Like Tree6Likes
 Old 03-17-2012, 11:54 PM   #121
17cak's Avatar
Posts: 104   (View Stats)
17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world17cak is the leader of the world
grenage blew up in my block
Black '06 Grand Touring - Cobb AP Stage 2 - M2 DP w/ HF Cat, Magnaflow CBE, AEM SRI, KMD Internals, TurboSmart BPV, SU RMM, Denso ITV22
17cak is offline   Reply With Quote
The Following 4 Users Say Thank You to 17cak For This Useful Post:
Nataphen (03-18-2012), phate (03-18-2012), wankular (03-19-2012), xfeejayx (03-19-2012)
 Old 03-17-2012, 11:59 PM   #122
17cak's Avatar
LAST BUT NOT LEAST, NATOR NATION!! btw check out the most important part on the oil pan the name plate
The Following 10 Users Say Thank You to 17cak For This Useful Post:
GartzSpeed (03-29-2012), mayer (03-20-2012), Nataphen (03-18-2012), phate (03-18-2012), Pseud0logik (03-19-2012), SKiZ0TT (03-20-2012), Teethkikr (03-18-2012), wankular (03-19-2012), xfeejayx (03-19-2012), xhymer (04-10-2012)
 Old 03-18-2012, 12:14 AM   #123
Roddiy's Avatar
Posts: 5,388   (View Stats)
Roddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the world
Groans: 279
Groaned at 58 Times in 47 Posts
Always awesome to see people coming out and helping fellow MSFers,
Good luck with the build/restore, and one quick question:
Are you getting forged pistons or OEM at this point?
2010 LSM Speed3
Bolted + Corn + Meth + ACT 6-Puck
#BakeryTuned
Roddiy is offline   Reply With Quote
The Following 3 Users Say Thank You to Roddiy For This Useful Post:
phate (03-18-2012), rfinkle2 (03-24-2012), SKiZ0TT (03-20-2012)
 Old 03-18-2012, 09:04 AM   #124
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Some info about the day:
The #4 piston and rod caused some major damage. Four holes in the block/pan - one by the starter, one in the pan by the front, one huge hole in the back at the bottom of the block next to the pan, and one random hole above that.
The collateral damage is pretty serious, as well: The starter got taken out by a chunk of the block that got pushed out. The transfer case has a hole blown into it where the huge hole is in the back side of the block.
The biggest piece of piston left is the one pictured above (being held). It and the top of the rod look like they just exploded. The bottom 3/4 of the rod is still attached to the crank. The main girdle got massacred under cylinders 3 and 4. I'm sure that bottom part of the rod had a big part in the block destruction at 6300rpm.
The balance shaft assembly was intact. (@HPFPUPGRADE)
____________________
Spark plugs in cylinders 1, 2, and 3 were oil soaked. Oil was EVERYWHERE in the engine. The intake manifold had so much oil in it, that it was pooled in the bottom and coming out of the throttle body.
The spark plug in cylinder #4 was crushed, but the porcelain was held in, and 3 or 4 pieces were left to attempt diagnosis after wiping them off a bit. They need blasted with brake parts cleaner, but there was no apparent spackling on those pieces to indicate major detonation. I suspected this, as we didn't hear any pinging when the engine let go.
All of the boost control system lines were tight and in good condition.
I'm sure Daniel will have some more info, but I think we're in agreement that we don't have a good indicator of failure mode.
17cak likes this.
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 10 Users Say Thank You to phate For This Useful Post:
17cak (03-18-2012), ak_spray (03-25-2012), BigjohnB20 (03-18-2012), mayer (03-20-2012), Nataphen (03-18-2012), Pseud0logik (03-19-2012), rfinkle2 (03-24-2012), silvapain (03-18-2012), wankular (03-19-2012), xfeejayx (03-19-2012)
 Old 03-18-2012, 04:35 PM   #125
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
Wow. No evidence of recent detonation (at least yet) and no bent rods, explosive separation of piston from upper rod and destruction of piston. Maybe boost did get extreme in recent past before the tune being tested? Maybe way higher than reported 22 psi?
This is baffling. Wonder what the other surviving pistons and ring lands (especially top ones) will look like upon tear down.
Any damage up top in the valve train? Any evidence of jumping timing (valve crashing into the piston, etc.)?
I'm so sad for OP, but now it's time to get the car back in action and to see what can be learned from the failure. A teaching/learning moment.
