-   -   WOT run with HHR SS, KR present...suggestions? (http://www.mazdaspeedforums.org/forum/f10/wot-run-hhr-ss-kr-present-suggestions-83806/)
whitespeed 06-19-2011 07:48 PM
To give you a brief history, I just got fully bolted and dynoed with a hypertech tune. My dyno results were 292 WHP and 336 WTQ. Anyways I have a dashhawk and have an alert for KR when it's >1.0. Upon normal/slightly aggressive driving my screen will occasionally blip with an alert, well after a 4500 rpm run and letting the engine slow down it flashed with KR 2.5-3.0 then went away after a second. So I've been keeping a closer eye on it now.
Well on my way home today I was in the middle lane on the highway and had to get into the right lane for my exit a mile away. In the right lane was an HHR SS that I was coming up on, just as I slowly pass I drop it into fifth and run about 5psi @80 mph to get by. He doesn't like this and floors it, so I drop into 4th and at first he was gaining ground but I started to pull away (Not as fast as I thought I should) as I got into 5th. Well I see my DH light up yellow and look down and I have a KR of 1.1 continuously throught the gear. I shut down probably around 125 mph and get into the right lane then exit.
So my question is should I be terribly worried about the KR? If so I hopefully could tune it out with an AP. I have heard of people having a DJ tune, I'm guessing that this is a Cobb AP e-tune from a guy named DJ?? How do I contact him and how much does this usually cost? Also I'm pretty sure that HHR was not stock as it put up a decent fight...Any opinions are greatly appreciated. Thanks
Monotonous ONE 06-19-2011 08:17 PM
i dont see injector seals in your mods...id say its a possibility
@djuosnteisn
@socks
Tokay444 06-19-2011 08:18 PM
How do you get your dashhawk to display indecimal degrees?
whitespeed 06-19-2011 08:23 PM
I just selected the Knock Retard Parameter under the Mazda selections in the computer program. I'm guessing for some reason yours is just whole numbers?
I have heard of them, do they just keep the injector sealed more tightly so you don't lose cylinder pressure? And this issue could cause KR?
Tokay444 06-19-2011 08:24 PM
It is. I've had to configure everything on the unit. I run a Mac and the software isn't supported. The parameter is "actual timing" or "actual advance" or something on the unit selctin field, and then displays as knk retard. Stupid.
whitespeed 06-19-2011 08:28 PM
Damn that sucks...I have 3 computers and the software only works on my old shitty one. The software does not like newer operating systems/macs apparently.
Tokay444 06-19-2011 08:46 PM
I don't think anything <2 is really all that cause for concern tbh.
whitespeed 06-19-2011 11:10 PM
Yea that's what I'm wondering because I have been pretty happy with the hypertech tune so far...I don't want to have to spend the money on an AP if I don't have to.
2011speed 06-19-2011 11:17 PM
Was it a black lowered hhr as?
whitespeed 06-20-2011 12:40 AM
It was silver I believe...
Page generated in 0.17791 seconds with 11 queries
