![]() | | #41 | ![]() |
![]() Join Date: Apr 2008 Location: MS
Rep Power: 845 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
Groans: 56
Groaned at 15 Times in 14 Posts
| Not Ranked : 0 score And I think that the H23 and some of the F series motors had belt driven BSs in them as well. None of the B-series or D-series had them that I know of. |
![]() | | #42 | ![]() |
![]() Join Date: Aug 2008 Location: Medford, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 625
| Not Ranked : 0 score Yes, the K20 in my '05 RSX Type S was smooth as butta all the way to the 8,600 RPM redline (w/reflash). If you were deaf and weren't looking at the tach, you would never know you were at 8k.
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! |
![]() | | #43 | ![]() |
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score what about the volvo 5 cyl like in the S60R's and V70R's making 300 hp stock and those motors have no balance shaft, and no vibes either at idle, and are buillit proof. |
![]() | | #44 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45886 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
![]() | | #45 | ![]() |
![]() | | #46 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score |
![]() | | #47 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score balance shaft on a 1.8T audi/vw motor are on a pully as well. its called the "intermediate shaft" and must be removed fora strokin'
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
![]() | | #48 | ![]() |
![]() Join Date: Jul 2008 Location: Canton, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,233
| Not Ranked : 0 score on my 2000 pontiac grandprix i had my balance shaft gear removed when i put in a big cam. (but left the shaft in) no adverse effects, maybe a tad more vibes at idle. but at that point...having a cam i didn't feel a difference as the car was loud and shaking enough already. i know it's a completely different engine, but just my experience.
__________________ cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC | |
![]() | | #49 | ![]() |
![]() Join Date: Mar 2008 Location: In a house
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
__________________ 7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance |
![]() | | #50 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
Cooler oil, can be deleted from that list as well, there is no detectable oil temp difference. I also noticed no faster revs. I also noticed no additional hp. Anything over 4.5qt of oil is useless except for extended oil changes, its just an additional qt on oil to get all over the crank.
Also one thing I havent really thought about, the only thread I have ever seen where anyone spoke of metal in their oil or filter was Randy's thread. If people are wearing these engines out enough that crank walk is a problem then there should logicly be metal somewhere, because it doesnt just dissappear. Or maybe no one looks at their oil or filter like I do =P
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | ||||
![]() | | #51 | ![]() |
![]() Join Date: Dec 2008 Location: Kissimmee FL.
Rep Power: 189 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
![]() | | #52 | ![]() |
![]() Join Date: Nov 2008 Location: Raleigh NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
Groaned at 16 Times in 3 Posts
| Not Ranked : 0 score 06speed6, Can you elaborate on this comment for me please, "Anything over 4.5qt of oil is useless except for extended oil changes, its just an additional qt on oil to get all over the crank." Thanks, -GG |
![]() | | #53 | ![]() |
| Wide tire man ![]() Join Date: Feb 2009 Location: Indianapolis IN
Rep Power: 383 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 162
| Not Ranked : 0 score Not that it matters for this conversation, but the gears are helical cut to reduce noise. Straight cut gears are very loud.
__________________ 2012 Crystal White Pearl Mazdaspeed3 Cobb AccessPort, Autotech HPFP internals, Corksport Stage II intake with TIP and airbox, Corksport rear camber arms, Corksport catted test pipe, Denso ITV22 plugs, JBR rear sway bar and HD mounts, CP-e stage II rear motor mount, Mazda5 rear brake upgrade, Bilstein struts, Eibach pro springs. Too many wheels & tires to list. |
![]() | | #54 | ![]() |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score Considering that you need to remove the BS assembly to install a oilpan baffle/windage tray, I would deem the extra oil useful for tracking on a road course where your oil is sloshing around and the baffle/tray keeps your oil lines fed.
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() | | #55 | ![]() |
| NEC ![]() Join Date: Mar 2008
Rep Power: 473 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
Groaned at 6 Times in 6 Posts
__________________ 2006 Lotus Elise: Toy car 1999 B4000: DD / Parts hauler / SC Project 2007 Mazdaspeed 3: *sold* 2005 Corolla XRS: *sold* | |
![]() | | #56 | ![]() |
| Not Ranked : 0 score You can technically probably run our engine safely on 1qt of oil, maybe even less. The reason we have more than that is to keep the oil pickup submerged. As you are driving your car, the oil is sloshing around all over the crankcase and it is not necessarily is the bottom of the pan. As long as you are keeping the oil pickup submerged, anything past that is pure gravy. After the BSD, our cars probably have on the order of 7qts of oil, thats about what big turbo diesel trucks run, and almost 1qt of that 7 is sitting in their oil filter. So technically, after doing the BS delete, we have more oil sitting in our pan than a turbo diesel truck does. If you are tracking your car, you shouldnt be running the factory oil pan anyway.
![]() | | #57 | ![]() |
Also, if I use a big spin on filter I am able to put in almost 8 bloody quarts of oil. It worked out to be like 7.8 quarts or something ridiculous like that.
![]() | | #58 | ![]() |
| Not Ranked : 0 score Lol 8qts of oil. Dry sumps arent really streetable unless you convert to the corvette system which apparently is DD material. A good wet sump pan with a good baffle system is all the vast majority of people will ever need.
![]() | | #59 | ![]() |
| Not Ranked : 0 score So I'm curious what you think of the F2 style baffle.
![]() | | #60 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score Wow tizi huh... I habent seen this anywhere. If he blew 2 days later, there was some kind of problem. I dont think the BSD mod is to blame, unless it was done improperly or something. What kit did he use? It could be something stupid like he plugged the wrong hole. There are 2 holes right next to each other, one is just a bolt hole the other is the oil feed to the BS. Or possibly his plug or bolt came out. Either situation would cause a serious loss in oil pressure that could be devastating. Just my thoughts. I am a firm believer in the BSD mod and just dont think it caused the failure.
__________________ Turbo boost + Nitrous boost = TRU-BOOST |
| The Following User Says Thank You to TRU-BOOST For This Useful Post: | Jonp (06-06-2009) |
![]() | | #61 | ![]() |
| Banned ![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() Thanks: 4
| Not Ranked : 0 score I just want to update on my BSD. I did the F2 kit and couldn't be happier. The vibs are barely noticeable. Far less than when I did a motor mount. The biggest upside for me is that I find it much easier to match the revs for the 1-2 shift. I feel that my 1-2 is much smoother now. |
| Japanese tax break saves fuel for Nissan in U.S. | Haltech | Automotive News | 0 | 03-31-2009 01:50 PM |
| Ford says power-steering switch saves fuel | Haltech | Automotive News | 0 | 03-13-2009 11:10 AM |
| Cheap gas saves Americans $1B per day | Haltech | Automotive News | 0 | 12-28-2008 09:30 AM |
| Ford Australia saves jobs and inline-6 with big investment | Haltech | Automotive News | 1 | 11-21-2008 11:36 AM |
| Computer-controlled Skysail Saves Money, Cuts Emissions | Haltech | Computers & Technology News | 0 | 03-26-2008 01:20 AM |