 Old 03-18-2012, 04:55 PM   #126
We didn't pull the head or valve cover, but the timing chain looked taut based on a visual inspection from underneath.
 Old 03-18-2012, 05:11 PM   #127
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
subbin.
So this is why phate is behind on tunes lol...sry to hear about this tho!
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
phate (03-18-2012)
 Old 03-18-2012, 05:29 PM   #128
nothing to see here....
drknyte's Avatar
Posts: 501   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
Man I wish I could've joined you guys.....
Made quick work of that motor pull.
Keep the knowledge cuming...... all over our faces!!
Good job guys!
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
The Following 2 Users Say Thank You to drknyte For This Useful Post:
Jeremy M (03-19-2012), phate (03-18-2012)
 Old 03-19-2012, 11:47 AM   #129
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
too bad that when there is piston separation, there is no evidence left to diagnose it
hurts so bad to read the t/c took a hit. that's just insult to injury, and more paint to the wallet.
-Wetz
QFT
The Following User Says Thank You to xfeejayx For This Useful Post:
phate (03-19-2012)
 Old 03-19-2012, 05:07 PM   #130
HPFPUPGRADE's Avatar
Posts: 403   (View Stats)
HPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the world
Groaned at 22 Times in 17 Posts
If you get a chance... check the crank end play and check to see if the BS assembly still rotates "clean". Its rare to see cyl 4 let go and normally that cyl will miss the BS assembly.
Have you checked the injectors? If you had an injector failure, that might be an indication to what the problem is.
HPFPUPGRADE is offline   Reply With Quote
 Old 03-19-2012, 07:18 PM   #131
Eth Fiend
phate's Avatar
We haven't done any more than drop the pan to look at the destruction. I suppose we could check end play if I dig out my caliper, lol. Not sure if the crank will rotate much after the destruction, but once the head is off we'll try.
-06 MS6
rfinkle2 (03-29-2012)
 Old 03-20-2012, 06:15 AM   #132
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
When a fuel pump goes bad you'll actually see a rich condition, as you're not getting the atomization you want.
Raw fuel pools on the pistons until things get hot enough to explode.
I blame inadequate fuel pressure.
That makes a lot of sense and the ecu is going to do it's best to compensate for bad fuel pressure by increasing the injector's duty cycle, I know nothing of the disi injectors but regular injector don't like being pushed much beyond 80-85% duty, going beyond that they heat up and can possibly stay static open or closed or even altogether fail.
Sorry to about your misfortune op, sounds like dumb luck, Phate seems pretty damn methodical about the way he approaches tuning.
425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel
Tabasco69 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tabasco69 For This Useful Post:
MSMS3 (03-20-2012), Tokay444 (03-20-2012)
 Old 03-20-2012, 06:27 AM   #133
backward_0's Avatar
Posts: 773   (View Stats)
backward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the world
Subbed. You got a lot of support OP. This is what makes MSF badass.
2013 WRX Stock as Fuck.
1997 Eclipse GSX
The Red Rocket, 2011 MS3 Some other bastards problem now.
backward_0 is offline   Reply With Quote
The Following User Says Thank You to backward_0 For This Useful Post:
phate (03-20-2012)
 Old 03-20-2012, 07:00 AM   #134
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
Originally Posted by HPFPUPGRADE View Post
Wow, you see so few of these engine let up under WOT and in the upper RPM band.
Did the OP still have the BS in the engine?
From what I've seen (unless I just happen to be focusing on these), most engines let up these days under WOT. I know that whenyou were here before, this was not the case, but it seems to be these days. We simply don't have nearly as many put put booms as we used to.
Some examples:
this guy
the guy with the red ms3 that got it on filmon his gopro with shit shooting out of the back of his car
whoisjeremy
superskaterxes
me
forzda (overboost)
bwallace (first Genpu and on a dyno with John@theI"mafucktardshop was tuning him)
I think I had one more, but can't remember now
The Following 3 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
MSMS3 (03-20-2012), phate (03-20-2012), rfinkle2 (03-24-2012)
 Old 03-20-2012, 03:13 PM   #135
xfeejayx's Avatar
Groans: 78
LLlllllloooOOOOoooooooollLLOLOlolOlol
-Wetz
QFT
Ckmazdaspeed3 (03-20-2012)
 Old 03-22-2012, 04:37 PM   #136
17cak's Avatar
if @phate doesnt buy my car i will be parting out fellas, stay tuned for some deals
 Old 03-22-2012, 04:44 PM   #137
Groans: 134
Sorry to hear bro. Good luck... God damn I wish I could buy it. Or u can just sell me the tranny, u don't need that, do u?
