![]() | | #1 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
(Thread Starter) | Not Ranked : 0 score Here is my plan: 1st Remove the hose + PCV from the crank case and the intake tract. 2nd re-use the stock PCV and install the PCV to the crank case and run a hose venting directly to the ground. 3rd Plug the hole in the intake What this would accomplish: This would allow the gasses + oil to be vacated from the crank case under vacuums and still allow for no boost leaks. Would also keep you from having to check the OCC for oil and draining it. Only Downsides: Technically not legal because the gasses would pollute the atmosphere Let me know if this is an idea no one has thought of or if it is flawed, as i plan to do this next week |
![]() Join Date: Mar 2008 Location: Jacksonville, NC
Rep Power: 2469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 810
Groans: 60
| Not Ranked : 0 score In the OEM setup vacume in the IM will pull air from the crankcase to vent at idle and cruise, and the vacume in the intake vents the crankcase pressure at WOT. The way you want to set it up you would have no vacume acting on the pcv so you wouldn't vent much if any at idle or cruise...
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks |
I am basically eliminating only one thing, the return to the intake track. There isn't a way i could be creating vacuum.
__________________ 95 Ford PSD : 99 540i M-sport : 89 325i ![]() | |
![]() | | #4 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well it wouldn't not be using vacuum to vent, however the One way PCV valve would be open anytime not spent in boost. Thus allowing for the gasses in the crank case to vent as nessicary. Am i wrong?
![]() | | #5 | ![]() |
![]() Join Date: Aug 2008 Location: Atlanta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score you sir are asking for MAJOR OIL CONSUMPTION..
__________________ 08.5 BLACK MICA GT, CP-e CAI, Black Forge bov DEBADGED Magnaflow Catback Corksport Test Pipe TRZ Rear Mount [SIGPIC][/SIGPIC]1 Step Colder NGK's |
![]() | | #6 | ![]() |
Groans: 60
| Not Ranked : 0 score Maybe I misunderstood. The stock setup runs like this Intake Manifold>PVC>CRANKCASE>HEAD>INTAKE. What are you wanting to remove.. When the motor is operating in vacume it flows in towards the IM, when it's in boost is flows towards intake.
![]() | | #7 | ![]() |
I just want to dump the crankcase And leave the head to intake alone. Anyone have a Diagram how the PCV system works on out car
![]() | | #8 | ![]() |
![]() Join Date: Jan 2009 Location: Chicago,IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
| Not Ranked : 0 score I thought this was another hole-in-the-block-thread...sorry for the uninformative post..move along...
__________________ Black Mica 08.5 GT I'm parting out. Buy my stuff: http://www.mazdaspeedforums.org/foru...ing-out-59908/ |
![]() | | #9 | ![]() |
Groans: 60
The intake manifold is connected to the crancase throught the pcv valve, head is connected to the intake via the port on the valve cover. There is no line from the crancase to the intake.
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
![]() | | #10 | ![]() |
(Thread Starter) | Not Ranked : 0 score Fack that would make since why no one dumps their OCC to the ground
![]() | | #11 | ![]() |
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 145
Groans: 29
| Not Ranked : 0 score In states that would require inspection a VTA crankcase breather would be A)Environmentally irresponsible B)Bad for your motor C)Grounds for citation That being said, PG is working on a bolt on kit for the MS3 and MS6 -Jeff at PG
__________________ All wagon, No traction |
![]() | | #12 | ![]() |
![]() Join Date: Aug 2008 Location: Cincinnati
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 328
__________________ | |
![]() | | #13 | ![]() |
Groans: 29
![]() | | #14 | ![]() |
But justify B for me. I know you wanna sell your bolt on kit and all, but explain how it could possibly be bad for the motor.
