Like Tree99Likes
 Old 11-08-2013, 10:30 PM   #361
alphasaur's Avatar
Posts: 2,847   (View Stats)
alphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the world
Groans: 235
Groaned at 60 Times in 48 Posts
Originally Posted by mgramata View Post
And your saying that from experience orr??
Cheap gaskets that come with cheap parts are always pieces of shit. Why are you trying to question everyone elses experience?
/91 miata with basic suspension bits
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/possessed speed 6- dead ((((((
/lol nator.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
DSIT995 (11-10-2013)
 Old 11-08-2013, 10:31 PM   #362
mgramata's Avatar
Posts: 39   (View Stats)
mgramata is a jewel in the roughmgramata is a jewel in the roughmgramata is a jewel in the rough
Groaned at 4 Times in 2 Posts
Originally Posted by LumberJack View Post
They suck huge fat raging donkey cock! Do not use them, but that's too late you already did. Pretty sure that was one of the most emphasized things in all the XS Power Mani threads. USE OEM and add some copper spray for extra insurance. This is from personal experience with 2 of these manifolds and having removed it 3-4x for issues with the manifold/gasket issues it had earlier
I used the oem gaskets with copper spray..
So I will be buying new fel pros in the am.
mgramata is offline   Reply With Quote
 Old 11-09-2013, 06:35 AM   #363
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Did you say your manifold came with copper gaskets? The only ones from XS I recall seeing are the aluminum crush style gaskets. Got a picture?
2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather
2004 Mazdaspeed Miata #3142- Stock, but not for long.
Equal rights for all, special privileges for none. ~ Thomas Jefferson
 Old 11-09-2013, 01:21 PM   #364
mgramata's Avatar
The Following User Says Thank You to mgramata For This Useful Post:
El_Diablo (11-09-2013)
 Old 11-09-2013, 02:08 PM   #365
El_Diablo's Avatar
Groans: 769
Anneal those with a torch, clean them and then copper spray them atleast 2-3 coats and you'll never have an issue. I've used that style on high hp cars before without issue its just a PITA to prep them correctly.
 Old 11-09-2013, 02:43 PM   #366
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
I almost feel bad- I pulled my stocker off, looked at it for a moment, put it back on and bolted up the new mani
Only the second use for that gasket tho, it was reused when the new engine went in about 3500 miles ago. I've also got a new OEM gasket just sitting waiting to be used if needed.
Safe to say if I didn't have a new one ready to swap in, the current one would have failed instantly. Since I do have a spare the old one will last forever...
I didn't default to the new one in case there was some issue that required the mani to be removed & screwed with for whatever reason
340hp / 371tq
Funkster777 (11-12-2013)
 Old 11-09-2013, 03:21 PM   #367
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Turbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the world
Did you try retorque the bolts? Maybe you never torqued them enough. Also do you have the egt bung pluged?
The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS
Soon to come.
WHO KNOWS? A.D.D. FTW!
Turbo_Steve is offline   Reply With Quote
 Old 11-09-2013, 04:52 PM   #368
mgramata's Avatar
Yup that plug is sealed. once started I heard a leak, so I turned the car off and re-torqued the 4 turbo bolt where it was coming from. The leak at idle went away, but now it leaks when I give it like 60% throttle at 3k rpms. I'm just going to replace and red part the gaskets. Hopefully with no leaks! Aha
Thanks for the replies guys. Appreciate all the inputs
The Following User Says NO Thank You to mgramata For This Un-useful Post:
maddocx240 (11-09-2013)
 Old 11-09-2013, 05:07 PM   #369
maddocx240's Avatar
Posts: 823   (View Stats)
maddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the world
Groaned at 45 Times in 21 Posts
Originally Posted by TiGraySpeed6 View Post
I found getting them out wasn't so bad. Putting them back in, on the other hand, was a special kind of fun...
I just cut the damn line and used a hose. So I never have to deal with those bolts again.
TiGraySpeed6 likes this.
maddocx240 is offline   Reply With Quote
The Following User Says Thank You to maddocx240 For This Useful Post:
TiGraySpeed6 (11-09-2013)
 Old 11-09-2013, 06:53 PM   #370
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Ok, Dale update. I got my CP-E DP in my MS6. It was very easy, especially after the exhaust manifold install. Unfortunately, I must report that the CP-E DP ALSO contacts the driveshaft flange; the bolts hit the DP to be specific. It is VERY little contact; there are a few ways to remedy this. Unfortunately, I found this out after the thing was fully bolted up and there was NO way I was going to pull it today to hammer it. Here's some other options besides denting the DP. You could flip the bolts and I am pretty sure that would be enough clearance. I decided to very lightly dremel the corners of the outer edges bolts, so there is enough meat to put a wrench on still, but enough so there is no contact. It totally clears now, unfortunately, the bolts did put a light gouge in the pipe on my first test drive.
