 Old 08-24-2013, 03:56 PM   #1
Blinker fluid's Avatar
Posts: 77   (View Stats)
Blinker fluid is a jewel in the roughBlinker fluid is a jewel in the roughBlinker fluid is a jewel in the rough
Default Weird boost cut issue
Hi guys, I apologize in advance if there are threads out there for this, I did some searching and found nothing to my knowledge that is the exact problem I am having.
My only two "mods"
-Cobb SF Intake, no TIP
-gutted secondary cat
So, on my way home from work today, I did a second gear pull, I make a little amount of boost, then car lost power, starting bucking almost like a hard misfire, no CEL, did it in 3rd gear too. Car runs fine other than this problem. My guess is that its either a boost leak, or a fuel pump issue? Maybe you guys could help me, thanks!
Blinker fluid is offline   Reply With Quote
 Old 08-24-2013, 09:17 PM   #2
ArmanRus's Avatar
Posts: 1,566   (View Stats)
ArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the world
Groans: 42
Get an AP, post a log.
But it seems you're getting either a boost or fuel cut. That gutted cat might be causing you to overboost.
ArmanRus is offline   Reply With Quote
The Following User Says Thank You to ArmanRus For This Useful Post:
mxlplx71 (08-24-2013)
 Old 08-24-2013, 09:43 PM   #3
Nano91's Avatar
Posts: 286   (View Stats)
Nano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the world
I would say fuel cut..
Sent from my SGH-M919 using Tapatalk 4
Black Vue Dash Cam- Cobb AP V3 (Stratified tune 4 gal E85 mix) - M2 Downpipe - Swift Springs - HKS SSQV4 - Sure V2 SRI - JBR TIP - ACDelco Rear Camber Arms - West-End Custom Alignment - White Line Bump Steer - KMD Internals - Hankook Evo V12 245-40-17 -
Nano91 is offline   Reply With Quote
Boost issue Moosheep Gen2 MS3 General Discussion 6 07-26-2013 07:04 AM
Need Help with a possible Boost Cut issue??? EddyV1987 MazdaSpeed 3/6 - Big Turbo Builds 7 04-24-2013 04:24 PM
Boost issue sriser66 MazdaSpeed 3/6 - Turbo Induction 4 03-19-2013 10:40 PM
Wierd Wierd Issue Payne Racing 67 2010 MS3 - ECU Computer Tuning 23 12-11-2012 01:48 PM
Hypertech Boost issue? ANMSPD3 MazdaSpeed 3/6 - ECU Computer Tuning 26 05-04-2010 08:48 AM
Page generated in 0.23971 seconds with 22 queries
