![]() | | #441 | ![]() |
![]() Join Date: Dec 2008 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 541
| Not Ranked : 0 score I am using ATP studs, washers, and OEM nuts on my turbo flange fyi. The studs dont hit my mani piping. Heres a dumb question, but you got me thinking, with these studs which side goes in the turbo and which side through the flange? http://www.atpturbo.com/mm5/merchant...egory_Code=FST I put the short side in turbo and long side through flange. Sadly I do feel that I may have a $600 paper weight at this point ($400 + coating + repairs)
__________________ GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP ![]() Bitwise Motorsports http://www.bitwise-motorsports.com - Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!) |
![]() | | #442 | ![]() |
![]() Join Date: Jun 2009 Location: Tally, FL
Rep Power: 3058 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,683
| Not Ranked : 0 score My studs just came from the local hardware store, but looked like the ATP's except the long side was longer. I'd have to go pick up another one to get an accurate measurement tho. Short side in the turbo.
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq |
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | MattJackson86 (12-04-2013) |
![]() | | #443 | ![]() |
![]() Join Date: Apr 2012 Location: Temecula, CA
Rep Power: 5431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,552
| Not Ranked : 0 score I think we may be on to something...
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 |
![]() | | #444 | ![]() |
| Not Ranked : 0 score We may be (im still trying to picture the stud/shoulder issue), but I still worry about what appears to be the lack of space in the first place for a BT. I am not convinced that even if we could close that gap, that the turbo would even fit without the compressor side hitting some of my studs on the block. Need somebody with a BT and this mani to chime in on what their space looks like. We need XS Power to get in here and give their 2cents. They are a vendor on here so they need to help us out imo.
![]() | | #445 | ![]() |
| Not Ranked : 0 score Cutting the head studs for the ex mani has been happening for a long time for this very reason. I search it just to get an idea, and one of the first results goes back to dougefresh in 2011 Need ex Mani Stud info Please
![]() | | #446 | ![]() |
| Not Ranked : 0 score I need to pull out my down pipe for clearance mod anyways, and I am going to change turbo-manifold studs and either mod or remove the turbo bracket at the same time. If mine still doesn't seal perfectly after that, I may go back to stock for the time being. I am getting some exhaust fumes in my cabin when I have non-recirc set for the HVAC fan and it is pissing me off. I HATE when a mod makes my car racecar.
![]() | | #447 | ![]() |
| Not Ranked : 0 score Seems like I will start to remove things again tonight and replace the 2 studs with bolts or shorter studs. I'll then see where we are at on getting the turbo flange snug.
| The Following User Says Thank You to MattJackson86 For This Useful Post: | TiGraySpeed6 (12-04-2013) |
![]() | | #448 | ![]() |
| Not Ranked : 0 score If your nuts aren't fused to your studs and the nuts move freely on the studs, then it won't do much for you. My recommendation is really only if the nut is fused on the stud at a specific height, in which case the shoulder of the stud may bottom out before the nut reaches the required torque on the exhaust manifold flange since the XS flange is slimmer then stock.
![]() | | #449 | ![]() |
| Not Ranked : 0 score Yea my nuts are were easy to tighten down fully, and removing them they came off the studs (except one which i torqued big time). I have to be torqued more than 37 ft lbs on some of them. I was really trying to close that gap ![]() I think ill try removing the exhaust from DP and see if that frees up a bit of movement, and then with bolts maybe the turb can swing just a bit more and close up the gap. Im not holding my breath though. I think the actual angle of the flange is off like you previously mentioned.
![]() | | #450 | ![]() |
![]() Join Date: Apr 2013 Location: Moreno Valley
Rep Power: 0 ![]() ![]() ![]() Thanks: 14
Groaned at 4 Times in 2 Posts
| Not Ranked : 0 score I got rid of the original turbo studs as they were hard to get tight after installing the manifold. I tried shorting them to not hit the runners on 1&2 but just ended up using regular ol bolts. So far I'm good like this, but I did have a leak at the front of the turbo flange on initial install. Replaced the gasket and I'm good. But now I'm only seeing 16lbs of boost as opposed to the 21 I'm tuned for. Maybe I sprung a boost leak while re-installing?? |
![]() | | #451 | ![]() |
| Not Ranked : 0 score Update @MattJackson86;?
