PM   #209
rguzman56's Avatar
Posts: 106   (View Stats)
rguzman56 has a reputation beyond reputerguzman56 has a reputation beyond reputerguzman56 has a reputation beyond reputerguzman56 has a reputation beyond reputerguzman56 has a reputation beyond reputerguzman56 has a reputation beyond reputerguzman56 has a reputation beyond reputerguzman56 has a reputation beyond reputerguzman56 has a reputation beyond reputerguzman56 has a reputation beyond reputerguzman56 has a reputation beyond repute
Groaned at 10 Times in 3 Posts
I keep using Castrol Syntec 530. If it's not leaking, keep using synthetic. If you see any leaks, use the high mileage.
Sent from my D6616 using Tapatalk
I'm also at 115k on original turbo
Injen Intake, Cobb V2, Koni Yellows, DDM HIDs, X-Pel Smoke Headlight Protectors and Graco Convertible Car Seat
Last edited by rguzman56; 12-09-2015 at 06:50 PM. Reason: MSF Database - Automerged Doublepost
rguzman56 is offline   Reply With Quote
The Following User Says Thank You to rguzman56 For This Useful Post:
WillP (12-10-2015)
 Old 12-09-2015, 07:13 PM   #210
TinyVoices's Avatar
I use Rotella t6. My car burns less than a quart every 5k miles.
The Following User Says Thank You to TinyVoices For This Useful Post:
WillP (12-10-2015)
 Old 12-09-2015, 08:14 PM   #211
BackRoads's Avatar
Posts: 575   (View Stats)
BackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the world
I have been using just your basic oil for 217,500 miles and am burning a quart about every 3,500 miles, self-tuned until 188,000 miles and now pushing 25+ lbs of boost since then.
2007 Sunlight Silver MazdaSpeed3 Sport | BNR S3v2 | Autotech Internals | Cobb TIH | 3BAR MAP Sensor | Denso itv-22's | MSCAI | ETS 3.5" TMIC | Synchronic DV | Stratified EBCS | Guardian Angel | UR Test Pipe | Cobb AP | Koni Yellows | JBR RMM | CORN YEAH! | 265,000m | Tuned by STRATIFIED!!!
To install: CPE SafeSeals
2012 Velocity Red MazdaSpeed3 w/Tech | Autotech Internals | Sure Aeros V2 | 98,000m
BackRoads is offline   Reply With Quote
 Old 12-09-2015, 10:27 PM   #212
doctavus's Avatar
Posts: 1,728   (View Stats)
doctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the world
Groaned at 29 Times in 23 Posts
What basic oil are you using?
doctavus is offline   Reply With Quote
 Old 12-09-2015, 10:33 PM   #213
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 283
Probably autozone conventional brand.
sent from my Nexus 6P
 Old 12-10-2015, 04:40 AM   #214
BackRoads's Avatar
I had the dealership do my oil changes up to about 175k or so - they commonly gave me a free loaner, so it was convenient. I have purchased several cars from them, so they treat me well. So, whatever they put in.
Since then, I have my friend here in my small town do it, since his shop is just a few blocks away and he's a great guy. So, whatever he puts in.
I have like three jobs, so it is worth the time I save.
I did replace my turbo (with a BNR) at 188k, but it never smoked.
Last edited by BackRoads; 12-10-2015 at 04:40 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-22-2016, 01:24 PM   #215
BackRoads's Avatar
Crossed 220k this morning. Rock solid.
The Following 6 Users Say Thank You to BackRoads For This Useful Post:
HawkeyeGeoff (01-22-2016), KiwiFlavor (08-02-2016), predapio (01-23-2016), redneck4Christ (08-24-2016), sxman (08-14-2016), xfeejayx (11-11-2016)
 Old 01-22-2016, 04:09 PM   #216
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
Wow
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
blackms3_71 is offline   Reply With Quote
 Old 01-23-2016, 06:30 AM   #217
IT Gnome's Avatar
Posts: 26   (View Stats)
IT Gnome is a glorious beacon of lightIT Gnome is a glorious beacon of lightIT Gnome is a glorious beacon of lightIT Gnome is a glorious beacon of lightIT Gnome is a glorious beacon of light
I crossed 211k 2 mornings ago. My engine has started burning oil real bad lately about a quart every 1k miles. Looks like I'm going to need to do some major engine work.
I've been using Castrol Syntec 10w-40 every 5k miles since the dealership replaced the turbo under warranty at 60k. That's what they used then and I've kept it up since.
IT Gnome is offline   Reply With Quote
The Following 2 Users Say Thank You to IT Gnome For This Useful Post:
BackRoads (01-23-2016), doctavus (06-29-2016)
 Old 01-23-2016, 07:17 AM   #218
Try adding lucas stabilizer. It helps
The Following User Says Thank You to blackms3_71 For This Useful Post:
IT Gnome (02-11-2016)
 Old 01-23-2016, 07:23 AM   #219
NRBt's Avatar
Posts: 29   (View Stats)
NRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to behold
196000km's for now.