Oh, I did damage the threads on my WB02, but I was able to clean it up enough to reuse which is good.
Here's the gig. If you have a speed 6, just dent the DP above the lower 02 sensor before you install. It won't impact anything and it will save you a lot of time and hassle.
Anyways, here's the Turbo xs with stock DP vs. Turbo xs vs. CP-E DP. It's interesting, because usually there is a flow improvement, boost improvement, some kind of improvement that quantifies the improved numbers. I pretty much stacked all logged parameters and it was all even between baseline and DP. However, the 60-100 times went down by .22 seconds. So, everything else was the same, but with the DP, it did it faster. Log comparison showed +4HP/+14TQ between the runs. IATs were within 2 degrees between runs on the exact same stretch of road.
MINI H1 6.0 - CAR LED TAILS
The Following 8 Users Say Thank You to dale_gribble For This Useful Post:
ABolewski (11-10-2013), Easter Bunny (11-10-2013), El_Diablo (11-10-2013), FADE2GRY (11-09-2013), lilred (11-10-2013), maddocx240 (11-10-2013), magicka (11-09-2013), TiGraySpeed6 (11-09-2013)
 Old 11-09-2013, 09:28 PM   #371
Koke382's Avatar
Posts: 4,361   (View Stats)
Groans: 32
Shuda gone catless
sent from my peepee
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
Koke382 is offline   Reply With Quote
The Following 3 Users Say Thank You to Koke382 For This Useful Post:
Bolted6 (11-09-2013), Easter Bunny (11-10-2013), El_Diablo (11-10-2013)
 Old 11-09-2013, 09:28 PM   #372
I hate to see my results reinforced, but it's nice to know I'm not insane...
340hp / 371tq
The Following 4 Users Say Thank You to TiGraySpeed6 For This Useful Post:
dale_gribble (11-09-2013), Easter Bunny (11-10-2013), lilred (11-10-2013), maddocx240 (11-10-2013)
 Old 11-10-2013, 12:18 AM   #373
maddocx240's Avatar
Aww, that sucks. I'm gonna see what they do with next revision, I'm not really into the idea of denting my dp. But thanks for the write up dale.
 Old 11-10-2013, 12:31 AM   #374
alphasaur's Avatar
Groans: 235
Weak son!
Trigger finger is itchy I want this
/speed 3- bye
/lol nator.
 Old 11-10-2013, 01:11 AM   #375
maddocx240's Avatar
Originally Posted by alphasaur View Post
Weak son!
Its very tempting, but that dp situation just doesn't sit right with me. They gotta do something about that.
The Following 2 Users Say Thank You to maddocx240 For This Useful Post:
Easter Bunny (11-10-2013), FADE2GRY (11-10-2013)
 Old 11-10-2013, 05:42 AM   #376
Bolted6's Avatar
Posts: 81   (View Stats)
Bolted6 has much to be proud ofBolted6 has much to be proud ofBolted6 has much to be proud ofBolted6 has much to be proud ofBolted6 has much to be proud ofBolted6 has much to be proud ofBolted6 has much to be proud ofBolted6 has much to be proud ofBolted6 has much to be proud of
I was not a huge fan of having to dent my $400 dp. But when all is said and done the denting of dp is minimal for clearance. It's the age old debate, spend more on quality/fit or save money on a cheaper part that might need some tweaking.
Bolted6 is offline   Reply With Quote
The Following User Says Thank You to Bolted6 For This Useful Post:
 Old 11-10-2013, 06:35 AM   #377
ABolewski's Avatar
Posts: 1,279   (View Stats)
ABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the world
Groans: 52
@Bolted6; Fast Reliable or Cheap, pick two!
2010 Alternative Lifestyle Blue Mazdaspeed3
(sold)
2008 Chevy Colorado. The only truck that comes with a lifetime guarantee...
ABolewski is offline   Reply With Quote
 Old 11-10-2013, 07:25 AM   #378
Bolted6's Avatar
Lower cost isn't always a cheap/junk item. The XS manifold is the only cheaper item I've installed on my build. Only time will tell if the quality of the manifold is there. The next "cheapest" manifold is DNP for $600. I'll stick that extra money either into an E85 tune or JBR mounts.