![]() | | #452 | ![]() |
![]() Join Date: Feb 2012 Location: Anaheim, Orange County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,921
Groans: 32
| Not Ranked : 0 score Someone should write a detailed how to on how to instal this on a speed3 and speed6 with pics. I know theres some but with all these issues it would sure help others to see what fixes have worked for others. Im going to be buying oem gaskets and some studs bols ect to do my install. Im running the stock k04 and a cnt catless downpipe so ill see how it goes for me. Will be getting my mani resurfaced after xmas and starting to buy the misc lil parts to make the install easyer. Hope it turns out well. Lol sent from my peepee
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit |
![]() | | #453 | ![]() |
| Not Ranked : 0 score Dropped the turbo from the manifold last night as well as disconnected the DP from the exhaust. Still cant slide the turbo over, it wont drop enough (hitting block) for the turbo studs to be lower than the mani flange. I cant remove 1 of the turbo studs to make clearance for it to slide over, thus the mani is gonna have to be loosened tonight to lift it over the turbo studs and slide the turbo over. Once its moved over I have some spare new ATP studs that I used on the turbo and downpipe, and will replace the problematic 2-3 studs on block. Then bolt the mani back and turbo to mani. After removing the downpipe from the exhaust the downpipe is still quite rigid (it still connected to the 2 exhaust hangers). I think to give me the absolute best odds of this working I will hang the turbo from the mani, remove the DP from the turbo, then fully bolt the turbo to the mani. If the gap exists still then there is nothing more I could possibly do without modifying mani more and would prove that the mani just has issues. If the gap goes away then I would assume its the DP pulling on the turbo (due to turbo being moved closer to block by manu) and would need to figure out how to get the DP attached once the turbo is fully bolted and tight. Hoping that the order I bolt things in will work. Mani to engine first, turbo to mani second, then dp to turbo. I think it may work (fingers crossed). Just hope there is enough slack in DP and exhaust to make up the distance the Turbo was moved closer to block.
| The Following User Says Thank You to MattJackson86 For This Useful Post: | Koke382 (12-05-2013) |
![]() | | #454 | ![]() |
![]() Join Date: Nov 2012 Location: Pinehurst, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 624
__________________ 2006 TGM MS6 Cobb AP w/ SELFtune // Split Second AIC1-V4H // Stratified Guardian Angel // Stratified Boost Dial // ATP GTX3071r IWG // Devils Own Stage 1 WMI // JMF v2 Intake Manifold // 4 x Siemens DEKA IV 60 lph Injectors // Outlaw4shrt In-Tank Fuel Pump Kit w/ 255 lph pump // CP-E CDFP // CP-E SAFEseals // Clutchmasters 350 & flywheel // CX Racing FMIC // HTP 3.5" Intake // 3.5 Bar MAP // Cobb EBCS // Forge BPV v1 // XS Power Exhaust Manifold // M2 Downpipe w/ Highflow Cat // Corksport 80mm CBE // Blackworks Racing VTA OCC // NGK +1's // JBR EGR delete // Speedy 17x7.5 Lite Fin's w/ Hankook Ventus V2 225/50/R17 // TooLateTuning Springs // Bilstein B6 HD Shocks // Whiteline RSB // SPC Adjustable Ball Joints // Airlift 1000 "Drag Bags" // JBR 80 duro RMM // JBR 80 duro TMM // JBR 80 duro PMM // CP-E RDM // Turbine Tech FDM // OEM Spin-On Oil Filter Conversion // Prosport Oil Pressure and Oil Temp Gauge with Oil Filter Adapter Plate, Boost and EGT Gauges // AEM UEGO Wideband O2 & Fuel Pressure Gauges // Block8head MS6 dual 52mm vent pod // Lotek triple 52mm gauge pod // Prosport EVO Single Gauge Pod // Cobb Knob // Corksport LED Kit // Corksport LED Fogs // LED Tails // Audi LED DRL's 2008 MazdaSpeed 3 - R.I.P. 1/3/13 - from ENM 2014 | |
| The Following 3 Users Say Thank You to Outlaw4shrt For This Useful Post: |
![]() | | #455 | ![]() |
| Not Ranked : 0 score If it doesn't work out I'll cross my fingers that xs power replace or refund it, but I'm not holding my breath on that..
