![]() | | #1 | ![]() |
Rep Power: 6755 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,368
(Thread Starter) | Neutral : +1 score It might save you guys some dough and include better parts etc.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant |
| The Following 17 Users Say Thank You to 06Speed6 For This Useful Post: | 802MS3 (07-11-2012), ak_spray (07-16-2012), Angr-E1 (07-22-2012), BigjohnB20 (07-12-2012), Boosten Ya(josh) (07-12-2012), dan7225 (07-16-2012), easy (07-11-2012), h.h.sk1nny (07-15-2012), McGee (07-12-2012), memin (07-11-2012), p057 (07-15-2012), paveltol (07-13-2012), rob ms6gt (07-29-2012), SLOWHATCH (07-15-2012), SofaKingAwesome (09-06-2012), theschrum (08-13-2012), Tomas (08-04-2012) |
![]() Join Date: Mar 2010 Location: Colorado Springs, CO, USA
Rep Power: 5060 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,059
Groans: 199
Groaned at 163 Times in 102 Posts
| Not Ranked : 0 score
Depending on price, I might be. My clutch is starting to slip in 4th and 5th, so it's only a matter of time.
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 6540 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,999
Groans: 58
Groaned at 25 Times in 21 Posts
Lol, me too on a 5 to 4 down shift. ACT 6 puck + street lite flywheelage coming soon.
__________________ ![]() CorkSport Sponsored driver~~~First amphibious PU~~~World record fastest fully bolted 2013 Pu! Fast Pu is Fast best ET> 12.586 best trap> 114.25. Thanks to all who helped me get back in the Pu! |
![]() | | #4 | ![]() |
| Queen Bish ![]() Join Date: Mar 2012 Location: Colorado Springs, CO
Rep Power: 677 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 644
__________________ 2008 Red MS3 GTX3071R with ATP EWG Hotside and Tial MVS EWG, Full Race Manifold, Cobb AP, ATP MAF, ATP TIP, JBR Trilogy, PTP Safe Seals & Stud Kit, 3bar MAP, Grimmspeed EBCS, Autotech Internals, VTCS Delete AQ Catted DP, Corksport FMIC, Corksport Exhaust, Matt Damond OCC, NGK's (1 Step Colder), ACT 6 Puck Sprung w/ Streetlite FW ![]() ![]() 50/50 Mix - 416hp/365tq Pump - 411hp/403tq [02:58 PM] dturboman: and ZZB will happen one day, its just how long you can avoid it for [09:15 PM] Erich: if you aren't notching your block, your turbo isn't big enough | |
| The Following 3 Users Say Thank You to sassyspeed3 For This Useful Post: |
![]() | | #5 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 10006 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,737
Groans: 98
cheaper then ACT? IMO the ACT is the best kit out there money can buy cause the pedal pressure is near stock and it holds retarted amount of power. you get a new clutch, FW, PP, TOB, PB all for 650ish shipped. if/when the items become worn out, they have a service that resurfaces your FW/PP and puts new pads on your disk for $150 shipped and you know it was done perfectly because its the damm mfg lol. im all for new options so lets see what you can come up with marcus!!!!
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 |
| The Following 10 Users Say Thank You to superskaterxes For This Useful Post: | 06Speed6 (07-11-2012), atvfreek (07-16-2012), chimmike (07-15-2012), doubleflusher (07-12-2012), Downmented (07-12-2012), MazdaGaragePat (02-09-2013), p057 (07-15-2012), SLOWHATCH (07-15-2012), SofaKingAwesome (09-06-2012), Vader (07-16-2012) |
![]() | | #6 | ![]() |
The kit I am putting together should hold 600-700wtq for years, I think I also have a 900wtq option. Its pretty sweet stuff and it should hold up really nice. I can duplicate the act kit with better parts for less, there is a fair amount of markup on even their stuff. Is that Act rebuild thing for all discs, fw, and pp? I bet its not but ill look into it. I bet shipping is extra too.
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | p057 (07-15-2012), superskaterxes (07-12-2012) |
![]() | | #7 | ![]() |
Groans: 58
Give Eric at Mazdaspeed 3 - EdgeAutosport.com a call.
| The Following User Says Thank You to kritz For This Useful Post: | EdgeAutosport.com (07-12-2012) |
![]() | | #8 | ![]() |
![]() Join Date: Mar 2009 Location: Oceanside, CA
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 896
I have had great luck and service with act so I will buy from them to support their business. That being said I would be down for that timken tob if it is proven to work.
