Like Tree6Likes
 Old 03-11-2012, 02:19 PM   #81
Stealth01's Avatar
Posts: 6,910   (View Stats)
Stealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the world
Groans: 201
Groaned at 164 Times in 103 Posts
Sounds like you could really use a tune. The stock tune is very aggressive and still doesn't deliver great power - so it's aggressive in the wrong ways you can say.
To this man you should listen, paduan.
OP: I've attached a log from a 3rd gear pull I did today. Note how even with the OEM HPFP, Fuel Pressure remains at 1600+ through the entire pull. Anything less is bad ju-ju. I'm a total noob to this tuning shit, but that much at least Lex has taught me. He is my Obi-Wan.
I was thinking about KMDs, since I can get a really good deal on them, but not so sure after all these failures. Still, at this elevation, the stock HPFP is doing just fine. For now.
Stealth01
2006 Mazdaspeed6 GT
Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose
SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG
Read my stories: https://www.smashwords.com/books/view/55318
Stealth01 is offline   Reply With Quote
The Following User Says Thank You to Stealth01 For This Useful Post:
Lex (03-11-2012)
 Old 03-11-2012, 04:31 PM   #82
17cak's Avatar
Posts: 104   (View Stats)
17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world
do u guys think kmd should atleast replace my internals for free?
Black '06 Grand Touring - Cobb AP Stage 2 - M2 DP w/ HF Cat, Magnaflow CBE, AEM SRI, KMD Internals, TurboSmart BPV, SU RMM, Denso ITV22
17cak is offline   Reply With Quote
The Following 3 Users Say Thank You to 17cak For This Useful Post:
phate (03-11-2012), Tokay444 (03-11-2012), xfeejayx (03-12-2012)
 Old 03-11-2012, 05:10 PM   #83
Take them out carefully and inspect. You might see the issue with the naked eye. Write a nice letter, supply a datalog, and show pictures. They will probably replace them - just state your case clearly and provide evidence.
deadlandxtreme (03-12-2012), phate (03-11-2012), radioflyer (03-11-2012), Stealth01 (03-11-2012), Tokay444 (03-11-2012)
 Old 03-11-2012, 05:19 PM   #84
kunfu's Avatar
Posts: 467   (View Stats)
kunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the world
Groans: 56
This scares the shit out of me. Reminds me that my car is first and foremost my daily driver. I look forward to the day that I have a daily driver that is different from my "have fun car".
Speed 3 2007:
NATOR NY mod. SURE SRI and TIP, OBX Test Pipe, SURE RMM, KMD Internals, JBarone SSP, Koni FSD's,Solid shifter bushings, Cobb AP, Stainless brake lines, EGR delete, OCC, HIDs, IV-22's, Turbo timer.
kunfu is offline   Reply With Quote
The Following 3 Users Say Thank You to kunfu For This Useful Post:
easy (03-12-2012), radioflyer (03-11-2012), Stealth01 (03-11-2012)
 Old 03-11-2012, 05:20 PM   #85
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
And remember, you get more bees with sugar than with vinigar.
Suck enough cock and you might get a new motor out of them (doubtful).
"Exclusivity" - CP-enis
Demodded.
The Seals
Nataphen (03-11-2012), radioflyer (03-11-2012), uncorked11 (03-12-2012)
 Old 03-11-2012, 05:26 PM   #86
Eric28243's Avatar
Posts: 554   (View Stats)
Eric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the world
Groaned at 6 Times in 6 Posts
This is indeed doubtful but at their fairly high rate of failure if you're very nice about it they might do... I dunno something for you. Entrusting your entire engine to something so tiny is a big deal.
'08 Polar White Saturn SKY Redline - "The RAWRmobile"
BorgWarner EFR 6758 + IWG Mani, forge v2 BPV, Energy Full Suspension Bushings, GMPP 3-Bars, Vibrant Racing Catted HiFlow Downpipe, WERKS Boost Tubes, Intake, Power-Steering Relocation Kit, Radiator Hoses, and Race FMIC, Koni Yellows + Eibach Pro-Kit's, RPi GT CBE, HP Tuner SquishyTooned on E40, RK Sport Rotors/Pads, DDMWorks 2-gauge Pillarpod and Armrest, Prosport HALO Electronic Wideband and Boost Gauges, Spec Stage 2+ Clutch + Fidanza Single-Mass FryWhee, XTUNERS Gauge Cluster, GM Roadster.com HID/LED Full Exterior and Interior Light Conversion
Dyno: Uhh... fast as hell?