Using original Mazda Dexelia 5w30 oil.
NRBt is offline   Reply With Quote
 Old 02-11-2016, 12:22 PM   #220
IT Gnome's Avatar
Default R>I.P. my faithful steed
My Speed6 died this weekend. Went out to run some errands and then tried to start it. It wouldn't start. I got towed to a nearby mechanic. He looked at and found cylinders 1,3, & 4 have only 35lbs compression and #2 has 85lbs. No indications other than the spike in oil consumption.
Anyone have a motor for cheap? I hate that I will have to give up on my Speed6. I love the car too much. This has been the first time ever in a 212K miles that it wouldn't start.
This is a very sad time right now.
 Old 06-29-2016, 08:57 PM   #221
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
Originally Posted by NRBt View Post
196000km's for now.
That's what I'm using and have been for over 100k.
I've used motul, royal purp, castrol and they all "caused" my motor to burn more oil. Royal was heinous in my block, added a quart every 2000km. Switched to Mazda synthetic due to Dale Gribbles thread.
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
 Old 07-23-2016, 11:04 AM   #222
spatton's Avatar
Posts: 10   (View Stats)
spatton is on a distinguished road
2012 with 150,000, many new engine mounts and a couple of clutches. Still does not consume oil.
Friends do not let friends drive stock!!!
K&N cold intake-Cobb TIH- Autotech Internals-Accesport2- JBR TMM, PMM and Cobb RMM-Counterweight-Steel braided lines-TSW Black 18" Pilot SupperSport-slotted rotors
spatton is offline   Reply With Quote
 Old 08-02-2016, 02:20 PM   #223
jmen73's Avatar
Posts: 63   (View Stats)
jmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of light
I had 193k on mine before I blew a valve. Now it's rebuilt with a much larger turbo...5858.
2007 Red MS3: 4" ported PTE 5858, HTP intake, HTP undermount, Treadstone TR8, HKS BOV (VTA), Custom exhaust mani, V-band dp, CNT exhaust, ACT clutch, ACT 6-puck PP, Damond PMM, RMM & TMM, Koni yellows, Eibach prokit springs, Damond OCCs (vented & not).
jmen73 is offline   Reply With Quote
 Old 08-08-2016, 09:17 PM   #224
artfuldriver's Avatar
Posts: 2   (View Stats)
artfuldriver is an unknown quantity at this point
2008 MS3- 140K- No smoke yet but there is a hesitation when under full throttle.
artfuldriver is offline   Reply With Quote
 Old 08-08-2016, 09:20 PM   #225
BackRoads's Avatar
Is it time for new plugs? That made an immense difference for me. Also used the AC Delvo top end cleaner. I was shocked at the difference.
 Old 08-08-2016, 09:25 PM   #226
Maybe time for new plugs but I replaced at 85K. Funny thing is I am not throwing any CEL !
 Old 08-08-2016, 09:26 PM   #227
BackRoads's Avatar
My bad plugs didn't throw a CEL. But they were sure ugly when I pulled them out. Might also be carbon buildup though, or a coil.
 Old 08-08-2016, 10:28 PM   #228
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Groaned at 6 Times in 6 Posts
Need compression numbers for science! That is insane.
2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE
2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too.
 Old 08-09-2016, 06:00 AM   #229
BackRoads's Avatar
I need to check compression again. Here's what I know. Way early last spring, I was noticing the car coughing at WOT. Got worried, figured engine was finally getting worn out. Compression check was not great, ranging from about 125 to 145 or so. Mazda specs say 128 and up is ok, with max of 20 difference between cylinders. Then I put in new plugs and did the top end cleaner. Cough went away, runs great. Haven't checked compression again, but oil use diminished a bit, and I recently got 26.5 mpg on a tank running E30 with an aggressive tune. At 70F or below, I commonly break traction when I downshift into 3rd and go WOT (not popping the clutch). Currently getting close to 232,000 miles. Who can ask for more?
 Old 08-09-2016, 06:35 AM   #230
Jdab's Avatar
Posts: 52   (View Stats)
Jdab is a splendid one to beholdJdab is a splendid one to beholdJdab is a splendid one to beholdJdab is a splendid one to beholdJdab is a splendid one to beholdJdab is a splendid one to beholdJdab is a splendid one to behold
About to hit 138k, car runs great, no oil consumption, no motor complaints overall. The clutch/flywheel setup supposedly changed by the PO at 115k really sucks. Could be something else but it feels really ambiguous and engages oddly. Not sure how to describe it.
Corksport Stage 2 Intake; Forge V2 BPV; Corksport Trifecta Mounts; Corksport Catback; Damond Motorsports Banjo Bolt; AP V3; Autotech HPFP; Stratified Tuned
ISC N1 Coilovers; RalyArmor Mudflaps; V-Limited S204 STI Lip; Gen 2 Wheels
Jdab is offline   Reply With Quote
 Old 08-09-2016, 08:13 AM   #231
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Mazda recommends replacing the spark plugs in these cars at every 60k miles/90k kms. That if you're using the OEMs which are basically NGK ILTR6A-8G. However, 30k miles/45k kms was poven to be the efficiency limit (past that the engine will not run great).