__________________ Murdered out 2007 speed3 GT with navi. |
| The Following User Says Thank You to mtnrunner For This Useful Post: | EdgeAutosport.com (07-12-2012) |
![]() | | #9 | ![]() |
![]() Join Date: Jul 2009 Location: Ballston Spa, NY
Rep Power: 199 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,699
Groans: 116
| Not Ranked : 0 score Damn, I wish I would've known that before i replaced my clutch ><
__________________ 2006 MS6 #367 Liquid Platinum 52,000 miles Engine - GTX3071R again soon - CP-E whale penis - SURE SRI (3.25" MAF housing - EBay DP - Magnaflow CBE - Denso ITV22's - Autotech HPFP internals Electrical - GS EBC - Cobb AP self tuned Drive train - Techna-fit Stainless Steel clutch line - SURE RMM - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's Fluids - Brakes/clutch - ATE Super Blue. Transmission - Motorcraft synthetic. Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40. ![]() |
![]() | | #10 | ![]() |
![]() Join Date: Sep 2009 Location: Skokie, IL
Rep Power: 327 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,029
In for more details.
__________________ 06 LPM MS6: The Essentials |
![]() | | #11 | ![]() |
| Unicorn Farts ![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 1074 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,319
Groans: 96
Groaned at 35 Times in 28 Posts
| Not Ranked : 0 score 06Speed6 Mind If I ask how you found the timken bearings. What manufacture is the stock one from. I work for timkens only competitor in the states NTN-Bower. If I knew the exact specs of the bearing I might be able to get you comparable bearings for less. We do a lot of OEM stuff for american auto companies and mitshu. Alot of our business is with heavy equipment such as CAT John Deere. Dana axels. I don't know if we do any OEM stuff for Mazda. Sent from my Galaxy Nexus using Tapatalk 2
__________________ Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms |
| The Following User Says Thank You to Deldran For This Useful Post: | atvfreek (07-16-2012) |
![]() | | #12 | ![]() |
![]() Join Date: May 2009 Location: Kankakee, IL
Rep Power: 7946 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,668
Groans: 121
The stock and the ACT TOBs suck. I bought a much better TOB for $45 from Stefan, but I'm afraid I don't know where he got it from. Tapadatass
__________________ ATP GTX3071 IWG . 10.5:1 pistons . K1 Rods . Balance Shaft Delete . COBB AP . eBay Special Catless DP . Mazdaspeed Accessory CBE . OCC . Autolite XP5364 Spark Plugs . TRZ TMM . TRZ RMM . MDM SSP . JBR Shifter Bushings . JBR EGR Delete . KW V1 Coilovers . SPC Rear Camber Arms . EBC Yellowstuff Pads . Autotech HPFP internals . 3-Bar MAP Sensor . N2MB WOT Box . ACT 6-Puck Sprung Clutch w/ Streetlite Flywheel . Konig Milligrams 18x8.5 et45 with 245/40's . GrimmSpeed EBCS . Self-PnP IM with VTCS removed . TWM full replacement shifter with 3" extension . TS BPV SU Edition . CX Racing FMIC . HTP 3.5" Intake . Lots of ricer mods . Beans Above the Frank Build http://www.mazdaspeedforums.org/forum/f541/beans-above-frank-build-115919/ |
![]() | | #13 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Burlington, VT
Rep Power: 2438 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,388
Groans: 188
Groaned at 102 Times in 55 Posts
seems like ACT actually took the criticism from lenny and did something good with it. aren't they banned from the foum? (saying this without actually checking)
__________________ '08 White MS3 w/ ported ATP 3071r, fat tires, and other sheit. No Meth or E. hit up NJSPEED3 so he can port yo intake mani! |
| The Following 2 Users Say Thank You to 802MS3 For This Useful Post: | doubleflusher (07-12-2012), superskaterxes (07-12-2012) |
![]() | | #14 | ![]() |
![]() Join Date: Apr 2011 Location: New Mexico
Rep Power: 209 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 954
Interested!
__________________ 2011 CBM MS3 (Daily Driver) Cobb AP w/Self-Tune // JBR 3.5 WP // GS EBCS (2-Port Mode) // PG Piping // X02 Racing IC // Forge V1 // Autotech FP // ITV22's // JBR 88/80/80 RMM/TMM/PMM // Full-Race 3" DP // Muffler Delete 1997 Black SC300 (Underconstruction) "Blown headgasket, turbo seals, warped head" 2JZGTE/W58 (Aristo V300 swap) // Custom FMIC // Custom DP // HKS CBE // Dyno tuned 412rwhp |
![]() | | #15 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() Thanks: 1
im very interested!!!! im down for a kit thats better than the ACT and better pricing (not that the ACT isn't to bad of a price already for what you get), when you think you might know something im down to buy ASAP!!!!