'08.0 Cosmic Blue MS3 - "The Daily" STOCKED OUT (almost)
COBB SRI/TIP - COBB AP SquishyTooned on E40 - COBB XLE BPV - HKS Hi-Power CBE - ITV22s - Corksport RMM Inserts - JBR Shifter Bushings and SSP - PTP Fuel Pump - PG + Treadstone - 35% Tint - ebaY Double-Penetrator - MS3 Vent Kit Install
Dyno: 319 / 331
CWP_MS3 is my mackdaddy
Eric28243 is offline   Reply With Quote
 Old 03-11-2012, 05:31 PM   #87
Stealth01's Avatar
Groans: 201
Very doubtful, since they still don't rate those for our platform. Just for VW 2.0s.
Stealth01
2006 Mazdaspeed6 GT
 Old 03-11-2012, 06:18 PM   #88
17cak's Avatar
thanks alot fellas. and yeah this is my daily driver too.. not only that, but my first investment after college. i have a lot of blood and sweat dedicated to this vehicle (mainly the dp) and now im stuck driving my grandmas buick. HOLLA
melbaro likes this.
The Following 4 Users Say Thank You to 17cak For This Useful Post:
kgb (03-12-2012), phate (03-11-2012), Pseud0logik (03-12-2012), Tokay444 (03-11-2012)
 Old 03-11-2012, 07:07 PM   #89
keymaster's Avatar
Posts: 397   (View Stats)
keymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the world
Originally Posted by Stealth01 View Post
ANy vibes in the clutch pedal?
Seriously, if it's knocking so much you can hear it, stop going WOT and get it looked at.
No vibrations in the clutch pedal. And, I have taken it in to be looked at, complete with data logs off the Dashhawk plotted out...and, of course, I couldn't get it to reproduce the knock despite everything I tried, and they just shrugged off the plots. Did it perfectly when I hit the highway on the way home, as is usually the case when trying to show the dealer something. So, I gave in...I have an AP that I should get around to installing and then see if I can work out what happens and tune around it so it quits knocking so much, or just be ready for it to blow and build a motor.
This reminds me that it's time to pull the plugs and check them, maybe they will show something finally (never have before though). I really do wonder...everyone around here talks about how their engine knocked and blew, and mine just keeps on going. I figure it will survive until the warranty is up in October.
2007 Mazdaspeed 6 GT
keymaster is offline   Reply With Quote
 Old 03-11-2012, 08:59 PM   #90
radioflyer's Avatar
Posts: 729   (View Stats)
radioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the world
Groans: 28
Groaned at 22 Times in 12 Posts
dido on the cock sucking, got me a new motor from mazda.
radioflyer is offline   Reply With Quote
The Following 2 Users Say Thank You to radioflyer For This Useful Post:
melbaro (03-13-2012), Tokay444 (03-12-2012)
 Old 03-11-2012, 09:30 PM   #91
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
sorry to hear about the car op. while you have your motor out you can take out the front grille as well. lol.
Hopefully you will get it back up and running soon..
Speaking of full pumps. I have a PTP fuel pump going for over 40K miles and it is still pumping out 1800-1900 psi
Just a thought.
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 03-11-2012, 09:59 PM   #92
17cak's Avatar
Just a thought.
the grill adds 20 hp.. somethin u would know nothin about!!!!
The Following 5 Users Say Thank You to 17cak For This Useful Post:
Ckmazdaspeed3 (03-12-2012), GLORIFIEDBOZO (03-12-2012), phate (03-11-2012), radioflyer (03-12-2012), sick_role (03-28-2012)
 Old 03-11-2012, 10:50 PM   #93
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Now I'm wondering how much time or how many pulls it takes for the damage to appear when the FRP drops at WOT?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 03-11-2012, 11:06 PM   #94
taf0422's Avatar
Groans: 192
lol. you got me there.
