Notices
Like Tree14Likes
 Old 09-25-2012, 11:45 AM   #41
I got all dem pipes
Zdraveca's Avatar
Posts: 1,472   (View Stats)
Zdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the world
Groans: 58
Groaned at 21 Times in 21 Posts
Originally Posted by pzr2874 View Post
Then riddle me this. I was there last Friday damn near the entire day and not 1 person touched the car (it had an atv parked under it) while ars came in and out for oil changes, fluid changes or what have you.
Maybe the turbo was sent out, no clue as his DP was sitting on the ground next to the car.
Subbed
this
the car was sitting there without engine i it for at least 3 months and the last time i saw it it had one in but it was just chillin on a lift
2011 MS3
Cobb AP,Cobb SF, Cobb TIP, KMD interals, ETS TMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR shifter bushings, Corksport CAB, Corksport Short Shifter Plate, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8, Nitto NT-555 245/45/17
E85 FREEKTUNE
Zdraveca is online now   Reply With Quote
The Following User Says Thank You to Zdraveca For This Useful Post:
BOTTLEFED08 (09-25-2012)
 Old 09-25-2012, 11:46 AM   #42
EdgeAutosport.com's Avatar
Posts: 4,532   (View Stats)
Groaned at 9 Times in 7 Posts
Originally Posted by XLT_66 View Post
MBC or EBCS? Catted or non-catted DP?
mbc and non catted always helps
Auto Tech Fuel pump internals #1 Source!
PM Me for Details or call me 303-268-2140
The Following User Says Thank You to EdgeAutosport.com For This Useful Post:
chimmike (09-25-2012)
 Old 09-25-2012, 12:01 PM   #43
Matx's Avatar
Posts: 1,618   (View Stats)
Originally Posted by eric@edgeautosport View Post
I ran the same setup for 20k with zero creep. Its almost impossible to get creep with that hotside on a 30r turbo with that ewg location.
When I called ya'll about it you said creep would happen with the 90 bend off the WG.
Mods: Come find out
"Man, ya'll have those dam scaners! we needs somo thos"
"FYMSN" - Honda
"its not yall its me."
 Old 09-25-2012, 12:08 PM   #44
Matx's Avatar
Originally Posted by Zdraveca View Post
this
It did take me awhile to decide what to do with the car to build it or put stock motor in, along with alot of family things going on and trips to NY, And Im glad that they held onto it for as long as they did.
Mods: Come find out
"FYMSN" - Honda
The Following 4 Users Say Thank You to Matx For This Useful Post:
BOTTLEFED08 (09-25-2012), Easter Bunny (09-27-2012), XLT_66 (09-25-2012), Zdraveca (09-25-2012)
 Old 09-25-2012, 12:11 PM   #45
yes you are correct but maybe my post wasnt clear enough. I said it wont get any creep with it in that location meaning directly off the hotside and not with a 90* bend
 Old 09-25-2012, 12:27 PM   #46
Eth Fiend
phate's Avatar
Posts: 4,250   (View Stats)
phate has disabled reputation
Can you give us some details about the new engine? What parts and who built it. Has timing been verified? Has a compression test been done?
Looking at your data logs, it should be making some pretty good power. What fuel are you using? Any meth/eth?
-06 MS6 - Tuning the high compression forged mill
-Corn fed 07 MS3 - Sold
phate is online now   Reply With Quote
 Old 09-25-2012, 12:52 PM   #47
Matx's Avatar
pauter rods and cp pistons/ cobb/ twice/ compression is good 93oct. no meth.
Also, put an EGT gauge on it this time around. You may have something wrong with injection and/or spark timing. You have the only melted valve I've ever seen, lol.
I've gone through and read a bunch of your past posts and I feel there is a LOT of missing information. How the hell did you burn a valve? What did the tune look like, how much power were you running? Spill the beans man, that's the only way we can help you.
Car was tuned by cobb about a week before power in the premotor run 326awhp 316tq. Spark plug tip melted off and took a joyride.