 Old 11-10-2013, 07:37 AM   #379
FADE2GRY's Avatar
Posts: 144   (View Stats)
FADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond reputeFADE2GRY has a reputation beyond repute
Agree 100%. Even at any price. If size 11 shoes are on sale I still buy size 9 because that's what I need.
2007 Titanium Grey Mazdaspeed 6
Mazdaspeed Forged Aluminum wheels (18x7.5) gun metal powder coating | 225/45ZR18 Hankook Ventus V12 evo K110 | SURE ShortCut, CounterShift, & Anchors
Cobb AccessPORT v3| Cobb SF Intake | Cobb Turbo Inlet Pipe | CorkSport TMIC | Saikou Michi oil catch can | STRI DSM-SLM II boost gauge /w vent pod
SURE Juggernaught | SURE Dreadnaught | SURE Torq R6 | Whiteline 24mm adjustable rear swaybar | cut OEM springs | Bilstein HD shocks | SPC adjustable ball joint
Autotech HPFP internals | 3.0 bar MAP sensor | Mazda spin-on oil filter conversion | CP-e SafeSeal injector seals | Cobb XLE bypass valve | JBR EGR delete
CorkSport rear brace bar | CorkSport front strut bar | CorkSport transmission mount insert
Next Mods ------
XS Power exhaust manifold | BNR stage 3 turbo | M2 downpipe w/ Magnaflow cat and Moroso venturi pipe | Magnaflow exhaust | Grimmspeed electronic boost control solenoid
FADE2GRY is offline   Reply With Quote
 Old 11-10-2013, 11:29 AM   #380
alphasaur's Avatar
Groans: 235
I don't expect car modding to be 100% put on and go. Headaches and slight modifications are inherent with this hobby imo. Manifold was likely designed on a speed 3 where there is no driveshaft.
/speed 3- bye
/lol nator.
The Following 5 Users Say Thank You to alphasaur For This Useful Post:
Bolted6 (11-10-2013), dale_gribble (11-10-2013), El_Diablo (11-11-2013), lilred (11-10-2013), Roddiy (11-12-2013)
 Old 11-10-2013, 02:26 PM   #381
FADE2GRY's Avatar
@TiGraySpeed6; Do you have any pics of how close your downpipe is to your alternator?
My M2 downpipe touches the alternator's heat shield because the turbo is closer to the block after the XS Power exhaust manifold install. I was hoping to keep that heat shield on.
I also broke my V-band clamp when removing it so I could try fitment without the alternator heat shield. Sucks to be me - more down time.
Next Mods ------
 Old 11-10-2013, 02:36 PM   #382
maddocx240's Avatar
I don't expect car Modding to be 100% but certain things I'm willing to modify and certain things I'm not. I don't think the manifold was tested with an aftermarket dp. Cause the stock pipe clears. But from what I hear there is supposed to be a final revision, xspower;
 Old 11-10-2013, 02:58 PM   #383
Drilling or slotting the bolt holes on the turbine flange of the manifold with a carbide bit and a die grinder to allow you to rotate the turbo 2 degrees will fix everything. It will also keep you from needing to dent your downpipie on the MS6.
Most aftermarket manifolds, downpipies, etc have the bolt holes slightly oversized to allow for fitment adjustment. IIRC the bolt holes on my manifold were pretty tight. Being A MS3 I didn't notice any alignment issues with my install.
If XS power sent these manifolds out with the holes on the turbine flange drilled 2mm bigger I am sure none of these alignment issues with the ms6 would be popping up.
The V1 & V2 manifolds are being sold now by xs power heavily based off of the feedback of the initial test fitters. I had nothing come up with fitment on my MS3 and I did share info with XS power as such. It wasn't till after these manifolds are now being sold that some issues with fitment with certain aftermarket downpipes on the MS6 are coming up.
Soon to come.
The Following 3 Users Say Thank You to Turbo_Steve For This Useful Post:
Easter Bunny (11-10-2013), El_Diablo (11-11-2013), maddocx240 (11-10-2013)
 Old 11-10-2013, 04:34 PM   #384
Guys, its no big deal too slightly dent the dp. No one will ever see it, it has no impact on performance since its overkill anyways, and it isn't really going to hurt resale. I didn't even think twice about it.
alphasaur likes this.
