![]() | | #1 | ![]() |
![]() Join Date: Dec 2017
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Also, p0030 poped up. What exactly is this code? |
![]() Join Date: Apr 2016 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Not Ranked : 0 score To answer the easy question, which any Google search could have revealed, the P0030 is a front O2 sensor code. As for the rest, there's not nearly enough information in that post to even begin to start troubleshooting your issues. What FMIC kit did you use and how is your piping routed? Did you do anything else or work anywhere else in your engine bay or under the car? Is it actually going into any of the gears or none of them? You said it's not stalling in ALL the gears, but didn't say which gears it IS stalling in. You're gonna have to be a little more specific for internet troubleshooting, my man. |
| Not Ranked : 0 score Just to clarify, if you clocked your turbo for under routed piping, the O2 sensor cable runs behind your engine right where your hot pipe would go and you could have damaged your O2 sensor wiring. That wire is also connected to a bracket that lives directly above your shifter linkages, and all of that lives under your battery box. It's possible that something was knocked loose or broken during pipe routing or battery box maneuvering. I'd take off the battery box and see if anything is screwed up underneath. Then again...it's also entirely possible you fried your clutch while "testing" your new FMIC setup... Last edited by Solarsurge; 07-07-2018 at 02:04 AM. |
![]() | | #4 | ![]() |
| Not Ranked : 0 score Picture: |
![]() | | #5 | ![]() |
![]() | | #6 | ![]() |
![]() Join Date: Jul 2016 Location: Near Charlotte NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 55
| Not Ranked : 0 score Everything works...until it doesn't. Easy thing to check/do is bleed your clutch line. If that's good, you might have a bad pilot bearing binding up. With car off, I bet it goes in gear just fine.
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) |
![]() | | #7 | ![]() |
| Not Ranked : 0 score We are trying to help you but so far you have not provided enough information, have not answered questions, and seem to be dismissive of the idea that your workmanship or your driving can be the cause of your issue. I know we love to believe we are the world’s greatest mechanics and drivers, but clearly something is broken and it happened right after you worked on it and drove it. A FMIC install can explain your O2 sensor code if you’ve got a leak, but is in no way even remotely related to your transmission unless you created enough power to break it or fucked something up during install or testing. There’s your simple answer. Sent from my iPhone using Tapatalk |
![]() | | #8 | ![]() |
![]() Join Date: Sep 2015 Location: Monongahela PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score Had a similar issue that popped up right after my fmic install, the shift weight was scraping up on the cold side piping causing it to act funky. Sent from my LG-H820 using Tapatalk |
![]() | | #9 | ![]() |
![]() Join Date: Dec 2017 Location: Idaho
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
| Not Ranked : 0 score THIS
__________________ 2011 MS3 Tech - 2008 Jeep Grand Cherokee CRD - 1989 Crown Vic LTD LX - 1985 Lincoln Town Car Signature The key to happiness is owning a car ridiculously slower than your 'fast' car. |
![]() | | #10 | ![]() |
| Not Ranked : 0 score Shifter weight delete. Weight reduction. Win.
![]() | | #11 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for trying to help. I did further inspection and found out that driver side CV axle is BROKEN and not connected to the wheel bearing. The passenger side is still in one piece, the boot closest to the tranny is torn and there is some play. The noises I mentioned were coming from both axles. |
![]() | | #12 | ![]() |
| Not Ranked : 0 score Fair enough. I'll keep my eyes open for the Part-Out thread in For Sale section. . . Kidding. Glad you figured out the problem. I want to say the there are eBay axles from DTA that are well priced and have had positive reviews. I have a new pair for my 6 when the forged build goes in next week-ish. Mine are starting to click.
![]() | | #13 | ![]() |
![]() | | #14 | ![]() |
| Not Ranked : 0 score |
![]() | | #15 | ![]() |
(Thread Starter) | Not Ranked : 0 score Last edited by Meeks726; 07-21-2018 at 06:00 PM. |
![]() | | #16 | ![]() |
| Not Ranked : 0 score "Upgraded" front axles don't exist...as far as I know.
![]() | | #17 | ![]() |
| Not Ranked : 0 score I have extra OEM axles from a parts car, but we aren’t doing the engine swap until next weekend. If you still need it, it will be available then. Sent from my iPhone using Tapatalk |
| Top Gear has an Extra Gear problem | Episode Review | Haltech | Automotive News | 0 | 06-27-2016 02:40 PM |
| Top Gear gets new companion show called Extra Gear | Haltech | Automotive News | 0 | 04-27-2016 08:00 AM |
| Multi Gear pulls ignoring Gear Limits | SarcasticOne | VersaTune | 5 | 07-15-2015 05:03 AM |
| Galactic Gear is a pitch-perfect Top Gear sendup from the future | Haltech | Automotive News | 0 | 09-16-2014 11:10 AM |
| Some Say He's Tiff Needell: Fifth Gear host back at Top Gear to fill in for The Stig? | Haltech | Automotive News | 2 | 12-28-2010 07:39 PM |