Mods: Come find out
"FYMSN" - Honda
Last edited by Matx; 09-25-2012 at 12:52 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-25-2012, 12:54 PM   #48
Eth Fiend
phate's Avatar
Sorry about the above ninja edit. I read further into the thread and realized the valve was broken, not burnt, lol. Crazy shit.
How was timing verified? What were the compression results? What compression ratio is the engine, what machine work was done to the engine? What parts were new/used? What was done to the head - any port work or aftermarket valves?
The story doesn't add up. Everything in the log looks good. That much boost and timing should be making some pretty nice power. That leads me to think it is engine related.
06Speed6
802MS3 (09-25-2012), atvfreek (10-22-2012), XLT_66 (09-25-2012)
 Old 09-25-2012, 01:06 PM   #49
Matx's Avatar
06Speed6
XLT_66 Calvin@COBB
Mods: Come find out
"FYMSN" - Honda
The Following User Says Thank You to Matx For This Useful Post:
 Old 09-25-2012, 01:15 PM   #50
Eth Fiend
phate's Avatar
When they had it all in one peice it would hit 280 awhp on the dyno and just shit out, said it was a restriction some place...
What do you mean by "shit out"? Does it stutter or does it just stop making power but still run smoothly?
 Old 09-25-2012, 01:17 PM   #51
XLT_66's Avatar
Posts: 706   (View Stats)
I'm just getting relays from Plano on everything but this is what I know:
- 9.5:1 CP Pistons
- Pauter Rods
- Upgraded Eibach valve springs
- Mild porting in the head
- VVT Upgrade
The same engine builder and head work has been done on a few other DISI motors by the same person with good results.
Car's timing has been checked a couple of times
It's my understanding that the car burnt up a valve and ate a spark plug on the factory motor. This is the first time I've ever heard of a DISI doing this as well.
Car sat in Plano for like 3 months before Matt was able to make a decision on what to do with it. However, everyone agrees that the build, once figured out, has also taken too long and everyone is doing everything possible to get this figured out and out of there.
This is the dyno plot of the car pre and post the build with the same turbo setup.
As you can see, more boost is yielding less power and the car is really falling off around 5700 RPM where previously it did not used to.
Needless to say...it's been a tough one.
- Checked Timing
- Checked Cat Converter
- Ran on Dyno with no CBE (remove restriction...no change)
- Replaced coils
- Replaced all injectors (increased power)
- Checked turbo for damage...none
2009 CWP MS3 Sport
XLT_66 is offline   Reply With Quote
The Following 8 Users Say Thank You to XLT_66 For This Useful Post:
802MS3 (09-25-2012), atvfreek (10-22-2012), BOTTLEFED08 (09-25-2012), Easter Bunny (09-27-2012), Matx (09-25-2012), phate (09-25-2012), pzr2874 (09-25-2012), silvapain (10-24-2012)
 Old 09-25-2012, 01:27 PM   #52
Eth Fiend
phate's Avatar
Torque is falling WAY off on the top end with the same boost. Has the seat pressure and open pressure been verified on the valve springs? Has valve clearance been double checked.
Valve float would kill top end power just like you're seeing.
Edit: AFR's are staying pretty steady, though, so maybe not valve float...
Boosten Ya(josh) (09-25-2012), pzr2874 (09-25-2012)
 Old 09-25-2012, 01:39 PM   #53
Hunting for teh Fastz
BlueStreak's Avatar
Posts: 1,401   (View Stats)
Have you checked for exhaust leaks before the primary O2 sensor?
I had a very very similar issue where the data logs indicated that the car should be ripping but it made very little power. It took a very aggressive tune to even eke out 285whp.
Turns out I had a 1" crack in my exhaust mani and my DP wasn't secured properly against the turbine housing. Putting around, the car ran just fine. Under boost, it would break up and fall on its face.
Like you, I also tried swapping injectors and coils but it didn't do anything. Fixing the exhaust leaks brought the car to life.
'07 CWP MS3
Forged.
