  • 1 Post By Fermion
 Old 07-01-2019, 06:59 PM   #1
Fermion's Avatar
Posts: 299   (View Stats)
Fermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the world
Default cleaning and prepping the block
I cannot seem to find a good thread regarding prepping the longblock and cleaning the tops of the pistons prior to performing a headgasket repair. What have you guys done? Acetone and a razorblade? Brass wire brush?
2007 MS3 Red
HKS BPV, AEM CAI, COBB TIP, Eibach Pro Springs, Black RPF1's 17x9 +45, CNT Catless DP, Racing Beat TBE, JBR SSP & Bushings
Fermion is offline   Reply With Quote
 Old 07-03-2019, 08:26 AM   #2
Fstrnyou's Avatar
Posts: 2,412   (View Stats)
To clean the deck surface, I used a razorblade. Be sure to plug all holes/cylinders and/or have a vacuum, set to full suck, while you scrape the surface so that crud doesn't fall into the oil channels, coolant channels, or get jammed in the piston rings.
Leave your piston tops alone. If you want clean pistons, do a rebuild.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
The Following 2 Users Say Thank You to Fstrnyou For This Useful Post:
Fermion (07-03-2019), MSMS3 (07-03-2019)
 Old 07-09-2019, 06:26 PM   #3
Fermion's Avatar
Not quite sure what I was looking at initially. The piston is definitely compromised when I went to resurface the block. Now I need to decide what to do. Part out and sell it or drop a new engine in.
2007 MS3 Red
 Old 07-10-2019, 12:22 PM   #4
Jeff23spl's Avatar
Posts: 1,937   (View Stats)
now you know why the head gasket broke....instead of just craking a ring land, the heat and knock also made it melt taking the gasket with it. (or was remanufactured without being decked)
i'm curious about those pistons...i never notice the writing on mine but it is looking like a #3 installed for #1.....
Drop the pan and get it out to see how is the cylinder wall but....humm
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-10-2019, 12:59 PM   #5
Fermion's Avatar
@jeff23spl It’s a 2007 so the old style pistons. All the pistons say M2 on them and that’s an arrow pointing towards the crankshaft side of the engine, not a 1.
Jeff23spl likes this.
2007 MS3 Red
 Old 07-10-2019, 01:56 PM   #6
Jeff23spl's Avatar
ok, i will check mine, it is on a shelf somewhere since 2015 lol
Wife drive 2010 CX7
Spy Shots: VW prepping new big-boy Golf Plus for Europe Haltech Automotive News 0 08-25-2013 11:30 AM
Report: Lincoln prepping MKZ re-launch? Haltech Automotive News 0 04-04-2013 09:00 AM
Prepping Speed3 for Auto-X? Alejo_NIN Auto-X / Road Racing / Time Attack 9 05-17-2012 06:12 AM
Prepping for a Intake Mani PNP superskaterxes MazdaSpeed 3 - Engine, Transmission & Driveline 3 01-10-2009 05:59 PM
Page generated in 0.26373 seconds with 22 queries