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 03-12-2012, 08:38 AM   #95
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
I personally think that boost spike happens after the destruction has begun, and is either some sort of back pressure or some sort of blockage cause a higher reading at the MAP sensor. If someone see's a flaw this possibility let me know.
Originally Posted by keymaster View Post
Sorry for your loss OP, good luck with the rebuild.
Stuff like this makes me worry...my car at WOT continually knocks, I've seen 7-8 on the Dashhawk and I can hear the pings. Doesn't always happen, but it happens enough that I'm pretty careful when I go for it. I get knocking at partial throttle too in high load situations. But, when I log with the Dahhawk the boost, AFR and fuel pressure look normal, no spikes or anything even when it knocks. This was the way it was stock, and all I've added is a SRI, TIP and step colder plugs, and the car didn't look like it had any mods done when I bought it and I haven't found anything yet. I'm just waiting for the engine to decide to blow one day.
I hate thread jacking, do you have a thread on any of this? If you are getting audible KR while WOT, don't go WOT. Don't just wait for your engine to blow, unless you just have money sitting around that you want to blow, in which case why not just rebuild it now? The PT KR you are getting, is that while cruising on the highway?
 Old 03-12-2012, 09:32 AM   #96
polysynth's Avatar
Posts: 62   (View Stats)
polysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the world
Very possible. This is what Phate said in a previous post as well, and we see a knock right before the boost spike. So that means the spike is a result of some other issue. What caused that knock prior to the spike we don't know, but our best guess at this point is probably the fuel pump.
I think in order for us to confirm whether or not the fuel pump cause the engine blow is to look at the spark plug. Because previous knocks caused by low FP pressure would show up on the spark plugs. Phate said the spark plug looks fine when he pulled it out prior to the engine blow, but i think it's worth a closer look though. WOT knock appear at the base ceramic of the center electrode, which isn't easily spotted unless we intentionally look for it.
polysynth is offline   Reply With Quote
The Following 2 Users Say Thank You to polysynth For This Useful Post:
GLORIFIEDBOZO (03-12-2012), phate (03-12-2012)
 Old 03-12-2012, 09:43 AM   #97
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Yeah, I checked out the plugs under my dual 1k watt halogens when we had them out, haha. I am positive there wasn't any spackling. I am also positive there wasn't any audible detonation prior to the event. I've heard detonation in my own MS3 (and other cars) as a result of bad gas and extreme BAT's, so I'm familiar with the sound.
-06 MS6
-Corn fed 07 MS3 - Sold
GLORIFIEDBOZO (03-12-2012), polysynth (03-12-2012)
 Old 03-12-2012, 10:10 AM   #98
Onelovesoccer's Avatar
Posts: 1,364   (View Stats)
Onelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the world
Groans: 116
Groaned at 13 Times in 7 Posts
sorry to hear OP! subbed for results as well
2010 Liquid Silver w/ Tech Package
270whp/324wtq corrected Dynojet 3/24/12 (93 FREEKPerm)
Cobb AP (91 RichTune) | CS SRI/TIP | cp-e S2 RMM | SURE Shifter Bushings | JBR SSP/Counterweight | UR TP | UR CBE | AT Internals | Denso ITV22s | 35% tint | Sonic Tuning HIDs | MD OCC | JBR TIGs | TSW Nurburgring 18x8.5+45 245/40/18 v12 evo2
Onelovesoccer is offline   Reply With Quote
 Old 03-12-2012, 11:38 AM   #99
keymaster's Avatar
I think I put a thread up a year or so ago with the plots, don't recall for sure.
It's not all the time, and it doesn't just happen at WOT. If I'm on the highway, I'll give it a bit of gas to make a pass and have it knock to 7+ with audible pinging. When I got a log on that one time, I saw that the boost and TP had jumped up as if I had floored it when I knew I hadn't. At WOT, I don't hear the pings, but I'll see the 7+ KR. I also see low KR just tooling around town, but I think that's not real.
It's just honestly strange, because everything runs perfectly fine except for this issue, and that happens intermittently enough that I can't really nail down the exact conditions to reproduce it. If it wasn't for the pings I hear I'd think the sensor was faulty or picking something up...maybe the pings aren't detonation but something else. It would be nice to get a video of it.....