__________________ 95 Ford PSD : 99 540i M-sport : 89 325i ![]() Last edited by jamesthebikeguy; 03-10-2009 at 07:15 PM. | |
![]() | | #15 | ![]() |
![]() Join Date: Nov 2008 Location: Fitchburg, MA
Rep Power: 273 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 546
But if you don't allow the PCV to close under vacuum and have it vent directly to the ground, basically allowing you to dump the oil right to the ground. The PCV is there to prevent anything (oil) from the crankcase to being sucked through the vacuum line and into the intake tract. The catch cans collect all the oil that is makes it past the pcv valve (usually small amounts) and usually gets sucked in the intake. | |
![]() | | #16 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score i think the reason a catch can that comes off the crankcase and does not connect back to the intake manifold is bad because it does not allow the crankcase to evacuate properly. i think you need the vacuum from the intake manifold to help it. |
![]() | | #17 | ![]() |
Groans: 29
| Not Ranked : 0 score Venting to ground would cause a vacuum leak, and god forbid your PCV fails, Oil starvation/piston ring destruction FTL -Jeff at PG
![]() | | #18 | ![]() |
![]() Join Date: May 2008 Location: Bellevue, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score That would be true if he was talking about the crankcase to intake manifold connection... He is talking about the connection from the valve cover to the intake -> turbo inlet. Which at best will occassionally spit oil into his CAI/SRI. I'm pretty sure there is no vacuum for this guy. |
![]() | | #19 | ![]() |
Groans: 29
| Not Ranked : 0 score There shouldn't be a leak for this connection to begin with unless you are pressurizing this connection which is NO GOOD. Here is what worries me the most 1st Remove the hose + PCV from the crank case and the intake tract. 2nd re-use the stock PCV and install the PCV to the crank case and run a hose venting directly to the ground. So unless the OP meant valvecover, he will be venting the CC to ground. -Jeff at PG
![]() | | #20 | ![]() |
Groans: 45
| Not Ranked : 0 score i see it as how jeff does, except ultimately also putting a plug on the intake manifold so there is no vacuum leak there. but still i don't know why you wouldn't do it like everyone else and just route from the catch can back to the intake manifold. even if you are talking about the valve cover, ron(whoosh) who put a dual vent on his and had it go to a catch can and not back to the intake, told me if he were to do it again he would change the way the baffling was in the valve cover and then just run a long hose down then back up to the intake with no catch can. |
![]() | | #21 | ![]() |
![]() Join Date: Jul 2008
| Not Ranked : 0 score sub
__________________ That pic is in a Miata. Damn midget mobile. Seat was all the way back. Mods: Turbo Inlet, Short Ram, IDRVSLO's L2AIC, TRZ RMM, Shifter Bushings, PG Mani, CS DP,HF Cat, DS Trans Mount, Stiffened Passenger MM, CDFP Internals, Saikou Michi OCC, DIY BS Delete, DIY Windage Tray. Falken 235/45 17 7.5 |
![]() | | #22 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| Not Ranked : 0 score On my Mustang I vented my crankcase to the exhaust and anything the was vented would get burned. Its what all the drag cars do.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG |
![]() | | #23 | ![]() |
![]() Join Date: Dec 2008 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 541
| Not Ranked : 0 score Adding a breather filter to the head and removing the to the air intake has been discussed before many time. I think the final determination was that it could cause your car to run a little leaner as air (post MAF sensor) could normally enter the head via that tube. Since that would be blocked off more air would enter the engine and the ECU would not be expecting this as it expects some to go to head. See this thread: http://www.mazdaspeedforums.org/foru...se-filter.html
__________________ GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP ![]() Bitwise Motorsports http://www.bitwise-motorsports.com - Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!) |
![]() | | #24 | ![]() |
Groans: 60
| The Following 2 Users Say Thank You to SSinstaller For This Useful Post: | wassup61 (03-12-2009), whoosh@Realtune (03-12-2009) |
![]() | | #25 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score WOW, so much confussion in this thread. I think he is talking about the valve cover to intake hose, if not then I have no idea what you guys are talking about. What I want to see is a unit ran from the valve cover to the exhaust system for scavange effect. With the high exhaust volume this would be ideal. |
![]() | | #26 | ![]() |
| Not Ranked : 0 score The 6's don't seem to run any leaner. I have hooked up 3 cars (ms3's) to a filter and capped the intake tube and they start to lean out under off throttle conditions. The transitoin from off to on throttle creates a little back fire. |
![]() | | #27 | ![]() |
Groans: 60
| Not Ranked : 0 score That's very odd.. I was usually right around 14.2~14.5 at cruise and light throttle, a little rich because of the diode on the second O2, but no dirveability issues...