The Following 5 Users Say Thank You to BlueStreak For This Useful Post:
atvfreek (10-22-2012), chimmike (09-25-2012), Easter Bunny (09-27-2012), phate (09-25-2012), XLT_66 (09-25-2012)
 Old 09-25-2012, 01:50 PM   #54
Will fuck up ur day
chimmike's Avatar
chimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the world
Groans: 409
Groaned at 205 Times in 121 Posts
I see the cat has been "visually" checked, but frankly that don't mean shit. You see how much soot we cough out of these cars, and CPE catted dp's have failed before. Bet that sucker is clogged up. If it's not making the power it should on or off boost, and the logs and everything look good, tells me the engine is probably fine. Bolt up a non-catted downpipe and see what that does.
07 MS3 bone stock?
The original Genpoo Hater
GTX3076r
FenderRollerRental Rent a fender roller, or MZR DISI Timing tools!
Originally Posted by woodfloor View Post
According to Roddiy, A List of Things as funny as fucking with MSF:
  1. Pissing in a bee hive
  2. Bridging the bus bars in an electrical panel with your dick
  3. Running with the bulls
  4. Willingly climbing into the lion habitat at the Zoo
  5. Shooting yourself in the foot on purpose
  6. Jumping up and down on a Fire Ant hill
@kyle undefined loves giving blowjobs to @raider; in truckstop bathrooms
chimmike is offline   Reply With Quote
The Following 7 Users Say Thank You to chimmike For This Useful Post:
atvfreek (10-22-2012), Boosten Ya(josh) (09-25-2012), BOTTLEFED08 (09-25-2012), lilred (09-25-2012), phate (09-25-2012), pzr2874 (09-25-2012), XLT_66 (09-25-2012)
 Old 09-25-2012, 02:21 PM   #55
Matx's Avatar
well at this point once the turbo goes back in with the new hotside, and still has the problem; I'll be getting a catless DP already have my eye on one in Ftworth area that I'll see about getting droped off to cobb
Mods: Come find out
"FYMSN" - Honda
The Following 3 Users Say Thank You to Matx For This Useful Post:
Boosten Ya(josh) (09-25-2012), chimmike (09-25-2012), XLT_66 (09-25-2012)
 Old 09-25-2012, 02:24 PM   #56
Will fuck up ur day
chimmike's Avatar
Groans: 409
then throw in some E or meth and make some big power! Solid motor to back it up!
07 MS3 bone stock?
GTX3076r
 Old 09-25-2012, 02:27 PM   #57
psn boostenya
Boosten Ya(josh)'s Avatar
Posts: 3,924   (View Stats)
Boosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the world
Groans: 38
Groaned at 15 Times in 13 Posts
Anyone have a catless dp laying around that he could borrow for testing?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Boosten Ya(josh) is offline   Reply With Quote
The Following User Says Thank You to Boosten Ya(josh) For This Useful Post:
 Old 09-25-2012, 02:29 PM   #58
Matx's Avatar
will save that for another project, got a meth kit sitting in the garage, will have to make a trip to SSP tho as Plano dont tune for meth.
Mods: Come find out
"FYMSN" - Honda
 Old 09-25-2012, 02:32 PM   #59
psn boostenya
Groans: 38
Have a tuner here tune you for meth
08 Mazdaspeed 3
 Old 09-25-2012, 02:59 PM   #60
pzr2874's Avatar
Posts: 3,911   (View Stats)
Groans: 89
Groaned at 103 Times in 69 Posts
Watch it be the DP....
2007 CBM MS3
Originally Posted by Macncheese View Post
Sniff sniff... Bunch of vaginas in here.
R.I.P.
JVella22
MacnCheese
bmylez
 Old 09-25-2012, 03:01 PM   #61
BlueStreak's Avatar
Doing a backpressure test would be easier/quicker than swapping DPs.
'07 CWP MS3
Forged.