![]() | | #456 | ![]() |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
(Thread Starter) | Not Ranked : 0 score Have you tried to email them? You need to email them direct with problems. Dont assume they are reading this.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! |
![]() | | #457 | ![]() |
| Not Ranked : 0 score Oh I know, if my efforts to make it work do not work out I will reach out to them direct and see what they can do. I just need to rule out installation error as the cause as I know they are going to want me to try all that I am doing anyways. It's good gathering knowledge though of people with similar issues.
| The Following User Says Thank You to MattJackson86 For This Useful Post: | Easter Bunny (12-06-2013) |
![]() | | #458 | ![]() |
| Not Ranked : 0 score Ok update... So my header head flange definitely isn't leaking. That is clearly evident here- ![]() The turbo flange is leaking pretty bad. ![]() The turbo flange looks terrible; when you can tell visually that it isn't flat, it isn't flat. ![]() I pulled the DP to dent it in a bit so it stops making contact with the driveshaft flange. The divit is pretty deep. I might take it to a muffler shop to repair it before reinstalling. I don't want to end up with a pinhole. ![]() This is my last go around with this header. I am going to get it machined, I am using all new studs/nuts/gaskets, I am going to remove the turbo bracket (for now) and see what happens. If it leaks, it's gone.
| The Following 4 Users Say Thank You to dale_gribble For This Useful Post: | Easter Bunny (12-06-2013), MattJackson86 (12-06-2013), Mauro_Penguin (12-06-2013), TiGraySpeed6 (12-06-2013) |
![]() | | #459 | ![]() |
![]() Join Date: Jul 2012 Location: Caldwell, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,512
Groans: 32
tappin
__________________ Rapey Agendas Racing | |
| The Following 2 Users Say Thank You to h0ckeyman For This Useful Post: | El_Diablo (12-06-2013), MattJackson86 (12-06-2013) |
![]() | | #460 | ![]() |
| Not Ranked : 0 score Wow, does that turbo flange really drop away as bad as it looks in that pic?? Damn. I'm not sure if it's the angle, or the soot being on there or what but that looks like a monster change. Remember if it's milled down you may want to pick up washers or otherwise address the shoulder on the studs & nut clearance we were talking about a few days ago!
![]() | | #461 | ![]() |
| Raider is mah Homie ![]() Join Date: Jan 2011 Location: Towson, Maryland
Rep Power: 7524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54,831
Groans: 2,978
| Not Ranked : 0 score Can you throw a straight edge on the turbo flange and take a pic for reference?
__________________ ![]() I hugged rfinkle2 |
| The Following User Says Thank You to Easter Bunny For This Useful Post: | El_Diablo (12-06-2013) |
![]() | | #462 | ![]() |
(Thread Starter) | Not Ranked : 0 score Email the warped flange pic to xspower. The person you need to talk to isn't the same person from xs power who handles their vendor account on here. Xxspower@gmail.com. I talked to the owner via email. He is going off our feedback on this piece. The builder made the relief cut after resurfacing the head flange and some of them were warped. We reported they were warped so they went out to have the head flanges machined. He said nobody reported th turbo flange was warped to him yet. I let him know, he needs pictures of this.
| The Following 8 Users Say Thank You to Turbo_Steve For This Useful Post: | dale_gribble (12-06-2013), Easter Bunny (12-06-2013), El_Diablo (12-06-2013), LumberJack (12-06-2013), MattJackson86 (12-06-2013), Micha (12-08-2013), Spectrix (12-06-2013), TiGraySpeed6 (12-06-2013) |
![]() | | #463 | ![]() |
The guy thinks it has heat cycled and settled so it will probably seal fine after resurface.
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 | |
| The Following 2 Users Say Thank You to dale_gribble For This Useful Post: | Easter Bunny (12-06-2013), El_Diablo (12-06-2013) |
![]() | | #464 | ![]() |
![]() ![]() ![]() Join Date: Nov 2012 Location: Temecula, CA
Rep Power: 2724 ![]() Thanks: 3,896
Groans: 57
Groaned at 21 Times in 13 Posts
| Where did you end up going too for it? Sent from my LG-LS980 using Tapatalk
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 |
![]() | | #465 | ![]() |
| Not Ranked : 0 score Arrow. I've used him before and since he did yours I decided to go there; its like a 3 day turn which kinda sucks but ah well...
