-   -   WHP Gain from a new TMIC or FMIC (http://www.mazdaspeedforums.org/forum/f10/whp-gain-new-top-mount-intercooler-front-24801/)
dcphantom 05-01-2009 11:12 AM
Originally Posted by wassup61 (Post 194713)
Lex, if the TMIC hits the cowl its because your motor mount is allowing the motor to rock or the install is too far back.
The ETS works well with the TMIC AND FMIC OTS maps.
Jeff at PG
I have the TRZ poly mount and my 3.25 still hits the cowl. It hits especially during hard 1-2 and 2-3 shifting. Granted it isn't hitting a hard as it might have with the stock mount in there, but It's still hitting. I'm taking the shroud out this weekend and will cut off the corner like Bioevolve did. I don't want to deal with a cracked cowl and would rather just cut the inch or so off. easy beezy
07slsms3 06-08-2010 10:10 PM
I have a SU TMIC and so far so good. Definitely potential 20whp with my mod list and tune...Well worth the money..The factory TMIC is a Flimsy POS !! It was the same Engineer who designed the Factory inlet pipe....Fire Him Now.:AR15firing:
cld12pk2go 06-09-2010 05:52 AM
You can see what I gained going from the stock TMIC to a FMIC here:
http://www.mazdaspeedforums.org/foru...66-9wtq-53665/
Basically, if you are already tuned to max out the stock turbo, then the gains will be minimal. The choke line on the right of the turbo's compressor's efficiency curve dictates the power potential.
ETS Michael 06-10-2010 03:41 PM
Here is a good example of the stock intercooler vs the ETS top mount.
http://www.extremeturbosystems.com/i...pmountcomp.jpg
Thanks,
Michael
Page generated in 0.17223 seconds with 11 queries