So basically you replaced the factory plugs at 85k, 25k over, and now you're almost due according to mazda (because you're actually 25k miles late) and you're talking like you replaced them yesterday while complaining about hesitation and ruling out the plugs just because you "just replaced" them 450 years ago
Dude... replace your plugs 25k miles ago
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 08-21-2016, 05:20 PM   #232
desertbound1024's Avatar
Posts: 36   (View Stats)
desertbound1024 is an unknown quantity at this point
2007 MS3 with 155k. Stock everything except plugs. Burns a quart of oil per 1000 miles and timing chain is loose. Compression is 180, 179, 180, 179.
desertbound1024 is offline   Reply With Quote
 Old 08-21-2016, 05:33 PM   #233
BackRoads's Avatar
Have you tried a top end cleaner? With those compression numbers, it might just be some valve buildup that is consuming oil.
 Old 08-21-2016, 05:36 PM   #234
Orangatang's Avatar
Posts: 466   (View Stats)
Orangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the world
Stock motor, trans, clutch, flywheel and turbo at 190,339
BackRoads and desertbound1024 like this.
Corksport stage 2 sri/tip, Autotech Internals, RSB,
CBE, Forge bpv, Koni FSD, Mazda Sport Springs,
ITV22, JBR PMM, JBR TMM, JBR RMM, Damond SSP
JBR SSB, CX piping with TR6, DM OCC
Dizzy Tuned
" I just don't need a stage 6, 16 puck, teflon diamond plated clutch that can snap a femur downshifting." -Raider
Orangatang is offline   Reply With Quote
The Following 2 Users Say Thank You to Orangatang For This Useful Post:
PapaBone (08-21-2016), redneck4Christ (09-30-2016)
 Old 08-21-2016, 05:38 PM   #235
No but I will try that thanks!
 Old 08-21-2016, 06:13 PM   #236
vote4chaos's Avatar
vote4chaos is just really nicevote4chaos is just really nicevote4chaos is just really nicevote4chaos is just really nice
Default 180K
just hit 180K 2007 MS3. 3rd owner. Runs. Low compression on cylinder 3. 2nd owner replaced turbo and clutch.
Planning to rebuild next year.
vote4chaos is offline   Reply With Quote
The Following User Says Thank You to vote4chaos For This Useful Post:
feldm4n (09-28-2016)
 Old 08-21-2016, 06:56 PM   #237
PapaBone's Avatar
Posts: 246   (View Stats)
PapaBone has a reputation beyond reputePapaBone has a reputation beyond reputePapaBone has a reputation beyond reputePapaBone has a reputation beyond reputePapaBone has a reputation beyond reputePapaBone has a reputation beyond reputePapaBone has a reputation beyond reputePapaBone has a reputation beyond reputePapaBone has a reputation beyond reputePapaBone has a reputation beyond reputePapaBone has a reputation beyond repute
Bravo sir. What's your secret?
Sent using smoke signals
2008.5 True Red MS3 GT
Sorry boss, not here to race; I'm taking the kids to daycare
PapaBone is offline   Reply With Quote
 Old 08-21-2016, 07:47 PM   #238
Orangatang's Avatar
Thank you. I am the third owner on my ms3. All current mods in sig is what I did to the car. The last 20k or so I have been 2gal e85 tuned pushing 19psi.
Basic maintenance, paying attention of rpm when boosting and rev matching when I need a higher gear. Most of my current driving is commute driving. T6(3-4k oci) oil for about the last 30k or so. Thinking about switching to the pp euro(5w-40) and trying that out. I just put on some bfgoodrich sport comp 2 a/s.
I want to do a valve cleaning soon since I don't think it has ever been done and throw in a new pcv valve while I am there.
Dizzy Tuned
 Old 09-26-2016, 08:13 AM   #239
BackRoads's Avatar
This little car continues to exceed expectations.
The Following 3 Users Say Thank You to BackRoads For This Useful Post:
MD1032 (09-26-2016), voodoo2crue (09-26-2016), xfeejayx (11-11-2016)
 Old 09-26-2016, 08:38 AM   #240
Damnn very nice. Stock turbo still?
Approaching 1000 miles on built engine JumpingJackson MazdaSpeed 3 - Engine, Transmission & Driveline 4 03-21-2010 12:01 PM
MS 3 original body kit 0001 MazdaSpeed 3/6 - Wheels & Tires 1 09-20-2009 06:40 AM
Wanted-- MS 3 original body kit 0001 MazdaSpeed 3/6 - Appearance 0 09-20-2009 04:17 AM
Mazda 3 Speed 5 Door Needs / Blown Engine 14K miles kingpin748 Mazdaspeed3/6 General Discussion 12 03-13-2009 10:01 AM
Page generated in 0.61836 seconds with 44 queries