 Old 03-25-2012, 09:25 AM   #138
drknyte's Avatar
Groans: 39
I can haz front a pillar plastic cover, says "AIR BAG", drivers side.......
And I would really think it over (if it's paid off), especially cause you have AWD and great potential! Just a thought!
60ft: 2.167
1/8: 9.052
 Old 03-25-2012, 10:54 AM   #139
17cak's Avatar
looks like ill be selling the car fellas pm me if interested or check out the fs section
 Old 03-25-2012, 12:48 PM   #140
memin's Avatar
Posts: 994   (View Stats)
can i have AP? let me know.. G/L
 Old 03-28-2012, 12:49 PM   #141
sick_role's Avatar
Posts: 815   (View Stats)
sick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the world
Groaned at 6 Times in 3 Posts
That sucks man. Sorry to hear. The boom looked/sounded pretty catastrophic, however, so I can't say I'm surprised.
On the plus side, you are now a full time Buick driver. At least it's not an Olds88.
"Also you cannot do anything "like a boss" in a srt4. If you ever get a job where the boss drives a neon, go somewhere else. Apparently that job has no future." - themytb
Oh you mean dogs. Yeah I like dogs. I drive a Hyundai.
sick_role is offline   Reply With Quote
 Old 03-29-2012, 06:08 PM   #142
memin's Avatar
any updates?
 Old 04-17-2012, 04:59 PM   #143
17cak's Avatar
Originally Posted by memin View Post
any updates?
hey sorry r u still lookin for an ap?
 Old 04-17-2012, 09:30 PM   #144
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
Did you sell the car?
 Old 04-17-2012, 10:40 PM   #145
08MS3-19.6PSI's Avatar
Posts: 46   (View Stats)
08MS3-19.6PSI is infamous around these parts08MS3-19.6PSI is infamous around these parts08MS3-19.6PSI is infamous around these parts
Groaned at 96 Times in 14 Posts
hope all goes well man and for phate to cover the damages done well thats fucking great. you almost never see a tuner take responsibility like that. great job phate.
08MS3-19.6PSI is offline   Reply With Quote
 Old 04-18-2012, 06:36 AM   #146
memin's Avatar
[QUOTE=17cak;1366460]hey sorry r u still lookin for an ap?[/Q
yes i send you a pmed!!
 Old 04-18-2012, 03:52 PM   #147
17cak's Avatar
got 7 for it on trade in with no engine and no tbe plus 2k off kbb of my 07 300c
The Following User Says Thank You to 17cak For This Useful Post:
silvapain (04-19-2012)
 Old 04-18-2012, 09:11 PM   #148
LMAO, speed 6 prices are going up
 Old 04-27-2012, 05:26 PM   #149
17cak's Avatar
just found out the dealer took my car to an auction.. they got 4 for it... HAHAHAHA same with @zenger 's car
 Old 04-28-2012, 10:13 AM   #150
zenger's Avatar
Posts: 602   (View Stats)
zenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the world
Groaned at 8 Times in 7 Posts
They got 4 for it?
Fuck yea serves them right the cock suckers
2007-Mazdaspeed 6
BNRSIII~all supportings
Zoom Zoom Boom part out.
zenger is offline   Reply With Quote
 Old 04-28-2012, 12:39 PM   #151
17cak's Avatar
Originally Posted by zenger View Post
They got 4 for it?
thats what adem told me
 Old 04-28-2012, 01:28 PM   #152
Chriscote's Avatar
Posts: 913   (View Stats)
Chriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the world
Groans: 137
Groaned at 17 Times in 7 Posts
sorry for your loss, scares me because i have been workin through some issues with @Bucker for a little while now.
Chriscote is offline   Reply With Quote
SEMA 2010: Mazda brings some serious Zoom-Zoom to Las Vegas Haltech Automotive News 0 11-03-2010 12:27 AM
Mazda design chief gives new meaning to zoom-zoom Haltech Automotive News 0 03-07-2010 10:10 PM
Zoom Zoom BOOM - I joined the blown up club. flyrevs2 MazdaSpeed 3/6 - Turbo Induction 85 09-27-2009 03:54 PM
MAZDA5 HYDROGEN RE HYBRID A FRESH APPROACH TO THE FUTURE OF ZOOM-ZOOM Haltech Automotive News 0 06-10-2008 02:18 AM
Page generated in 0.51482 seconds with 38 queries