| The Following User Says Thank You to dale_gribble For This Useful Post: | LumberJack (12-06-2013) |
![]() | | #466 | ![]() |
Groans: 57
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 | |
![]() | | #467 | ![]() |
| Not Ranked : 0 score Sheesh, good luck. Im going to knock it all out this weekend. Got the turbo fully dropped last night but still can't slide it over enough to remove the studs. May just stop trying to prevent inevitable and just start over. Remove mani, remove turbo, fix studs, and re-install. Interesting your flange was leaking in same spot as mine. I hope the re-surface fixes it for you. Let me know if you can see a gap when you re-install. Wonder if you may need to re-install with DP not attached like im thinking.
| The Following User Says Thank You to MattJackson86 For This Useful Post: | dale_gribble (12-06-2013) |
![]() | | #468 | ![]() |
![]() Join Date: Sep 2013 Location: Quebec
| Not Ranked : 0 score wow! we can see the warp on the picture! Can you tell if it was like this at time of install or it become like that after heat cycle ? Maybe a brand new one will need to be heat treated before re-surfacing...I'M thinking about throwing it into a wood stove for few hours lol...
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... |
![]() | | #469 | ![]() |
| Not Ranked : 0 score I think it may not have been flat during install; the leak flutter was there, I just thought it was the header just being noisier than the manifold as exhaust passes through which is consistent with my experience with headers on other vehicles. It did seems to get worse over time and then I finally saw the carbon build up on the gasket in the front. I think if both mating surfaces are verified and/or machined prior to install that you will be in a lot better shape than me.
I do think my reusing the fused nuts on studs may have exacerbated the issue.
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 Last edited by dale_gribble; 12-06-2013 at 06:40 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #470 | ![]() |
| Not Ranked : 0 score So I think i have to conclude this Mani just makes everything sit at different angles and locations. I removed the Downpipe after hanging turbo from Mani and sure enough I was able to rotate the turbo and close the gap up more. It looks pretty good at the moment and I think it would be leak free. Problem is, I can now not get the downpipe reconnected. It needs to rotate a tad and I can't get it at the moment. Downpipe is just connected to rubber exhaust hangers at moment, no where else. Tons of wiggle room but just can't get it connected. Will try removing hangers after lunch but I am not too please how much stuff I am having to alter when this should just work. If I ever have to remove the Mani in future I would have to disconnect dp and everything to reinstall, and that seems silly. EDIT: FYI, sent an email to XS. I think I am just going to remove the mani and stick with OEM at the moment. This manifold is not correct and not worth the headache. I have about $550 into this manifold to try and get it working, not to mention who knows how much time installing and removing both this and every other component nearby to try and make it work. If XS decide to help me out and refund me or let me try another manifold of theirs, then awesome. We shall see
__________________ GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP ![]() Bitwise Motorsports http://www.bitwise-motorsports.com - Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!) Last edited by MattJackson86; 12-07-2013 at 03:27 PM. |
| The Following 2 Users Say Thank You to MattJackson86 For This Useful Post: | Bolted6 (12-09-2013), dale_gribble (12-07-2013) |
![]() | | #471 | ![]() |
| Not Ranked : 0 score So you couldn't get the dp lined up?
![]() | | #472 | ![]() |
| Not Ranked : 0 score No, it was all just too wonky. It seemed way too wrong having to keep dismantling down stream parts to make a Mani fit. Removed it for the final time and threw the oem Mani back on. It's night and day difference fitment wise. Never installed any other manis before, and oem was a breeze compared to xs power. The gasket looks perfect, everything just fits. I'll be starting it up in morning after a few more final pieces. It's time to enjoy the new turbo and not waste more time and money on a faulty part. I'll see if xs power email me back and keep you updated.
| The Following User Says Thank You to MattJackson86 For This Useful Post: | Bolted6 (12-09-2013) |
![]() | | #473 | ![]() |
Let us know what xs power says though.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! | ||
| The Following User Says Thank You to Turbo_Steve For This Useful Post: | Status Update (12-09-2013) |
![]() | | #474 | ![]() |
| Not Ranked : 0 score Fast email response from xs power. Am talking over the issue with them and seeing what can be done. I expect some issues for sure with after market, it always happens. But this Mani, for me, simply doesn't fit.
| The Following 2 Users Say Thank You to MattJackson86 For This Useful Post: | DSIT995 (12-11-2013), TiGraySpeed6 (12-08-2013) |
![]() | | #475 | ![]() |
I emailed him about wanting to help out with designing a V3 manifold some time back. Sounds like it is a go. We will make sure fitment is perfect. Make sure the flanges are 100% flat, and possibly have them all come standard with an ewg port and a block offf plate.
