 Old 03-26-2009, 01:48 PM   #41
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
Originally Posted by kgb View Post
Ok...this information helps me a bit as I just installed a Deluxe OCC from PG and am running extremely lean at idel (stft @ 25). I am using this following setup but I think I might of added an extra valve or something???...... I have the stock green valve > running to another valve, >to the OCC > then from the other OCC barb > to the crankcase. Does that sound like I set that up right?
Thanks guys!!
isn't the deluxe OCC from Ken a breather type can?
if so, you have issues
stock green PCV to OCC to another PCV or check valve to the intake manifold
*this is a sealed system*
then
back of your valve cover to a vented OCC (breather on top)
cap off your intake tube/turbo inlet
remove baffles from underside of your valve cover
and you'll be set
I've typed that probably 2 dozen times this year
I don't mind but the info is out there guys
The Following 2 Users Say Thank You to whoosh@Realtune For This Useful Post:
kgb (03-26-2009), MTuning (03-26-2009)
 Old 03-26-2009, 02:03 PM   #42
MTuning's Avatar
Posts: 362   (View Stats)
MTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond repute
Groaned at 16 Times in 8 Posts
make it ur sig
MTuning is offline   Reply With Quote
 Old 03-26-2009, 02:49 PM   #43
Bigbody250's Avatar
Posts: 258   (View Stats)
Bigbody250 has much to be proud ofBigbody250 has much to be proud ofBigbody250 has much to be proud ofBigbody250 has much to be proud ofBigbody250 has much to be proud ofBigbody250 has much to be proud ofBigbody250 has much to be proud ofBigbody250 has much to be proud of
Groaned at 227 Times in 193 Posts
Why dont you just buy one of those bad a electric superchargers on ebay hook the PCV to the suction and now you have ur vacuum...
Bigbody250 is offline   Reply With Quote
The Following User Says NO Thank You to Bigbody250 For This Un-useful Post:
 Old 03-26-2009, 03:31 PM   #44
kgb
kgb's Avatar
Posts: 808   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 88
then
and you'll be set
Yes...damnit....so the filter is screwing with the ecu...
kgb is offline   Reply With Quote
 Old 03-26-2009, 03:39 PM   #45
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
ha yeah, you are pulling in tons of unmetered air, i'm surprised it doesn't just stall out.
 Old 03-26-2009, 03:46 PM   #46
kgb
kgb's Avatar
Groans: 88
then
and you'll be set
Whoosh....thanks for the info. man....but I have to admit I am having trouble understanding the setup you suggested I guess because I tried to memorize and understand the way Cobb did theirs. I never took into consideration the one they gave instructions for (non-filter) would require me to do a different setup with mine (filter).
 Old 03-26-2009, 04:58 PM   #47
bova's Avatar
Groans: 45
you need a can that doesn't have a filter then it will be like this
intake manifold====pcv====occ(sealed can)=======pcv=crankcase
The Following 2 Users Say Thank You to bova For This Useful Post:
kgb (03-27-2009), whoosh@Realtune (03-26-2009)
 Old 03-27-2009, 10:47 AM   #48
kgb
kgb's Avatar
Groans: 88
lol...thanks...I need an "OCC for Dummies" guide.
 Old 03-28-2009, 01:43 PM   #49
kgb
kgb's Avatar
Groans: 88
then
and you'll be set
Well, I gotta say thanks Whoosh and Bova80 for bringing up the filter problems with the OCC. Like I said before, I was getting 20+ LTFT at Idle...this morning, I took of the filter and capped the OCC off. I reflashed Stage 2 SF and now my LTFT are 5 at idle and the CEL hasn't come back yet. I only have a few miles on it but will add some when I get more oil as it seems to be disappearing quickly!
Thanks again guys!
Upcoming single vent gauge pod for MS3! www.cp-e.com Custom Performance Engineering (cp-e.com) 76 07-09-2009 03:36 PM
From Cow to Crankcase: Synthetic oil from animal fat Haltech Automotive News 0 12-03-2008 03:50 PM
cant find the Boost guage vent pod anywhere? FWD=WWD Mazdaspeed3/6 General Discussion 5 11-07-2008 11:04 PM
Get ready to vent: Lorinser kits the new SL Haltech Automotive News 0 09-21-2008 03:30 PM
Page generated in 0.29813 seconds with 24 queries