The Following 2 Users Say Thank You to BlueStreak For This Useful Post:
BOTTLEFED08 (09-27-2012), chimmike (09-25-2012)
 Old 09-25-2012, 03:02 PM   #62
Speeeeeed
06Speed6's Avatar
Posts: 5,731   (View Stats)
First things first, that isnt a intake valve its an exhaust valve. If the injectors have been swapped and tune is good then the only thing I can think of that could generate that amount of heat is a clogged cat.
If it runs, drive it around for half an hour at night and see if the cat starts glowing.
2006 Mazdaspeed 6
P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant
06Speed6 is online now   Reply With Quote
The Following 5 Users Say Thank You to 06Speed6 For This Useful Post:
atvfreek (10-22-2012), BOTTLEFED08 (09-27-2012), chimmike (09-25-2012), mczimer (09-25-2012), XLT_66 (09-26-2012)
 Old 09-26-2012, 08:05 PM   #63
Matx's Avatar
So swaped out the hotside and problem is still there, Going to put in a catless downpipe in... anyone in dallas have an extra one?
Mods: Come find out
"FYMSN" - Honda
 Old 09-27-2012, 05:41 AM   #64
BlueStreak's Avatar
Have you checked for a leaking bpv?
'07 CWP MS3
Forged.
 Old 09-27-2012, 12:00 PM   #65
Matx's Avatar
Has cobb bov with new gasket, and it holds boost fine...
Mods: Come find out
"FYMSN" - Honda
The Following 2 Users Say Thank You to Matx For This Useful Post:
BlueStreak (09-27-2012), BOTTLEFED08 (09-27-2012)
 Old 09-27-2012, 04:28 PM   #66
BOTTLEFED08's Avatar
Posts: 652   (View Stats)
BOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the worldBOTTLEFED08 is the leader of the world
Groaned at 11 Times in 6 Posts
Matt.. remember when we put your turbo in, we were looking at how rough the bellmouth was inside the Downpipe, I wonder if that lip that was sticking up by the flange ended up breaking apart and getting stuck in the baffles clogging that cat?? I think David remembers seeing that, possibly Jim too.
2008 MAZDASPEED 3 THE TORQUE MONSTER
BOTTLEFED08 is offline   Reply With Quote
The Following User Says Thank You to BOTTLEFED08 For This Useful Post:
shopety2012 (09-27-2012)
 Old 10-04-2012, 03:46 PM   #67
Cheeto's Avatar
Posts: 368   (View Stats)
Cheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the world
Bump
Any update Matt??
Chad Erwin -ATX
06 MazdaSpeed6 Gt AWD/Turbo/#5994
MODS:
COBB AP // MSD Dashhawk // Street Unit TMIC // Street Unit Test Pipe // COBB SRI intake // Speedies TIP // Turbosmart BOV // RPM Street Spring // Bilstein Struts/Shocks // TWM Stage 2 Short Shifter // CPE Dogbone rear mount // CPE Dogdone Diff mount // COBB Shifter weight // HPFP Internals // Magnaflow 3IN Cat Back// Denso ITV 22s // Shorty Antenna // PA Engineering OCC // LED swap
Cheeto is offline   Reply With Quote
 Old 10-04-2012, 07:37 PM   #68
Matx's Avatar
Replaced catted downpipe with noncatted same problems, valves and springs were pulled for valve float everything is to spec they are gonna try it with shims or some shit other than that ..... Still the same problem. My car just loves to be put on the dyno I guess....
Mods: Come find out
"FYMSN" - Honda
 Old 10-05-2012, 03:32 AM   #69
pzr2874's Avatar
Groans: 89
That blows. You know they have a spare built motor there?
All else fails, have them plop it in. Ask Calvin about it.
2007 CBM MS3
R.I.P.
JVella22
MacnCheese
bmylez
 Old 10-05-2012, 04:33 AM   #70
Matx's Avatar
Fuck that I want the rods and pistons I paid for and 0 miles on it, built another block if need be.... but we will see....