| The Following 5 Users Say Thank You to Turbo_Steve For This Useful Post: | Bolted6 (12-09-2013), El_Diablo (12-09-2013), JgamB (12-09-2013), MattJackson86 (12-08-2013), Micha (12-08-2013) |
![]() | | #476 | ![]() |
| Not Ranked : 0 score Let me know if you need anything. I am going to mail this back to them tomorrow or Tuesday, but if they want it direct to you I can do that too. I'll be happy to test fit a future Mani if needed. I can swap these things out in no time it seems now. They did offer to send me a v1 while they sort it out but I said I'll just run oem as I don't "need" a Mani at the moment.
![]() | | #477 | ![]() |
![]() | | #478 | ![]() |
| Not Ranked : 0 score I just got off the horn with my guy at the machine shop. He didn't go into detail because he was busy, suffice to say he said my header was in terrible shape surface wise on both surfaces and he would need it an extra day to get it right. I'll provide details tomorrow when he gives me the rundown. FFFFUUUUUUUU............... Pretty fucked up no matter how you cut it. I guess some guys have had luck with this, I sure as shit wouldn't touch it again until I knew for sure they got this shit under control. If you are on the fence on this header, I would personally hold off and either save up for a better one or wait for to see if they can get this one under control. Again, it isn't a $600 or $900 header, but for $400, it should be at least usable out of the box. It's garbage right now. This doesn't even consider the fact the turbo bracket won't work stock or the downpipe hits my driveshaft flange. I am calling it garbage straight based on fitment because I was willing to fix that other shit understanding that it is an aftermarket part and this is the game.
| The Following 2 Users Say Thank You to dale_gribble For This Useful Post: | DSIT995 (12-11-2013), Status Update (12-09-2013) |
![]() | | #479 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score Keep in mind, if you bolt it down as is and its already warped, it will only get worse over time.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson Last edited by El_Diablo; 12-09-2013 at 08:52 PM. Reason: Spelling error. |
| The Following User Says Thank You to El_Diablo For This Useful Post: | Bolted6 (12-09-2013) |
![]() | | #480 | ![]() |
| Not Ranked : 0 score Ya, understand that. I guess I shouldn't have bolted mine up and had it machined out of the box; I guess when XS said they checked the flanges for flatness, I thought they meant both flanges. Just like how they said the headers were 421 stainless too I guess. I was lulled into a false sense of security because they said the addressed issues and another few of the early guys seemed to have 0 problems. So, for anyone that is considering buying one of these, just find a local engine/machine shop and quote out machining the head and turbo flanges flat. Include that in the price of the header.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/xs-power-turbo-manifold-here-install-pics-154973/ | ||||
| R32 Build Log, My First Skyline :-) - Page 2 - Projects, Overhauls and Build-ups - SAU Community | This thread | Refback | 03-20-2015 10:07 AM | |
| Whats New/General Speed 6 Discussion - Page 271 | This thread | Refback | 10-20-2013 05:45 PM | |
| Picking up an exhaust manifold finally - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 10-16-2013 09:38 PM | |
| XS Power exhaust manifold ? Mazda MPS Owners Club | This thread | Refback | 10-16-2013 08:58 AM | |
| Follow up to "Catasprohic dyno results" | Elvisrosales88 | 2010 MS3 - ECU Computer Tuning | 4 | 08-22-2013 06:53 PM |
| Scatt's Medieval Manifold Install/Dyno Thread | Scatt Nasty | MazdaSpeed 3/6 - Turbo Induction | 40 | 06-27-2009 12:03 PM |
| Results on an AWD dyno vs. a 2WD dyno: closer to actual power on the road? | desperado callado | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 10 | 05-18-2009 11:27 AM |
| Pics of Dashhawk and Turbo Timer Install, and some other random stuf | Addikted To Boost | MazdaSpeed 3/6 - Car Audio & Electronics | 12 | 12-15-2008 10:51 AM |
| Built Cylinder Head - 8700RPM Redline - Tubular Turbo Manifold (Pics) | jhershorin | MazdaSpeed 3 - Engine, Transmission & Driveline | 36 | 07-23-2008 04:10 PM |