![]() | | #16 | ![]() |
Ill know when I get the tob in
![]() | | #17 | ![]() |
Groans: 98
why does everyone say the new ACT TOB's suck? i dont think anyone has had their "new revamped" clutches long enough to say anything was poorly designed. doubleflusher had his clutch fucked up when he took it out and they found a mfg defect and replaced everything for free!!!! just be careful on how strong you increase the clamp load on the PP marcus because thats how the CM clutches failed. people couldent shift at WOT due to our sock hydraulic system not being able to support that much pressure.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 | |
| The Following 3 Users Say Thank You to superskaterxes For This Useful Post: |
![]() | | #18 | ![]() |
Groans: 121
I wish I could find the picture I took of the stock TOB, ACT TOB, and the one I got from Stefan. The ACT is identical to stock, and The one Stefan found was much beefier. Actually, I can take another pic tonight since I have everything out anyways. Tapadatass
| The Following User Says Thank You to silvapain For This Useful Post: | ak_spray (07-16-2012) |
![]() | | #19 | ![]() |
| psn boostenya ![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 1306 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,899
Groans: 40
Groaned at 15 Times in 13 Posts
| Not Ranked : 0 score How did you prove you are in the military?
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
![]() | | #20 | ![]() |
| Hair by Voltron ![]() Join Date: Feb 2009 Location: Hillsborough, NJ
Rep Power: 146235 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51,120
Groans: 1,404
Groaned at 310 Times in 292 Posts
The rebuild service from ACT includes repucking the clutch disc and resurfacing both the FW and PP. It's $150 plus shipping. That deal can't be beat by anyone. Like superskaterxes said, they found an issue with mine. One of the rivets on the clutch disc wasn't properly rolled, so they did all the work for free.99 and didn't charge me for shipping either. I felt like a winner on this day. I did however, purchase a new pilot bearing and TOB from Edge. Might as well have all new stuff .
__________________ ![]() 11.91 @ 122.48 1.85 60' - 12/4/11 - Atco Raceway 11.85 @ 119.69 1.75 60' - 4/15/12 - Mason Dixon Dragway For Sale Section Rules UPDATED 5-17-2013! Please read before posting! |
| The Following 5 Users Say Thank You to doubleflusher For This Useful Post: | ak_spray (07-16-2012), EdgeAutosport.com (07-12-2012), p057 (07-15-2012), silvapain (07-12-2012), Vader (07-16-2012) |
![]() | | #21 | ![]() |
| Not Ranked : 0 score you have to scan them your ID. I think it was originally like $968 or something and we paid $581 with shipping.
| The Following User Says Thank You to sassyspeed3 For This Useful Post: | Boosten Ya(josh) (07-12-2012) |
![]() | | #22 | ![]() |
Groans: 1,404
| $581 is a decent price, but that $968 is way over inflated.
| The Following User Says Thank You to doubleflusher For This Useful Post: | memin (07-12-2012) |
![]() | | #23 | ![]() |
| Veblen Goods ![]() Join Date: Jan 2009 Location: Dania Beach, FL
Rep Power: 2126 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,374
Marcus, I am in if you can get this ready soon. I need a new clutch bad.
__________________ ![]() GHEY THUNDER |
![]() | | #24 | ![]() |
Yeah I am going to be careful with pp pressures, i found stefans tob and used it to find the timken tob. Stefans tob is a interchange part so its a direct fit, the timken has the same dimensions but is not listed as a interchange. The timken is also metal and is supposed to have a better grease seal.
![]() | | #25 | ![]() |
Groans: 121
__________________ ATP GTX3071 IWG . 10.5:1 pistons . K1 Rods . Balance Shaft Delete . COBB AP . eBay Special Catless DP . Mazdaspeed Accessory CBE . OCC . Autolite XP5364 Spark Plugs . TRZ TMM . TRZ RMM . MDM SSP . JBR Shifter Bushings . JBR EGR Delete . KW V1 Coilovers . SPC Rear Camber Arms . EBC Yellowstuff Pads . Autotech HPFP internals . 3-Bar MAP Sensor . N2MB WOT Box . ACT 6-Puck Sprung Clutch w/ Streetlite Flywheel . Konig Milligrams 18x8.5 et45 with 245/40's . GrimmSpeed EBCS . Self-PnP IM with VTCS removed . TWM full replacement shifter with 3" extension . TS BPV SU Edition . CX Racing FMIC . HTP 3.5" Intake . Lots of ricer mods . Beans Above the Frank Build http://www.mazdaspeedforums.org/forum/f541/beans-above-frank-build-115919/ | |
| The Following User Says Thank You to silvapain For This Useful Post: | Boosten Ya(josh) (07-12-2012) |
![]() | | #26 | ![]() |
![]() Join Date: Jan 2009 Location: York, PA
Rep Power: 1357 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15,062
Groans: 153
mine just started slipping as well in 4th gear. Stocker has 82K on it. Anyone have thoughts to what clutch I should put back in? My car is mainly daily driven, goes on road trips and I usually go WOT a few times a day. It will probably never see the track either. I was leaning towards an ACT clutch but it has been so long since I've needed to install a clutch since all my other previous cars had 180+K on them and clutches were fine.
