 Old 01-03-2012, 10:45 AM   #1
dynamix's Avatar
Posts: 60   (View Stats)
dynamix is a glorious beacon of lightdynamix is a glorious beacon of lightdynamix is a glorious beacon of lightdynamix is a glorious beacon of lightdynamix is a glorious beacon of lightdynamix is a glorious beacon of light
Post 4wd light blinking on and off
I was driving home from my morning classes and when i get off the highway, my 4wd light start to blink on and off. It didn't stop even after i got home and parked. This is the first time i have experienced this problem before. Once i turned the car off and then back on again, the light was off. Should i be concerned about this or no?
dynamix is offline   Reply With Quote
 Old 01-03-2012, 11:42 AM   #2
speedms6's Avatar
Posts: 825   (View Stats)
do you have different rims or tires on or is everything the same at all 4 corners? also rear diff or transfer case fluid been changed recently or at all?
 Old 01-03-2012, 10:40 PM   #3
dynamix's Avatar
wheels and tires are stock and i am scheduled with the dealer this saturday to have my diff fluid changed?
** I just checked my tires and i found that i have a lump in my passenger rear tire.
 Old 01-03-2012, 10:47 PM   #4
Sid3wayS's Avatar
Posts: 6,789   (View Stats)
Groans: 97
Place elecrical tape over the blinking light n it wont bother u any more.
As for the lump seriously be careful, lumps lead to blowouts wich equals very bad. Change that tire out pronto
TEAM LUXURY
Sid3wayS is offline   Reply With Quote
The Following User Says Thank You to Sid3wayS For This Useful Post:
xfeejayx (01-04-2012)
 Old 01-03-2012, 11:10 PM   #5
dynamix's Avatar
yeah the tape could work if it bothers me alot lol.
I bought a spare rim and tire a few weeks back in case i ever get a flat somewhere or something. I plan on changing that out in the morning.
 Old 01-04-2012, 08:52 AM   #6
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
is the lump on the tread or on the wall of the tire? i'd be surprised if a sidewall lump threw a light, and i'd be surprised if you didnt feel a tread lump while driving.
-Wetz
QFT
 Old 01-04-2012, 11:50 PM   #7
dynamix's Avatar
it was on the tread and i actually never noticed it until i drove on the hughway. I usually drive on small streets majority of the time.
 Old 01-05-2012, 04:16 PM   #8
Matx's Avatar
Posts: 1,681   (View Stats)
how old is the tire? what kind/brand of tire is it
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
 Old 01-06-2012, 06:44 AM   #9
quad4svtspeed6's Avatar
Posts: 82   (View Stats)
quad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond repute
Definitely check the tread depth of the front tires vs the rear....doesnt take much difference to cause the rear diff to engage unnecessarily....before getting new tires i would get the blinking 4wd light, but it was only on long drives of 100 miles or so never got the light in normal city stop and go traffic...
Current Mods>>>>>CPE-Nano..CPE TMIC...TIP....Ebay Test Pipe...Forge V1 BPV...ITV22 Plugs....HyPeRtEcH TuNe
quad4svtspeed6 is offline   Reply With Quote
 Old 01-06-2012, 11:13 PM   #10
dynamix's Avatar
The tires are proxes 4s and they were on the car when i bought it. They are half worn but i plan on changing them out this week, there noisy especially when i go on the highway.
it hasnt come on during stop and go traffic just this one time when i drove on the highway. I was on the highway most of the day today and it didnt come on at all.
Last edited by dynamix; 01-06-2012 at 11:13 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-16-2012, 05:24 PM   #11
dynamix's Avatar
i checked the tread depths and there was a noticable difference between the front and rears. I ended up putting new tires on all corners. I ended up getting some Federal 595s really cheap. Light has come back on since.
 Old 01-16-2012, 08:12 PM   #12
671 grains of reason's Avatar
Posts: 350   (View Stats)
671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world
check/change out the rear end fluid yet?
2006 MAZDASPEED6 // SURE R6 // SURE AEROS & TIH // COBB AP // JBR TIG // SURE ANCHORS & SHORTCUT // SURE DREADNAUGHT // WHITELINE RSB // RACING BEAT E.L. // ULTRA GAUGE // AMSOIL FLUIDS
formerly pursuit_special
671 grains of reason is offline   Reply With Quote
 Old 01-16-2012, 08:37 PM   #13
scubasteve711's Avatar
Posts: 1,238   (View Stats)
scubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the world
Has or Hasn't??
scubasteve711 is offline   Reply With Quote
 Old 01-16-2012, 11:12 PM   #14
dynamix's Avatar
my bad hasn't come back on.
 Old 01-16-2012, 11:26 PM   #15
Karmat's Avatar
Posts: 1,179   (View Stats)
Karmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the world
It was due to the lump as it increased the rolling circumference of the wheel. It overheated the rear diff which caused the light to flash.
I had it happen to me when I had 2 different sets of 245/40 tires and the circumferences differed.
2007 Mazdaspeed 6 (Velocity Red)
2002 Corvette Z06 (Black)
2001 Mazda Millenia S (Brilliant Black) - GONE
Karmat is offline   Reply With Quote
tpms blinking dantes5823 2010 MS3 - Wheels & Tires 12 12-23-2011 11:56 AM
Fog light blinking with highs spdaddicted MazdaSpeed 3/6 - Car Audio & Electronics 0 11-30-2010 02:32 PM
My message light is blinking with 1 new message gsrtype1 Website Help/Feedback 11 07-02-2009 10:04 AM
Audi traffic light detection system gets the green-light Haltech Automotive News 1 09-21-2008 01:24 PM
All-in-One Black Studio Light Kit (includes Light Tent, 2 Lights, and Acrylic Table) $99.99 Haltech Hot Deals Section 0 03-26-2008 01:24 AM
Page generated in 0.66508 seconds with 28 queries
