 Old 12-03-2019, 12:38 PM   #1
lowtone20hz's Avatar
Posts: 2   (View Stats)
lowtone20hz is an unknown quantity at this point
Default Cylinder Head Bolts
I recently had to remove the head and get it cleaned up, serviced, etc. When reinstalling the head, am I able to reuse the stock head bolts? The shop manual doesn't mark them as replace and it has a section on page 01-10-27 about bolt inspection. Am I correct that I can reuse the bolts as long as they are within spec? Thanks.
lowtone20hz is offline   Reply With Quote
 Old 12-03-2019, 02:38 PM   #2
Police - Grammarhead
Vansquish's Avatar
Groans: 1,906
No. The head studs are torque-to-yield devices. If the proper torquing procedures is followed during installation, the studs will stretch. While you *could* reuse them, I think it would be fair to say that most people on the forum would recommend replacing them.
 Old 12-03-2019, 03:28 PM   #3
Db09ms3's Avatar
Posts: 507   (View Stats)
Db09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the world
Groans: 96
Yeah them bolts are a one time use dealio, so just buy new Mazda OEMs.
Stockish
Head Bolts jaguar_mike CX-7 > Engine, Transmission & Driveline 10 02-10-2016 03:18 PM
Oem Head Bolts rusharp MazdaSpeed 6 - Engine, Transmission & Driveline 13 02-07-2016 09:36 AM
How much will stock head bolts hold... mOBSCENE MazdaSpeed 3 - Engine, Transmission & Driveline 20 04-23-2015 03:29 PM
MS3 Cylinder head bolts(Ebay) joey Mazdaspeed3/6 General Discussion 12 09-22-2014 07:48 AM
Page generated in 0.24185 seconds with 22 queries