__________________ 07 MS3 GT.. Engine:Cobb AP,BNR S3,FREEKTUNED 25PSI,Wiseco Pistons/Manley Rods,NJSpeed Manifold, Bosch 3bar MAP,CS DP/RP&cat-back,DNP manifold,FP internals,JBR 3.5"WP,CP-E flange HKS,DO Stage II 75% meth,PG piping,TR8L FMIC,JBR Trans mount 70d&80d RMM,DH CP-E mount,Colder Plugs,SURE shifter bushings,JBR SSP,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,windage tray,JBR BSD,JBR TIG,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint.Suspension/Wheels:Enkei RPF1 17x9,extreme contact DW,Eibach 5mm spaces H&R springs,koni yellows. BNR-S3 424/397 @GSD Dyno 414/390 at MNM KILLAH BUILT/FREEK TUNED |
![]() | | #27 | ![]() |
Groans: 121
I also prefer the steel flywheels over the aluminum ones, though the removable face on the Fidanza flywheels are pretty sweet. Tapadatass
![]() | | #28 | ![]() |
| I'm a real live nigga ![]() Join Date: Aug 2011 Location: Poughkeepsie, NY.
Rep Power: 835 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,686
Groans: 130
Groaned at 36 Times in 28 Posts
what would be looking at price wise? swapping tranny soon and will be replacing clutch, lemme know.
__________________ ![]() MS3...GOOD BYE! 91 Miata...HELLO! Yoko S-Drives Konig Feathers Koni Str.t Eibach Prokit Stoptech Pads & Rotors Hella Vision Plus |
![]() | | #29 | ![]() |
Rep Power: 272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 337
Did anyone try the SPEC self ratcheting clutch kits with the OEM flywheel? Are they good for anything?
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B14 PSS, SSR Type-F, Michelin PSS 225/40/R18 US Spec, CS RMM Inserts, AutoExe Street Pads Cobb SRI, SU TMIC, Cobb XLE, NGK LTR7IX, Corksport CAI Box, UR catted DP and res TP, GS EBCS, Autotech internals, GTX3071, Bosch 3BAR MAP Sensor StratiVersaTuned |
| The Following User Says Thank You to mituc For This Useful Post: | Boost_creep (07-15-2012) |
![]() | | #30 | ![]() |
![]() Join Date: Nov 2011 Location: Caldwell, ID
Rep Power: 563 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 664
Mine is starting to go in 4th and 5th too. Oober K04 torque FTW!!!! Def Interested. Keep us posted
__________________ - Stock OEM k04 - Cobb AP - 3" ATP MAF w/9" Amsoil Filter - Grimmspeed EBCS - cryo'd Act 6 Puck w/Streetlite FW - HTP 3" Inlet - Bosch 3 Bar w/PNP Harness - Forge BPV V1 - CP-E 3" Single SS Exhaust - M2 Dp - Custom FMIC - PTP BSD - EGR Delete - Sonic Tuning S3 CO's - Enkei PF01 - 235/45/17 Toyo T1 Sport - Sure Dreadnaught - Sure Torq - AWR Pass. MM - PTP RV - KMD Internals - 50/50 e85 - Sure Countershift - Blox 490 LE - PNP'd IM/Head - VG Sharkfin Antenna - Car_Led Tails - Speedline CF Grill - 12.301 @ 113.20, stock turbo, stock ex. manifold, stock clutch ![]() Awaiting: The first 11 sec STOCK k04 powered Mazdaspeed!!!! ![]() ![]() |
![]() | | #31 | ![]() |
Groans: 153
Im definitely interested in something too since I have to have this installed before august 19th. Hahaha
![]() | | #32 | ![]() |
Groans: 121
![]() | | #33 | ![]() |
Groans: 153
morning. I dont want my leg to be destroyed!
