 Old 10-16-2009, 06:55 AM   #1
needforspeed6's Avatar
Posts: 59   (View Stats)
needforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond repute
Default Automatic Climate Control Question
Hey Guys,
I just got my MS6 about a month ago. It is getting pretty cold here in MI (in the mornings it is upper 30's). Anyway, when I turn my auto climate control on and set it to 70 degrees, it still shows that the air conditioning is on. It is blowing warm air, but the a/c button is lit up. Does the A/C always run in auto mode?
needforspeed6 is offline   Reply With Quote
 Old 10-16-2009, 07:13 AM   #2
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
if you hit the auto mode button it will, once you turn the speed of the fan it should turn off the auto climate, i have a ms3
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 10-16-2009, 09:34 AM   #3
Problem is, I would like to be able to use my auto climate control without having the ac running all the time (Especially in the winter)
 Old 10-16-2009, 09:54 AM   #4
clos561's Avatar
use the right wheel to adjust temp and unpush the ac button
 Old 10-16-2009, 10:19 AM   #5
N118GT's Avatar
Posts: 347   (View Stats)
N118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the world
Groans: 56
Groaned at 25 Times in 13 Posts
I'm assuming the MS6 auto climate control works similar to the MS3. If that's the case, the auto CC works with varying degrees of automation.
IE. Set a vent location and it will still maintain the temperature without changing your vent settings. I believe it will continue to work with the a/c off, and will attempt to keep the cabin to what you have selected, without the a/c, which won't be a problem in the winter.
Another thing to consider is that because the a/c light is on doesn't mean the compressor is running, it just really indicates that the climate control has the discretion to run the compressor if it decides that it's necessary.
N118GT is offline   Reply With Quote
 Old 10-16-2009, 03:34 PM   #6
fjames's Avatar
Posts: 1,058   (View Stats)
The way I look at it (ms3) it's always in auto, but pressing "auto" adds vent and fan control. I never use "auto." It works great for me maintaining temps, and I have full control over fan, vent and AC when needed.
Edit: I almost always have split vent in, but if you change to floor/defrost it cycles compressor without the light.
 Old 10-16-2009, 03:46 PM   #7
memin's Avatar
Posts: 993   (View Stats)
 Old 10-16-2009, 04:31 PM   #8
retrobmx63's Avatar
Posts: 436   (View Stats)
retrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the world
It doesn't mean the A/C compressor is running. The light just means it is enabled. The A/C is used in cold climates to dehumidify the air. It will only come on when it needs to.
Hey, do my fingers smell like your mother?
retrobmx63 is offline   Reply With Quote
 Old 10-18-2009, 01:23 PM   #9
Thanks for the clarification guys!
Wastegate control, Boost spikes, PID control FreeFlyFreak
Cobb ATR Support
83 11-05-2009 11:40 AM
NHTSA rarity: Hearing on CAFE and climate Haltech Automotive News 0 08-01-2008 01:40 PM
Lawmakers say EPA to delay action on climate Haltech Automotive News 0 07-11-2008 10:11 AM
GOP: Climate bills would make $4 gas look cheap Haltech Automotive News 1 06-19-2008 12:04 PM
GOP: climate bills to make $4 gas look cheap Haltech Automotive News 0 06-19-2008 09:00 AM
Page generated in 0.29393 seconds with 25 queries