The Following User Says Thank You to keymaster For This Useful Post:
 Old 03-12-2012, 11:42 AM   #100
Eth Fiend
phate's Avatar
Fuel quality is HUGE in these cars - that's my first thought for your case. If you can revive your thread and link us here, as to not derail this thread, we could revisit.
-06 MS6
GLORIFIEDBOZO (03-12-2012), zenger (03-12-2012)
 Old 03-12-2012, 03:04 PM   #101
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
Phate sent me a text about your car today 17CAK. I'll come down next Saturday and help you and Phate pull that engine.
when you going down/coming back?
-Wetz
QFT
The Following User Says Thank You to xfeejayx For This Useful Post:
phate (03-12-2012)
 Old 03-12-2012, 04:09 PM   #102
I'm heading down there around 11AM on Saturday and coming back up sometime Sunday morning.
phate (03-12-2012)
 Old 03-12-2012, 04:50 PM   #103
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Shitty.... looks like Phate got to the car too late.
The car seems to have had several issues in recent past... dropping fuel pressure, high boost, KR, etc.... and that was likely even worse in the colder months, and running an OTS map, without any KR bandaid above 5700 rpm...
GL OP, and sorry for the trouble.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
phate (03-12-2012)
 Old 03-12-2012, 05:14 PM   #104
Tokay444's Avatar
Groans: 793
Audible knock.
Not audible knock retard.
Demodded.
The Seals
 Old 03-12-2012, 05:19 PM   #105
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
Guys, correct me if mistaken. Doesn't the stock MAP sensor scaling end at about 22 psi? If so, wouldn't the sensor report 22 and no higher even if boost was way higher? If OP was monitoring and seeing 22 psi in the past and was not using a manual boost gauge, then his reported overboost may have been much much higher than 22. Just a thought.
Overboost coupled with low WOT fuel pressure under load is a recipe for fail, either instantly or one small step at a time.
And you guys are spot on in concluding that low fuel pressure under load probably had a cumulative effect. Persistent low atomization, wide pulsewidth fuel pooling would lead to the eventual zoom, zoom, boom.
The more recent WOT pulls were just the straw that broke the camel's back, IMHO.
I defer to the experts here. But I think taking a good hard look at the top of the pistions and the top ring lands on tear down will tell us a lot about what happened.
The Following 3 Users Say Thank You to MSMS3 For This Useful Post:
kgb (03-12-2012), phate (03-12-2012), Tokay444 (03-12-2012)
 Old 03-12-2012, 05:48 PM   #106
Yes, the stock MAP sensor is 2.5 Bar = ~36.3 Psia, which is about 21.5-22.0 Psig at this elevation.
The Following 4 Users Say Thank You to silvapain For This Useful Post:
Nliiitend1 (03-12-2012), phate (03-12-2012), SarcasticOne (03-12-2012), xfeejayx (03-13-2012)
 Old 03-12-2012, 09:12 PM   #107
taf0422's Avatar
Groans: 192
I know my stock map sensor would boost cut if it went above or hit 23 psi but it could run >22.8 with no issue.
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 03-13-2012, 03:16 AM   #108
radioflyer's Avatar
Groans: 28
Fuel quality is HUGE in these cars - that's my first thought for your case. If you can revive your thread and link us here, as to not derail this thread, we could revisit. [/B]
Pretty sure this had a lot to do with my blown motor. I was going to this shitty little gas station with the cheapest shit in town, amongst other issues (driver mod included). I watch my KR and fuel trims like a hawk now, let the motor warm up completely, don't load the turbo in 6th under 3k etc.
The Following User Says Thank You to radioflyer For This Useful Post:
phate (03-13-2012)
 Old 03-13-2012, 02:04 PM   #109
keymaster's Avatar
I can't do much about my fuel quality, I live in SoCal and I've never had the car anywhere that saw better than 91 octane. I at least take it to good gas stations, so I don't think bad gas is the issue.
It looks like I never put a thread up...I'll do that once I get to spend some more time working on this and see if I can find something new. Sorry for the derail, back to hoping the OP can get things put back together and running.