__________________ 07 MS3 GT.. Engine:Cobb AP,BNR S3,FREEKTUNED 25PSI,Wiseco Pistons/Manley Rods,NJSpeed Manifold, Bosch 3bar MAP,CS DP/RP&cat-back,DNP manifold,FP internals,JBR 3.5"WP,CP-E flange HKS,DO Stage II 75% meth,PG piping,TR8L FMIC,JBR Trans mount 70d&80d RMM,DH CP-E mount,Colder Plugs,SURE shifter bushings,JBR SSP,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,windage tray,JBR BSD,JBR TIG,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint.Suspension/Wheels:Enkei RPF1 17x9,extreme contact DW,Eibach 5mm spaces H&R springs,koni yellows. BNR-S3 424/397 @GSD Dyno 414/390 at MNM KILLAH BUILT/FREEK TUNED | |
![]() | | #34 | ![]() |
![]() ![]() Join Date: Nov 2010 Location: Mount Sinai, NY
Rep Power: 243 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,045
| Not Ranked : 0 score I have. After bolting in an act street kit, and completely hating it, I then went to the spec self-ratcheting unit with my oem (cut) flywheel. Pedal feels exactly like oem, and engagement is perfect. I couldn't be happier now.
__________________ 2009 True Red Mazdaspeed 3 GT - 326whp/360wtq E30, Cobb AccessPort, Cobb SRI/TIH, Sure ID300 Maf UR v2 Catted Downpipe/Resonated Testpipe, Racing Beat CBE Corksport TMIC/Tubes, Grimmspeed Ported Throttle Body KMD v2.1 FP Internals, PTP Seals/Studs, JBR TIG/EGR Delete Turbosmart BPV, Denso ITV22, Bosch 3 Bar, Optima RedTop Snow Performance Stage 2 WMI Kit, Sure Torq R3 RMM SPEC Stage 2+ Clutch, Goodyear Eagle GT, EBC Red Stuff H&R Coilovers, Corksport RSB |
![]() | | #35 | ![]() |
I am waiting for everything to come in, I have a couple discs, three throw out bearings, and two pressure plates on their way and I am thinking of getting another pp. I also need to go through the hydraulic system and find upgrade parts. I know that slave cyl has a huge interchange part number list.
![]() | | #36 | ![]() |
| thread killer ![]() Join Date: Sep 2009 Location: Oak Pollen Central
Rep Power: 784 ![]() Thanks: 1,896
Groans: 84
Groaned at 6 Times in 4 Posts
i dont mind a little extra pressure, but i dont want to have to start a workout regimen to drive my car. I need a clutch that can handle up to around 500 tq. I'm only going to need 350-400 right now, but hopefully in the future i'll be upgrading rods/pistons. I've heard horror stories from the SPEC and clutchmaster clutches, heard good about ACT, but a story here and there about them being quite a pain to operate... now i heard that some company is coming out with some fantastic clutch.... but apparently they were supposed to release it weeks ago... still havent. I really need a clutch SOON. just Friday, when I floored it in 5th, it slipped bad to 6k rpms before i released and let off the gas... just shitty. anyways, i'm hoping to get some great information before my clutch starts slipping more frequently. For now, i'll have to lay off it. |
![]() | | #37 | ![]() |
Yeah I am looking to make a 500wtq kit and a balls out kit, but I think the 500ish wtq kit will cover most of the possible market.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | p057 (07-16-2012) |
![]() | | #38 | ![]() |
Groans: 40
I would like a Clutch that lasts 60,000 miles while holding 500wtq.
![]() | | #39 | ![]() |
Groans: 153
| Not Ranked : 0 score ^^^ditto
| The Following User Says Thank You to taf0422 For This Useful Post: | jracer (07-16-2012) |
![]() | | #40 | ![]() |
Groans: 84
| Not Ranked : 0 score Not sure if this is even asking too much. wonder what corvettes and cobras use...
| Announcing cp-e Stage 1,2 &3 Clutch Kits | www.cp-e.com | Custom Performance Engineering (cp-e.com) | 52 | 06-20-2012 02:17 PM |
| Year End Clearance Deals - ACT Clutch Kits & Rally Armor Mud Flaps | maperformance | Modern Automotive Performance | 87 | 05-04-2012 02:43 PM |
| led kits | tiness69 | MazdaSpeed 3/6 - Car Audio & Electronics | 5 | 04-12-2010 02:28 PM |
| clutch vibration at top of clutch PLEASE HELP | livetoskate06 | MazdaSpeed 3 - Engine, Transmission & Driveline | 84 | 03-06-2010 05:53 PM |
| Lip kits for MS6 | manofhonor24 | MazdaSpeed 3/6 - Appearance | 5 | 11-07-2009 12:54 PM |