![]() | | #28 | ![]() |
| Not Ranked : 0 score Tell me about it, there seems to be a good amount of differences between the MS3 and 6's with the PCM programming. |
![]() | | #29 | ![]() |
| Thermonuclear Skeet ![]() Join Date: Jul 2008 Location: Triad N.C.
Rep Power: 3876 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,765
Groans: 188
Groaned at 333 Times in 222 Posts
| Not Ranked : 0 score I always thought that it was vented back to the intake on a MAF system because the air in the motor was already accounted for by the MAF thus the reason it vents back into the intake after the MAF meter. Its about like the difference between BOV and BPV. I could be wrong, I usually am.
__________________ El Fantasmo Del Negro Helicopter Cat LIVES ![]() |
![]() | | #30 | ![]() |
![]() Join Date: Oct 2008 Location: Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 190
Groaned at 53 Times in 32 Posts
| Not Ranked : 0 score I was trying to wrap my head around this and Some of it doesn't make any sense to me. I was planning on doing this as follows. Remove PCV system. Cap IM run both Valve cover and CC to OCC. Vent OCC to Atmosphere. -Without the PCV system connected to the IM You have cleaner air +1 -No Pcv valve +1 -No Back pressure in CC or VC +2 -Gasses vented to Atm. -1 (But I live in Alberta so +1) -No Vacuum leaks +1 Maybe I don't understand completely. I don't know everything. But if I'm missing something please explain.
__________________ My mission is to go fast. ![]() Currently Designing: The golden girdle of the gods The CF "fuck your face" IM |
![]() | | #31 | ![]() |
![]() Join Date: Mar 2008 Location: PA
Rep Power: 1820 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,082
![]() go ahead and do exactly what was tried before and failed you obviously have not read any of the posts and experiences
__________________ 2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008) 2008 Caliber SRT4 / 11.8 @ 120 | |
![]() | | #32 | ![]() |
Groans: 45
| Not Ranked : 0 score i guess people don't understand when we say that our crankcase needs the vacuum from the intake manifold to evacuate it properly. |
![]() | | #33 | ![]() |
sometimes people don't want to listen and I'm not about to go out of my way to make him understand it's pretty simple as you know
![]() | | #34 | ![]() |
Groans: 190
| Not Ranked : 0 score Why does the CC need vacuum to evacuate? Please explain
![]() | | #35 | ![]() |
Groans: 188
| Not Ranked : 0 score Because without vacuum from the intake manifold and no positive pressure in the crankcase that shit is just going to sit there.
![]() | | #36 | ![]() |
![]() Join Date: Mar 2008 Location: sc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
__________________ I hate my mazdaspeed3 more than anything else in this world! |
![]() | | #37 | ![]() |
Groans: 190
| Not Ranked : 0 score I was digging around on another forum and thought of something. (in theory would this work?) What about running a dry sump system? would that still require you to run a PCV? or could you cap it?
![]() | | #38 | ![]() |
I've had only one car in my life that had a dry sump set up If I told you the cost of the -12 & -16an fittings, the oil pan, oil tank, and peterson pump cost me...you would think I'm totally bull shitting you to answer your question though.....your valve cover would have to be sealed as would the PCV catch tank on the front of your engine block "if" you were going dry sump the oil tank which sits next to your engine now functions as your breather
![]() | | #39 | ![]() |
Groans: 190
| Not Ranked : 0 score So cost aside. this seems to be the only way to eliminate the PCV from returning to the IM.
![]() | | #40 | ![]() |
![]() Join Date: Jun 2008 Location: New Port Richey, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,984
Groans: 88
Thanks guys!! | |
| Upcoming single vent gauge pod for MS3! | www.cp-e.com | Custom Performance Engineering (cp-e.com) | 76 | 07-09-2009 03:36 PM |
| From Cow to Crankcase: Synthetic oil from animal fat | Haltech | Automotive News | 0 | 12-03-2008 03:50 PM |
| cant find the Boost guage vent pod anywhere? | FWD=WWD | Mazdaspeed3/6 General Discussion | 5 | 11-07-2008 11:04 PM |
| Get ready to vent: Lorinser kits the new SL | Haltech | Automotive News | 0 | 09-21-2008 03:30 PM |
