Notices
 Old 12-06-2008, 08:55 PM   #1
vballbwing's Avatar
Posts: 161   (View Stats)
vballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant futurevballbwing has a brilliant future
Default CPE Xcel Air Intake --Cleaning
Just got a 2006 Mazdaspeed6. The previous owner had the CPE Xcel Air Intake installed. While I haven't needed to do any maintenance on the car, I'm wondering if anyone else has this part and how to clean the air filter?
vballbwing is online now   Reply With Quote
 Old 12-07-2008, 02:08 PM   #2
Poohster's Avatar
Posts: 200   (View Stats)
Poohster has a reputation beyond reputePoohster has a reputation beyond reputePoohster has a reputation beyond reputePoohster has a reputation beyond reputePoohster has a reputation beyond reputePoohster has a reputation beyond reputePoohster has a reputation beyond reputePoohster has a reputation beyond reputePoohster has a reputation beyond reputePoohster has a reputation beyond reputePoohster has a reputation beyond repute
Cleaning the air filter element is the same as cleaning a K&N flter. You need to remove the filter element from the car. I removed the 3 or 4 screws to the plastic wheel well cover so you have access to the filter. Reach up and loosen the band clamp to remove the filter element off the CP-e Xcel tube. Shake off loose debri and spray on cleaner. Let stand for a few minutes. Rinse the filter from the inside out. Don't use high pressure. Let air dry. Then apply oil. Re-install newly oiled filter and put back screws to plastic wheel well.
This should be good for you unless you have an oiless "dry" filter.
06 MS6, Blk Mica, MS wheels 18x7.5, Yoko ENvigor P225/45-18, Magnaflow CB, SU MM, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, MPI Upgraded K04, TT Diff Frt mount & Rear Bushings, SP slotted rotors, Hawk rear pads, Whiteline RSB, Steedspeed mani, JBR Thermal Gaskets. Cobb AP
RPM: Sport Springs, Shark Fin, LED side markers
HKS: BOV
CP-e: CDFP, TIP, Xcel CAI, Catted DP, BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, MZR DISI Stage 1 clutch
Poohster is offline   Reply With Quote
 Old 12-09-2008, 07:50 AM   #3
vballbwing's Avatar
I haven't taken it out or looked at it yet. So I'm not sure if it's oil-less.
Speaking of k&N. I had a K&N filter in my previous car, can I use the same cleaning kit for that K&N filter with the CP-E filter? --Should be the same idea as other filter cleaners and oil, but I'm not sure if the CP-E has some proprietary or recommended cleaners.
thanks for the info. I may try to get under the hood this weekend(depending on the weather).
 Old 12-09-2008, 07:56 AM   #4
SgtP's Avatar
Posts: 2,117   (View Stats)
Groans: 106
Groaned at 28 Times in 20 Posts
i thought the XCel came with a dry filter but I may be wrong.
13.2@111
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is online now   Reply With Quote
 Old 12-09-2008, 08:09 AM   #5
ChrisK's Avatar
Posts: 1,168   (View Stats)
ChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the world
Groans: 56
Groaned at 15 Times in 14 Posts
My Xcel came with a dry filter
ChrisK is offline   Reply With Quote
 Old 12-09-2008, 11:09 AM   #6
Poohster's Avatar
Mine came with a Afe filter. I bought it when CP-e first produced the Xcel. It was blue. I think (and someone can correct me) a dry filter is not colored. I used K&N cleaner and oil for my filter.
HKS: BOV
 Old 12-09-2008, 11:46 AM   #7
danesti's Avatar
Posts: 4,190   (View Stats)
danesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the world
Groans: 137
i just bought a cpe CAI and it came with an oil filter (blue one). my previous CAI was the AEM w/ dry flow.
2008 STi
Intake
Turboback
AP
danesti is offline   Reply With Quote
CP-E Xcel Cold Air Intakes For MS3 In stock! kevin@gripgarage.com Mazdaspeed3/6 General Discussion 7 01-08-2009 04:57 PM
Cp-e Xcel Nano install and review w/ pics n vids copperkid Custom Performance Engineering (cp-e.com) 19 11-07-2008 01:53 PM
iRobot Roomba 510 Vacuum Cleaning Robot $159.99 Free Shipping at Buy.com Haltech Hot Deals Section 0 04-15-2008 12:20 PM
Page generated in 0.29786 seconds with 24 queries
