 Old 04-14-2018, 04:01 PM   #1
LenSpeed6's Avatar
Posts: 122   (View Stats)
LenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to behold
Default Arp main studs vs balance assembly
While assembling my engine with arp main studs I noticed that the studs hit on balance assembly, has anyone else run into this? I cannot mesh the gears from the crank to the balance assembly because of this, was not planning on doing a delete kit but if that's the only way to use the arp studs then that's what's gonna have to happen, got a bunch of money tied up in arp stuff so I'd like to use the studs both for the mains and the head.
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump
 Old 04-14-2018, 04:11 PM   #2
JSmith's Avatar
Posts: 697   (View Stats)
Groans: 103
Groaned at 6 Times in 6 Posts
Believe others have had to cut down the arps.
 Old 04-14-2018, 06:24 PM   #3
shaneski's Avatar
Posts: 490   (View Stats)
Engine builder had mine cut down, i don't have the specs they were cut down to though.
The Following User Says Thank You to shaneski For This Useful Post:
greg08 (04-14-2018)
 Old 04-14-2018, 07:38 PM   #4
greg08's Avatar
Posts: 480   (View Stats)
greg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond repute
Groaned at 22 Times in 15 Posts
Shaneski, when you got your head ported and polished, did you get the exhaust side ported and polished too or just the intake side?
greg08 is offline   Reply With Quote
 Old 04-16-2018, 08:43 AM   #5
shamie's Avatar
Posts: 926   (View Stats)
BSD and get rid of 18 lbs.
Or cut the ARPs or use OEM mains.
I had my crank bore realigned since the ARPs have a higher torque than OEM.
2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, 51R Battery Box & Raider's AD / StopTech Brakes
Main studs/ bolts wyeto MazdaSpeed 3 - Engine, Transmission & Driveline 3 02-04-2015 12:22 AM
ARP main studs and balance shaft KCi 2010 MS3 - Engine, Transmission & Driveline 1 12-23-2014 09:29 PM
Rods and main studs ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 2 06-08-2009 10:11 AM
Page generated in 0.25569 seconds with 24 queries
