Won't go into 3rd gear It grinds when I try to put in 3rd. I have a JBR short shift plate. Thinking it's that or the synchros? |
Check your shifter cables... They might be binding |
Also, check at the shifter plate and see if the cable has come loose. |
Does it always grind or pretty much only when trying to shift under wot? |
It always grinds unless I rev match. I took it to a reputable shop today and they said the synchros are shot. ~$1000 to fix. |
Adjust the linkage. There is a youtube video. /Thread |
| All times are GMT -7. The time now is 07:32 AM. |