The Following 2 Users Say Thank You to dale_gribble For This Useful Post:
 Old 11-10-2013, 05:27 PM   #385
Bolted6's Avatar
I thought twice. But decided once the manifold was on there's no going back. Truthfully once the dp is modified you'll never give it a second thought.
 Old 11-10-2013, 05:55 PM   #386
It's tucked in there tight for sure, but no discoloration or anything. I took several pics, but it comes down to these two. You can see it's tucked in there, but not (currently) actually making contact. Picking nits - it's right up in there.
The only change here is the angle you're viewing from- more towards the O2 and it's not touching, more towards the alt and it's buried
340hp / 371tq
FADE2GRY (11-12-2013)
 Old 11-10-2013, 06:09 PM   #387
CP-E def has more clearance off of the alternator.
 Old 11-12-2013, 08:51 AM   #388
FADE2GRY's Avatar
Thanks. Mine was a lot worse and actually prevented the v-band flanges to mate. @Turbo_Steve; mentioned rotating the turbo and I'll try that. I'll be getting me new V-band clamp on Wednesday.
Here's another funny thing. When I had the downpipe installed, for a few minutes, there was no clearance problems at the drive shaft flange. Enough space there to stick my fat hand between the pipe and the flange. Go figure.
Next Mods ------
 Old 11-12-2013, 01:00 PM   #389
skiptowncat's Avatar
Posts: 1,592   (View Stats)
skiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the world
Groans: 49
Groaned at 34 Times in 25 Posts
My build starts next week, I'll let you all know how it goes with fitment.
Tuned with by
K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!!
skiptowncat is offline   Reply With Quote
The Following User Says Thank You to skiptowncat For This Useful Post:
Turbo_Steve (11-13-2013)
 Old 11-23-2013, 02:14 PM   #390
MattJackson86's Avatar
Posts: 1,407   (View Stats)
V2 required me to enlarge / slot 1 bolt hole but was otherwise painless. XS power knows of the issue with the bolt hole and it is being fixed on all v2-3 manifolds from this point on.
@Turbo_Steve
Purchased my V2 on 10/21, had it ceramic coated and came to install it today and it seems they missed enlarging the bolt hole on a few When looking at the flange, its the top right bolt hole that looks like it needs to be enlarged/slotted a 1/4". Was this the same for you?
EDIT: 20 mins with a grinder and carbide tip solved the issue. Fits great now.
The Following User Says Thank You to MattJackson86 For This Useful Post:
skiptowncat (11-24-2013)
 Old 11-24-2013, 02:27 AM   #391
Groans: 49
Originally Posted by MattJackson86 View Post
@Turbo_Steve
Any data?
Tuned with by
 Old 11-25-2013, 01:14 PM   #392
Installing it currently with a new GTX3071. Install of the manifold so far hasn't been too bad. It fits back there no issue and wasn't really difficult to get it lined up and onto the studs of block and turbo (once the hole was enlarged). Definitely check holes with OEM gasket first.
The nuts bolting it to the turbo are not as easily reachable as OEM. Can get a socket on 1, other 3 require a short wrench. Found the nuts wouldn't go on the left side turbo studs if you do them last (ie you do the right side first) as the studs on the turbo then come close to the header tubes and you can't get the nuts on. So I'd suggest tightening (when looking from front of car) back left, front left, back right, front right (this one you can get a socket and impact gun on).
Once it was bolted to the turbo I started installing all the other manifold to block nuts. Did the top easily (easy access with wrench) and came to do the bottom. The bottom 2 near turbo I can now not get nuts on. The studs are too long and/or the turbo too close. There is a couple millimeters between end of stud and turbo. Will need to remove all the buts again tonight, hoping to then slide it off the studs a bit, enough to move turbo back and get nuts started, and then tighten them first. All others seem to have easy nut access.
Some of this may be BT size and fitment issues too, and they have not been difficult to resolve but to save you a headache its nice to know before you have to start undoing things.
EDIT: Figured out the bolt issue, your first must bolt the mani completely to the block and then bolt on the turbo. That allows the turbo to sit out of the way when tightening the 2 bottom nuts.
The Following 2 Users Say Thank You to MattJackson86 For This Useful Post:
Nel Mazdaspeed (12-11-2015), Spectrix (11-27-2013)
 Old 11-30-2013, 11:07 PM   #393
Got it all bolted in and driving, only to find an exhaust leake on the mani->turbo flange. Brand new OEM gaskets used all round. Everything is really tight, so not sure what to do at the moment. Its the front of the flange looking through the runners. Not a small gap imo.