Mods: Come find out
"FYMSN" - Honda
Zdraveca (10-05-2012)
 Old 10-13-2012, 01:18 PM   #71
Matx's Avatar
SO valves were set right no float.... they are checking the transmission, pto and diff......... ..... .... . .. . ya
Mods: Come find out
"FYMSN" - Honda
 Old 10-13-2012, 04:19 PM   #72
Cheeto's Avatar
Man.......sorry to hear bro. Keep use updated. I think we all want you to get your car back soon but like you we want it to be right.
Chad Erwin -ATX
MODS:
 Old 10-22-2012, 09:50 AM   #73
Cheeto's Avatar
Bump.......
Any update Matt?
Chad Erwin -ATX
MODS:
 Old 10-22-2012, 10:11 AM   #74
JWSpeedWorkz's Avatar
Posts: 144   (View Stats)
JWSpeedWorkz has disabled reputation
I can't believe no-one has asked HAVE YOU CHECKED YOUR CAMS? Breaking a valve like that could have damaged at least 1 lobe on your cam, and an engine trying to heave around an underperforming hole will look ok, but spit out bad numbers. I would honestly suggest doing a power balance test using an IDS enabled scan tool, such as the autel maxidas ds708. Power balance tests can tell you a bunch. (may also be called cylinder contribution)
Hers: 06 MS6, 53 Pontiac Cheiftan Sedan
His: 53 Ford Business Coupe
JWSpeedWorkz is offline   Reply With Quote
 Old 10-24-2012, 01:33 PM   #75
Matx's Avatar
Cams= replaced
Mods: Come find out
"FYMSN" - Honda
 Old 10-24-2012, 01:54 PM   #76
Gotcha, I didn't see it mentioned.
 Old 11-04-2012, 01:03 PM   #77
Matx's Avatar
So they checked the head readjusted lifters and valves, They are removing the blanceshaft... other than that everything to the motor beside the block itself has been checked.
Mods: Come find out
"FYMSN" - Honda
 Old 11-10-2012, 05:50 AM   #78
Mattcinnc1's Avatar
Posts: 260   (View Stats)
Mattcinnc1 has a reputation beyond reputeMattcinnc1 has a reputation beyond reputeMattcinnc1 has a reputation beyond reputeMattcinnc1 has a reputation beyond reputeMattcinnc1 has a reputation beyond reputeMattcinnc1 has a reputation beyond reputeMattcinnc1 has a reputation beyond reputeMattcinnc1 has a reputation beyond reputeMattcinnc1 has a reputation beyond reputeMattcinnc1 has a reputation beyond reputeMattcinnc1 has a reputation beyond repute
any more updates?
2006 Mazdaspeed 6 WWP
Mods: Cobb ap, rebuilt ko4(hhskinny), Autotechs, AEM CAI, ETS tmic, Sure sidewinder, sure charge tubes, Corksport strut tower, catless test pipe, Magnaflow CBE, Forge BPV(v1), VTCS delete
Interior: Block Vent pod, Prosport boost gauge, Redline leather boots, Mazdaspeed E-brake, Ipod integration, Corksport LEDs
Looks: blacked out corners, 15% tint, Corksport LED fogs, Corksport stub
Fluids: Rotella T6, Motorcraft XT-M5-QS, Redline 75w90
waiting to install (in garage): JBR RMM(in mail)
Mattcinnc1 is offline   Reply With Quote
 Old 11-10-2012, 05:59 AM   #79
Matx's Avatar
Motor is on its way back out of the car....
Mods: Come find out
"FYMSN" - Honda
 Old 11-10-2012, 09:35 AM   #80
shopety2012's Avatar
Posts: 366   (View Stats)
shopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the world
Groaned at 69 Times in 37 Posts
Exciting lol
left side drive conversion, break shit father figure mod, 2.3 slow swap
first gen pu with a gen 1 tranny.. i think?
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
TEAM Dad -- FYCN
shopety2012 is online now   Reply With Quote
Installed Cobb SRI and Turbosmart BPV, now have a weird noise under the hood when I shut off the motor.... Todd H 2010 MS3 - Turbo Induction 11 01-07-2011 09:59 PM
Page generated in 0.57755 seconds with 35 queries