 Old 03-13-2012, 02:18 PM   #110
XxSPUDxX's Avatar
Posts: 105   (View Stats)
XxSPUDxX has a reputation beyond reputeXxSPUDxX has a reputation beyond reputeXxSPUDxX has a reputation beyond reputeXxSPUDxX has a reputation beyond reputeXxSPUDxX has a reputation beyond reputeXxSPUDxX has a reputation beyond reputeXxSPUDxX has a reputation beyond reputeXxSPUDxX has a reputation beyond reputeXxSPUDxX has a reputation beyond reputeXxSPUDxX has a reputation beyond reputeXxSPUDxX has a reputation beyond repute
Groaned at 35 Times in 16 Posts
I understand about 1/2 of what is being said in this thread.
XxSPUDxX is offline   Reply With Quote
 Old 03-14-2012, 12:59 PM   #111
HPFPUPGRADE's Avatar
Posts: 403   (View Stats)
HPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the world
Groaned at 22 Times in 17 Posts
Wow, you see so few of these engine let up under WOT and in the upper RPM band.
Did the OP still have the BS in the engine?
HPFPUPGRADE is offline   Reply With Quote
The Following User Says Thank You to HPFPUPGRADE For This Useful Post:
phate (03-14-2012)
 Old 03-14-2012, 01:06 PM   #112
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Another block bites the dust
too bad we can't save these blocks by re-sleeving and reinforcing the hole
07 MS3
The original Genpoo Hater
phate (03-14-2012)
 Old 03-14-2012, 01:09 PM   #113
kunfu's Avatar
Groans: 56
Is their a point that you recommend removing the BS. For example if making X number of HP remove the BS.
Speed 3 2007:
The Following User Says Thank You to kunfu For This Useful Post:
phate (03-14-2012)
 Old 03-14-2012, 01:10 PM   #114
Eth Fiend
phate's Avatar
Yeah, almost all of the stories are either low rpm with lots of boost or just cruising away from a stop :/
I would think the engine still had a balance shaft (it ran very smoothly with no vibes), but we'll know for certain Saturday.
-06 MS6
 Old 03-14-2012, 01:16 PM   #115
Ya, stock.
Its all about oil control and the gear driving oil into the PCV system. To much oil in the PCV system = knock, detonation and on the rare occasion... oil hydro-lock.
Yes, very rare to see one blow up top.
Let me know what you find out on the BS.
The Following 2 Users Say Thank You to HPFPUPGRADE For This Useful Post:
kunfu (03-14-2012), phate (03-14-2012)
 Old 03-14-2012, 05:30 PM   #116
17cak's Avatar
ignore this pic guys im uploading this for a guy who contacted me about where i welded on my cat
 Old 03-14-2012, 05:38 PM   #117
17cak's Avatar
when i went to put in the KMDs we noticed that the pump had been removed for some reason? and as far as i know i still have the balance shaft
 Old 03-14-2012, 05:54 PM   #118
KevMS6's Avatar
Posts: 316   (View Stats)
KevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the world
Is it a big job removing BS?
Never good reading about this
Good luck getting it back on the road
Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft
Tuned with by
KevMS6 is offline   Reply With Quote
 Old 03-14-2012, 10:40 PM   #119
4 hours on your back in the driveway or 2 with a lift and air tools. Just make sure you do it during an oil change and have a few cans of brake cleaner handy.
 Old 03-17-2012, 11:50 PM   #120
17cak's Avatar
sorry for the labeling problem with all these photos. but today we pulled the block to take a look.. thanks to all the guys who came to help today btw! clint and daniel can elaborate more on the damage for everyone
Nataphen (03-18-2012), phate (03-18-2012), silvapain (03-18-2012), xfeejayx (03-19-2012)
SEMA 2010: Mazda brings some serious Zoom-Zoom to Las Vegas Haltech Automotive News 0 11-03-2010 12:27 AM
Mazda design chief gives new meaning to zoom-zoom Haltech Automotive News 0 03-07-2010 10:10 PM
Zoom Zoom BOOM - I joined the blown up club. flyrevs2 MazdaSpeed 3/6 - Turbo Induction 85 09-27-2009 03:54 PM
MAZDA5 HYDROGEN RE HYBRID A FRESH APPROACH TO THE FUTURE OF ZOOM-ZOOM Haltech Automotive News 0 06-10-2008 02:18 AM
Page generated in 0.59015 seconds with 42 queries