 Old 11-30-2013, 11:40 PM   #394
Bolted6's Avatar
I had to re-torque mine after a couple of a hundred miles. But yes my manifold to flange was leaking to.
MattJackson86 (12-01-2013)
 Old 11-30-2013, 11:57 PM   #395
so you just torqued it down and it was all good? Mine is tight right now, cant see getting it much tighter...
 Old 12-01-2013, 12:31 AM   #396
Spectrix's Avatar
Posts: 332   (View Stats)
Spectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the world
Groaned at 7 Times in 3 Posts
Sorry to say, that manifold will need to come out for the flange surface to be corrected.
2008 Gen1 MS3
Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires.
Self tuned on E85
Spectrix is offline   Reply With Quote
The Following User Says Thank You to Spectrix For This Useful Post:
 Old 12-01-2013, 09:04 AM   #397
Kinda what I suspected, but hoped otherwise. Gonna try and remove it today and just put stock one in again for now. Want to get the car drivable with BT at least. I'll have to find a shop that I can take this too and have the flanges fully inspected.
 Old 12-01-2013, 04:28 PM   #398
LumberJack's Avatar
LumberJack has disabled reputation
Groans: 57
Groaned at 21 Times in 13 Posts
Unfortunately flange surfaces have been messed up on these since day 1. I posted this a few times that regardless of them being re surfaced from xs power that they needed to be checked AGAIN. My replacement that was supposedly fixed needed MAJOR resurfacing still.
Sent from my LG-LS980 using Tapatalk
2018.... Doing even more freeky things!
10.36@148 Fastest Gen 2
LumberJack is offline   Reply With Quote
The Following 3 Users Say Thank You to LumberJack For This Useful Post:
atvfreek (12-01-2013), Bolted6 (12-01-2013), MattJackson86 (12-01-2013)
 Old 12-01-2013, 06:59 PM   #399
Yes, everyone needs to take that advice and confirm flanges and bolt holes are correct before you go coating this thing, and especially before you install it. Ripping it out is not super fun, but good practice I guess....
In process of removing it now and hoping to find a shop to take it too this week.
Question, what nuts are people using for this? Oem seem best to me. After a few times tightening and loosening the atp ones do not seem to hold up. Probably going to stick with oem and washers. Also someone mentioned it earlier but Crows feet wrenches are a big help.
LumberJack (12-01-2013)
 Old 12-01-2013, 07:02 PM   #400
LumberJack's Avatar
Groans: 57
Agreed between all my bullshit that happened i replaced gaskets 3x and had the manifold out 3 separate times for either fitment or leak issues. All I can say is i can now have that fucker out in less then 45min haha.
The Following User Says Thank You to LumberJack For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/xs-power-turbo-manifold-here-install-pics-154973/
R32 Build Log, My First Skyline :-) - Page 2 - Projects, Overhauls and Build-ups - SAU Community This thread Refback 03-20-2015 10:07 AM
Whats New/General Speed 6 Discussion - Page 271 This thread Refback 10-20-2013 05:45 PM
Picking up an exhaust manifold finally - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 10-16-2013 09:38 PM
XS Power exhaust manifold ? Mazda MPS Owners Club This thread Refback 10-16-2013 08:58 AM
Follow up to "Catasprohic dyno results" Elvisrosales88 2010 MS3 - ECU Computer Tuning 4 08-22-2013 06:53 PM
Scatt's Medieval Manifold Install/Dyno Thread Scatt Nasty MazdaSpeed 3/6 - Turbo Induction 40 06-27-2009 12:03 PM
Results on an AWD dyno vs. a 2WD dyno: closer to actual power on the road? desperado callado MazdaSpeed 3/6 - Dyno Sheets/Discussions 10 05-18-2009 11:27 AM
Pics of Dashhawk and Turbo Timer Install, and some other random stuf Addikted To Boost MazdaSpeed 3/6 - Car Audio & Electronics 12 12-15-2008 10:51 AM
Built Cylinder Head - 8700RPM Redline - Tubular Turbo Manifold (Pics) jhershorin MazdaSpeed 3 - Engine, Transmission & Driveline 36 07-23-2008 04:10 PM
Page generated in 0.59763 seconds with 35 queries
